THANKS
What could be causing this?
I have a 2000 Ford Explorer Eddie Baur.
Periodically the tac will work, most of the time it does not. When the tac is not working, the display on the radio does not work. When the tac works, the display on the radio works.
Any ideas/suggestions?
Terry
Sorry folks, I thought I was adding a new thread.
I have a 2002 ford explorer that cuts off and wouldnt start back up. The fuse in slot 41 blows and I have to replace it and it start up . what does that fuse belong to ?
One day it will start, the next, it won't.
I and a friend believe it is a fuel delivery problem as he couldn't hear the fuel pump prime up when the ignition was turned on (had his ear close to gas tank) and when you give it a little starting fluid, it attempts to fire but won't, so we belive it's getting spark.
It dosn't even ATTEMPT to fire when it won't start, but when it DOES start, it fires right off the bat and runs & drives fine, no missing, no bogging, no hesitations, etc.
Fuel pump? Fuel pump relay? Filter? I always believed that a fuel pump is either dead or alive, NOT intermitent. True?
Like the tree said to the lumberjack, I'm STUMPED!
One simple symptom of bad ball joint is the front end loosness that you feel when you go over bumps or you might see it in your front tire wear.
As far as the front hubs go....I don't know what the sign is where both are bad right now... Squeals? dragging when a suspended free wheel is turned? grease leaking out?
Joe
I went to clean my windshield and hit the mist button
it sprayed washer fluid but then the wipers STAYED ON...will not turn off until I restart the vehicle
so I restart and now the wipers are off but not in the lowest position..i have to manually turn switch to time it to just right to turn them off at the bottom of windshield
...started to rain so i turned on the wiper delay
..doesn't work
..just keeps running at normal speed on ALL delay setting
Hi speed and Low speed function works on the wipers but didnt shut off even in the switches off position...then
POP!..pops a fuse
replaced fuse
..POP when I turned key to acc
swapped around relays in box under hood related to wipers according to the owners manual position..NOTHING..still popped when I replaced fuse
HELP!
between 20 and 30 mph and 40 to 50 the car hesitates. Was there a repair done? what was it and how much did it cost?
amatte@mail.com
Had 2 wheels fall off
Axel bend
Replaced transmission
misc other stuff
The latest....the car stopped working while idling in traffic. Went into "limp home" mode. Wouldn't turn over or do ANYTHING. Towed it to the mechanic who thought that the key dropped code. After trying a second key and not having it work, our local guy said that he thought it was the security system and that the dealership would have to do it. The security light was flashing very fast, which led him to think that was the problem.
Car is on it's way to the dealership.
If this has happened to you...what kind of cost was it? We know that the dealership will have to scan it and figure out specifically what is wrong, but are we talking a few hundred dollars...a few thousand???
