Chevy Silverado and GMC Sierra Transmission Problems
1414244464750
  • obyoneobyone Posts: 8,065
    Have you checked with your local BBB office? Lemon law vary by state. However, the one common denominator is the three repair rule. The manufacturer has three attempts to fix the problem, if it is not repairable for whatever reason, the BBB can be instrumental in getting you a buyback which is way better than trying to trade or sell a truck with known issues.
    Just saying....
  • gmcustsvcgmcustsvc Posts: 4,246
    galvezfj,
    I understand your frustrations. Due to your situation and concerns as well as the department you have worked with, there isn't a lot that I can do. They are better quipped to handle your situation. I apologize for your inconvenience.
    Christina
    GM Customer Service
  • lisa117lisa117 Posts: 1
    I too am having transmission problems but was told it has to do with the torque management system on the vehicle. Also, I was told that no repairs could be made to fix it and that I should consider it to be normal. I bet if it was their money on the line they'd want an investigation done. It's a potentially serious mechanical problem as well as a safety issue.
  • Keep trying, I complained so much, sent a certified letter to the ceo of GMC, finally the district manager called and offered to buy me out of my 2011 and into a 2012. I am still waiting for the dealer to locate an identical truck but hope to get results soon. The truck is dangerous, it actually accelerates as I'm slowing down and it is always in the wrong gear constantly up and down shifting and bogging because it won't accelerate when necessary! Keep screaming or we will need a class action law suit!
  • I have posted on this before. My truck is at the shop again. I am pushing them to look into the TPS this time. I continue to have downshift/re-acceleration issues with my 2009 GMC Sierra 5.3l 6-speed 3.42 rear end. Very, very, very frustrated. I have an open case number and talk with GM reps...they are very professional, but absolutely no help. The dealer is great...the problem is GM engineers...they need to come up with a fix for this known problem and known issue. I pay a ton of money for this truck and it is the nicest vehicle I have ever owned (bought in '10 with 12K on it). I now have 69K on it.
    there are no codes...which renders the local dealer mostly helpless as they try to fix the crappy programming of the TPS, TMS, and Transmission. The loaner vehicle I have this time is a 2012 Colorado with the 5.3l in it and a 4speed. Oh, how I miss the 4 speed. This little truck rocks...seems so much "less confused" than my Sierra.
    I drove a 3.5l EcoBoost the other day...WOW. Ford has that thing dialed. Makes it pretty hard to want to stay in this GM product. Don't get me wrong...I really, really like my truck. Like how it looks, interior, power, fuel economy...but when I have been driving a vehicle for 30K+ miles and continue to bring it in to the dealer to fix a very, very serious drive ability issue and they are left stranded by GM who, with all their R&D and techy know how can't seem to program the thing to run correctly...well, quite frankly, it sucks rocks.
    Should be getting a call today from the dealer. Will let you know if whatever they "fix" this time changes anything.
    Jake
    MN
  • Thank you for your reply! I actually figured this would just get lost in cyberspace. I will email with info. I also still have the same problems only progressively getting worse. I am planning yet another trip to Dominion Chevrolet Richmond, Va. very soon to look at these problems. 13,000 miles and I want documentation before my warrent expires or runs out.
  • Definitely sounding like a solenoid issue. If you've never replaced that on your stock transmission, I'd suggest getting on line to GM Parts Giant, GM Parts Direct... one of those should have your solenoid.
    The R&R will be tough if you don't have a trusted transmission person that will do the service without telling you "you need to check this". A tale-tell sign is if the transmission fluid is it's pretty ruby-red, and there's no sediment, get the solenoid changed. The R&R shouldn't be more than $100 if you have the part. Call the stealership and get the part number, and roll from there. If the fluid is in good shape you should be able to re-use it.
    Let me know how you make out.
  • Lady3bgloverLady3bglover Posts: 24
    edited July 2012
    If they're going to give you a "deal" on a new buy, ask for the LT package. It has a little better transmission, and if you're in the need to tow something, all the goodies will be there.
  • I also have a 2012 6 speed that is not running correctly. Especially going down a hill or mountain. The trans just goes into free wheel mode and here you go. Pulling a trailer going down hill is always my favorite idea of fun.
    I have called GM and setup a case on it and they are playing the normal games of nothing wrong with it. Like you said if it was there dollar I bet it would be fixxed or taken back.
  • galvezfjgalvezfj Posts: 12
    I finally got my truck back 2 weeks ago. So far its running as it should have when it was purchased. Dealer found pump and converter full of metal on the rebuilt transmission. GM finally authorized a transmission replacement on my not so new 2012 silverado lt 5.3 6 speed 4x4 z71. Now im hoping it will last longer then the last one (2k miles). Im not holding my breath and I contacted a lawyer.
  • Has any one here in the forum thought about or tried to put true duals exhaust on a 6.0L to see if it helped in the performance and fuel mileage. I cannot believe that with all the technologies we have and a 2012 GMC 6.0L 6 speed transmission will only get 14MPG. Thats on a good day along with the no power issue. I am waiting to see what GM is going to do.
    As far as I am concern they can buy it back.
  • lchaney33lchaney33 Posts: 2
    I have a 2012 1500 with the 6.2 and the 6 speed transmission and have had nothing but problems since I picked up the truck.
    I feel that not only are the issues aggravating but also quite dangerous. I have found that I can not change lanes and expect the truck to accelerate without a HUGE amount of lag time.
  • What did you do about the Cat converters?
  • Just bought that same model truck. Transmission already playing games and the truck doesn't even have 1500 miles on it.
  • sounds about right. Mine right off the bat was surging on take off. Now when you hit third gear at a some what normal speed then try to accelerate it sound like it is struggling badly. Bogging
    Take it back to the dealer and complain. I took my truck in and had a ride along from the transmission tech. He's the one that said "Yes the truck is not shifting properly". Then i got a call from 866-790-5600 ext 11040 his name is Houston. He's a customer support rep that help me get my transmission replaced in my Truck. Hope this helps you. I went through the original and a rebuilt tranny before i hit 5k on the truck.
  • This is where I have seemed to get responses from GM getting them to act on warranty.
    https://my.chevrolet.com/web/portal/managemybrand?g=1
    Back in '02 no long after I bought my Silverado, it wasn't the transmission yet. It was the lifter tap. I actually had a Regional GM Representative make the trip to the dealership and assess my truck's issue.
    So go register your car and be heard.">link title
    galvezfj,
    Thank you for taking the time to share your experience with GM Customer Service. :-) I am happy to hear you are satisfied after working with us. Please feel free to contact me with any questions comments or concerns.
    Christina
    GM Customer Service
  • Is there a posted TSB (Technical Service Bulletin) on issues with the 2011 and 2012 6spd transmissions?
  • There is a service bulletin, my service manager printed and gave it to me. They are all aware of the problem but refuse to fix it. Apparently GM had to increase the average gas mileage of all trucks so they made the 6 speed and have it shift prematurely to lower engine speed and increase the mileage. Keep complaining to your dealer and then start sending certified letters to the CEO of GM
  • i have the same problem with my 09 sierra 5.3. im driving come to a stop then thump 4 seconds then thump and another 4 seconds then another thump then nothing. trying to see how many more ppl have this problem and if you have any info on this problem i would like some feedback.
  • chuck1chuck1 Posts: 1,405
    "There is a service bulletin, my service manager printed and gave it to me."
    AND what does it say?
  • I have the same issues with my 2012 GMC Yukon. I was told it's supposed to shift that way to increase fuel efficiency. I have my truck in the shop right now, this is the final straw. If they don't get it to drive properly I will have no other choice than to get a "Lemon Lawyer" I think GM should recall all of these trucks and replace the 6 speed with the old reliable 4 speed.......how about a class action suit!
  • I would be interested in the lawsuit.
    my truck is almost 2 years old and its been doing this crap since the day I bought it new.
    it been in the shop more times then I can remember and told the same 2 stories. " its supposed to make noise and shift hard, its designed that way" OR " what noise? what hard shift?"
    my last trip was to a new dealership that admits there is a problem but will not put it in writing.
    figures.
    YOU STILL SUCK GM!
    STILL AN UNSATISFIED CUSTOMER.
  • Has anyone registered their vehicle with GM on line and gone around the dealership? I've mentioned this before... This system works.
  • Hello, please elaborate on house you "went around" the dealership.
    El Hoppy-
    We have all heard numerous times how unhappy you are. Buy a Ford F150, RAM, or Tundra and move on.....
  • rayt2rayt2 Posts: 1,208
    The old reliable 4 spd auto is no better. My tranny went at 62k, 5 years ago :sick: . 2000 3/4 ton (7200gvw) Silverado 5.3 auto w/overdrive. My trans shop said unless you bought the heavy duty trans option all you were getting was the same tranny found in a Camaro. He rebuilt it with stronger torque converter and upgraded the brain to a Corvette module to quicken the shift. $1800 out of pocket. 95k so far on odo.
    Would I buy another GM product........NO ! and I tell that to anyone I meet on the street when they talk about buying one. Besides they have gotten pretty ugly in design to boot. Is Dodge or Ford any better? don't know their design dept has more going for it then GM's bland look, but that will be my next choice when I am ready to buy new again.
    Ray T
  • Bought my truck used from a Dealer in Arizona. I live in PA. What a mistake that was but thats another story. I bought a 2010 silverado 1500 with the 6.2L 6 speed 49,000 miles. The first trip I took as soon as I got out of my driveway the Tranny slipped and the engine just reved and went nowhere. As long as you babied it it would run just fine. So I take it to the Dealer they flushed the transmission thinking it was there for service and called me and said its all done everything is working perfectly. I said a flush fixed the slip? what slip? he replied. So they did tests and talked to a GM tech and decided to put a new valve body in it. I told them I smelt the clutch burning and it wasnt the valve body but GM knows best. So it didnt work and they tore the tranny apart and found a crack in the sleeve that holds the discs releaving pressure, fixed parts and on my way I went 2 weeks later. Now it lags when shifting from a dead stop to second gear and any time it has to shift down a gear going up hills or passing somebody. Took it back to the Dealer and they had it another 2 days just to tell me theres no codes coming up and we dont know what to do, my best GM tech says to put a programmer in it to see if that helps the tranny being confused because I have 35" tires. I said thats all good and fine but 35" tires arent gonna make my tranny temp go to 223 degrees when going up hills is it? He said no thats high temp but we are at a loss. I asked him does the 15 brand new vehicles you have on the lot with the Rocky Ridge package with 6" lift with 35" tires do this? no reply just we dont know.
  • Timid Temper doesn't your model have the 65e and 3.73 rear end?
    I maybe able to shed a little light for you.
Chevy Silverado and GMC Sierra Transmission Problems - Page 44 — Car Forums at Edmunds.com
