Dodge Dakota 4x4 Problems
13»
  • oootinmanooooootinmanooo Member Posts: 1
    edited July 2011
    my check engine light is on when i start my truck in the am. i have no power from starting point to 60km per hour. after driving the truck for an hour or 2, the engine light shuts off & normal start & stop power is back. please help! it's a 2001 dakota v6 4x4 auto. all fluids are full and oil changed regularly
  • bobbyg22bobbyg22 Member Posts: 3
    i have a 2005 dodge slt quad cab when i use my powere door locks or my key to open door it engages my transfer case motor and puts into 4 wd i use the electronic switch on dash sometimes to get it out sometimes my 4lo light on dash flashes does anyone have any ideas
    hey let me know my problem is when i use my power door locks it engages my transfer case motor and when i use my key to get into my truck let me know
  • carvermancarverman Member Posts: 101
    edited December 2011
    The transfer case is shift controlled electronically. There is a TCCM (Transfer
    Case Control Module + the encoder motor sensor + the selector switch on
    the dash. The problem may be in any one of those three. best to take it to
    a dealer and use the DRB scan tool to analyze the fault.
  • 2818micheal2818micheal Member Posts: 2
    today my trucks 4 lo light flashed 3 times them repeated while driving down the interstate.later i was backing up out of a parking stall and it dropped into 4 lo on its own took 3 times of forward and reverse to get it to go anywhere. does sound like your problem if so what did you find out?
  • marchalmarchal Member Posts: 3
    I ended up having to take it in and the problem was the 4wd control chip which needed to be replaced. I think I ended up spending about $600 to get it fixed.
