Chevy Silverado and GMC Sierra Transmission Problems
1568101130
  • medic979medic979 Member Posts: 2
    my 2008 sierra did the same thing at 2000 miles. The dealer lubed the slip yoke and it fixed the problem but they are skeptical. They said that gm is working on the problem. Tell your dealer to look up PI & bulletin .....PIP 4020D.
    If they told you this was normal, the need to fire the mechanic because my dealer found it right off the get and knew how to fix it.
    Good luck
    My 2008 sierra does the same thing. Tell your dealer to look up bulletin PIP 4020D
    The slip yoke needs to be lubed. It worked. My dealer said this a temporary fix but gm is working on a permenant fix. You would think that if gm would sell a truck for $32,000 it would work right. I should of bought a Toyota. Know wonder their stock is at $5.
    good luck
  • nerdnerd Member Posts: 203
    I need to install an auxiliary transmission cooler on my 2007 Silverado with 4.8L engine and auto trans. I see that GM offers a cooler at a competitive price, but the dealer wants about $200 to install it. The photo indicates it comes with the supply and return lines that run all the way from the transmission. Is this GM cooler that hard to install? I would appreciate any advice. Thank you.
  • tahoe10tahoe10 Member Posts: 2
    just bought a 05 silverado Z71 with about 71000 miles. i was wondering why/if its suppose to make a clunking noise when shifting in to 4lo? its my first truck.
  • 9_376_Slvrdo9_376_Slvrdo Member Posts: 5
    Yes, that's normal when you are engaging low range. It's just the transfer case changing to the lower ratio gears needed for 4L.
  • hcamarohcamaro Member Posts: 4
    It has 230000 miles on it. when i come to a stop the transmission down shifts into 1st really hard. other then that it shifts great. if there is anyone that can help me please tell me what this could be.
  • dkelley85dkelley85 Member Posts: 2
    I have a 2000 silverado. I was driving it the other day, then a loud sound came from under the truck, now I can put the truck into any gear, but it will only move in reverse. I can put in into drive, 1st, 2nd and 3rd, nothing happens. When I put it into PARK, it acts normal, the truck will not roll. Any suggestions!?
    Sorry to have to tell you, but I'm pretty sure you dropped (blew) your tranny. I had a truck years ago that did the same thing. Same problem, all I had was reverse, no forward gears. Park won't have anything to do with the gears. Just the parking paul dropping in to secure the vehicle. How many miles?
    144,000miles
  • carfaxcarfax Member Posts: 43
    Since 1999 and good old G.M. hasn't fixed the problem and they want the tax payers to bail them out. I am so glad this has happen to the big so called 3 and hope it will change the automotive world for ever. Sorry for the ones who lose their jobs and I have family that will be part of it, but they agree also that it has to change with the unions and management. They have held the average person hostage for decades and didn't give a dam about it.
  • b36b36 Member Posts: 15
    I posted before about my 2006 5.3 V8 sierra giving a bump when starting out slow..the bump occurs at around 15mph at the first shift. It does not do it if you can take a little faster. I took in to the dealer and they said there couldn't be any thing serious wrong or I would get a warning light. However they did re-program the transmission because of a service bulliten. It did nothing for the bump. A transimission shop says they thought it was the coolant pump hanging up. The service manager said if that was happening I would get a light. I have 6 months left on the warranty. does anyone have any ideas? Does any of this make sense? thanks
  • grumphygrumphy Member Posts: 6
    My 04 silverado does the same thing but only after it warms up .if i take off fast it does not do it. its been doing it for a long time.it now has 112.000 miles .i figure if i take it to a tranny shop they will tell me i need a new tranny .so i just leave it alone and have regular service fluid flushed.other then that bump from first to second its fine
    Joe
    Hey Joe in regards to your 04 Silverado.
    If your truck has a lot of hard tow miles it could be in need of some internal parts. If it's just 112k everyday miles then it could just be the 1-2 shift servo. The servo's are on the outside (side) of the 4L60e in your truck (assuming it's a 1500). It's an inexpensive quick fix also. The Hydro-Matic (GM) transmission is one of the best out there. BMW even uses the Hydro-Matic automatic trans. in their 5 Series cars. It's a very solid well built transmission. Don't listen to the GM haters out there.
    If there aren't many hard tow miles it might not have been properly serviced by the guy or guys before you. This is the reason General Motors now uses Dextron VI ATF, 100k before first service, verses 30k for the Dextron III or IV that your truck uses. The Hydra-Matic auto trans. is one of the best built out there. BMW also uses the GM Hydra-Matic (a 5 speed auto exclusive to BMW) in their 5 Series premium cars.
    I've always driven a Chevrolet from an '86 Chevy 3/4 ton 4x4,'96 Chevy Z71 to an '07 Tahoe and back to a Silverado. General Motors, GM Powertrain, makes the best most solid powertrains bar none. GM has the best interiors, the best ride and they are the most reliable out there.
    Don't listen to the GM haters out there. We really do need the domestic auto makers around. They are a large part of our Gross Domestic Product and of the Big Three at least General Motors makes a great product. GM's board just needs to replace parts of upper management including CEO Rick Wagoner possibly with Bob Lutz the "car czar" who is credited with the recent improvements at GM. Besides, what would the president do without his sweet custom armored Cadillac. Our lawmakers won't let the Big Three fail, too much of a trickle down effect. They've just been burned twice by AIG (A**holes, Ignorant and Greedy) now, so Congress just wants a solid plan. USA-1!!
  • cowboy50cowboy50 Member Posts: 1
    hope this helps
    You need to check fuel pressure at the rail on motor and check it at the fuel filter.
    If you got good pressure at the filter suppect the the fuel pressure regulator. If
    pressure the same both spots suppect fuel pump is weak.
  • PardPard Member Posts: 1
    Anyone had problems with there truck trying to start off in high gear and will not down shift or shift into overdrive. The problem is intermittent, and there is no diagnostic codes shown. Sometimes I can put back in park and shift back to drive and that fixes it momentarily.
  • bigblock2bigblock2 Member Posts: 1
    I have the same trouble with my 2005, Z71, with babied 20,000 miles.... seems to start in third if you let it. If i shut if off for a few minutes and re start the truck it will work fine. I'm thinking one of the servos is sticking ,but like you mentioned the problem is intermittent...
  • jamonettjamonett Member Posts: 1
    Hello everyone,
    I am having a very difficult time removing the transmission pan on my 04 Suburban. The bracket that holds the shift cable is blocking me from dropping the pan down. I have tried bending it out of the way, but that doesn't work as it is too stiff to bend it very far. And I don't want to break it off of the transmission case. It looks like I need to drop/remove the exhaust Y and then I can "fold" the pan down at a 90 degree angle and slip it out from behind the bracket.
    Any suggestions?
    Thank you in advance for any help.
    John
    Do you have the 5.3 or 6.0?
  • JParkeJParke Member Posts: 1
    Trans fluid is leaking through the wire harness plug. What is the cause. Is replacing the harness the only remedy? Can the fluid cause a short circuit at the plug. What seals the plug on the inside of the case? How difficult is it to replace the harness?
    Jim
  • DRAGRACER30DRAGRACER30 Member Posts: 1
    I HAVE A 01 CHEVY 2500 WITH AN ALLISON 1000 TRANSMISSION. THE TRANSMISSION IS STARTING OFF IN 1ST GEAR AND IMMEDIATELY SLAMS INTO 3RD GEAR. IT IS THROWING A P1711 CODE. THE SILINOID HAS BEEN CHECKED AND IT IS NOT THAT. WHAT ELSE COULD MAKE IT THROW SLAM INTO 3RD GEAR AND THROW THAT CODE? PLEASE HELP!!!!!!!!!!!!
  • geez150geez150 Member Posts: 2
    My 2004 chevy silverado 5.3 4x4 is having tranny trouble. After the tranny shifts into 4th gear and i'm doing about 40-55mph and in the rpm range of 1500-1800 it starts bucking bad. If i either speed up to say 60 it goes away or if i slow down it goes away. The STEALER has no clue! Any help would be great! :lemon:
  • freewheelin1freewheelin1 Member Posts: 1
    When I accelerate from a red light sometimes i hear a clunking from the tranny going into second gear and less so into third. I thought i read somewhere that the gear changing in Sierra's are noisy.... is this the case or should i consult someone that the tranny might be going.... I JUST bought it ...an 05 GMC Sierra 4x4 34,796 miles. It seems to occur more often when i accelerate a bit harder.
  • bluedroptopbluedroptop Member Posts: 1
    When the trans. temp. is between 100 and 150 degrees, the trans. shifts hard from 1st to 2nd. This isn't a constant problem, just occasional. Otherwise the trans. works fine. Any suggestion as to what is causing this problem, or remedies. Any info will be helpful.
    Thanks, bluedroptop
    update on my 2004 chevy silverado 5.3 4x4 with 31,000 on it, picking it up for the stealer tomorrow, they replaced the torque converter on it, so hopefully the problem will be gone :shades:
  • judice3judice3 Member Posts: 2
    I noticed that my trans. is leaking at the end were it meets the shaft. I checked my fluid levels and it looked fine. When i press the gas I take off normally, but if I let off of the gas i slow down abruptly. I contributed this to not letting my engine warm up enough, because when warmed up it acts normal. Any ideas?
  • GMCATWGMCATW Member Posts: 1
    1999 GMC Sierra 2500 4x4 Hi.. Does any body have any idea about my transmission. I do snow plowing and after couple of hours of driving back and forth, my truck wont go in reverse :confuse: for some reason so i have to park the truck for 15 minutes to cool down it works fine after that, any ideas guys. Thanks
  • pkbroilerpkbroiler Member Posts: 1
    I have a 2008 GMC 5.3 Auto ( 12,000 miles) with a front seal leaking. Took it to my dealer for a warranty repair. Seal was replaced and I had the truck back in a day. 3 to 4 days later the transmission just quit working going down the road :lemon: . No nothing. GM roadside assistance towed it to my dealer and they determined the torque converter and a pump needs to be replaced. How long does it take a dealer to get the parts and what may have happened? Transmission worked fine till the front seal was replaced. Dealers answers seem funky to me. I just need some thoughts and other ideas from people.
  • pondrockerpondrocker Member Posts: 18
    Hello, need some advice on a 2008 GMC 5.3 4 speed auto, 4x4 Z71 pkg. I am experiencing the same issue as user name Frock10 post # 332. My first incident happened at 3,000 miles, they replaced the 3-4 clutch pack with one that had tighter clearances per an internal bulliten that the mechanics are unable to see, sorta scary. 2 different gm service dept. referenced the internal bulliten, both said it wasnt the usual 2-3 clunk. The mechanic I chose has 35 years experience and I have used this service dept for years and never had an issue/ flawless service. After the repair the tranny was great, even better than before the fix probably due to tighter clearances. The fix failed 575 miles later, it is better due to different clearances but there non the less. Brought it back angry and concerned and they slapped a 2-3 cluck bullitin on it and told me I have a warranty just drive it. The truck is now black listed & I am being denied service if I even mention the word tranny. 4,100 miles on it now, cant even get it fixed myself without voiding the warranty. Something is fishy here and not right, any suggestions and solutions would be greatly appreciated. Also does anyone know how I can get in contact with user name fronk10?
  • byanceybyancey Member Posts: 3
    Just took my 2004 GMC 5.3/Z71 to trans shop because it was starting off in 3rd gear, and wouldn't downshift. Turn it off, restart, no problem. Showed trouble code (not sure which one), and mechanic said might be short in harness from computer/transmission. Checked solenoids and all were ok.
    Anyone else have this?
    BY
    My mistake, disregard my last post, I had'nt read some of the other posts regarding issues with the 07-08 GMC sierra/silverado before naeivly posting about my transmission issue. This might be the least of my worries as I too also have problems with the Advanced Fuel Management system, floor board vibrations, sporatic fuel milage, vibrations in steering column, louder exhaust, & (freaky/scary) engine surging all at 4,100 miles, other than that I love this truck. It sounds like regardless of the problem the end result from GM is the same, this is "normal" operation, maybe it really is normal? I thought I was nuts!, glad to hear I am not alone, it actually has made me feel better. My 1st new car experience lasted 3,000 miles, sad but true, live and learn. If anyone has a solution for all these issues I am all ears, sorry to sound so cynical!
  • joesmithjrjoesmithjr Member Posts: 1
    Hey I have a 2000 2500 with the 6.0 in it. Im not sure exactly wat the trans model is. but wat that problem is its not going into lock up anymore. A year ago I was going around 45-50 mph and the kid in the front decided to get something from the back sit. well wen he did he hit my shifter into reverse and all i heard were the tires scretching iit maybe stayed there for 2 seconds b4 i threw it into N. amazingly never had any problems with it at first after that. Until bout 3 months ago now it will not go into lock up over 40 mph. any ideas??
  • bomb_tech04bomb_tech04 Member Posts: 1
    i have a 95 sierra, 4l60e trans. that is really weak in reverse. it barely pulls the weight of the truck. i tried the (engine brake in 1st) and it doesnt brake, just acts like it rolls through, all gears foreward pull fine, just problems with reverse. i changed the fluid and filter, no shavings in pan, and the fluid level is spot on.
  • cac4cac4 Member Posts: 11
    Hello I have a 08 4x4 with the 4.8L, w/21k. For the second time in 2 wks the truck is in the dlr for a trans leak. The dealer is cool about it, but it is not acceptable. Yeah [non-permissible content removed] happens, but GM need to get there [non-permissible content removed] straight. I was going to buy a toyota, but I live in the metro det. area and decided to give them one more chance. May be the last. I will update this post with what seal was replaced the first time and what they say the second time. I just wanted to know if anyone else had any leak issues with their new trucks?????maybe a :lemon: ???
  • slayer10slayer10 Member Posts: 1
    hi guys i am new to the site so i hope that the info. that i submit is enough. its a iffy situation. sometimes while driving the trans. will shift into overdrive, but most of the time it will not. i have changed both the transmission module switch, and the safety neutral switch and it still does it. someone please help!
  • bumperdudebumperdude Member Posts: 19
    one of my service trucks had the same problem, i had it flushed and its been fine for 30k miles. give it a try. good luck.
  • carolinadebcarolinadeb Member Posts: 3
    I recently bought a 2005 2500HD with about 20,000 miles on it.
    Today, I noticed that the transmission temperature gauge was barely reading anything. This is while driving over an hour at 55 mph in 45 degree weather not towing anything. Is this normal? If not, what could be the problem? Should I be concerned?
  • rhtransrhtrans Member Posts: 84
    I assume this is a diesel or an 8 litre with an allison trans...if so yes, they have an excellent cooling system and that is very normal...will run very cool anyway especially at highway speeds where the torque converter is fully locked not allowing much heat to be generated. Most of the heat generated in an automatic trans is from torque converter stalling.
    Actually it is not a diesel. How do I find out if it is an 8 litre with an allison trans?
    I drove it today in 64 degree weather at varying speeds from 35 to 65 for about two hours and it registered 80.
  • ricky16ricky16 Member Posts: 10
    i put 2002 transfer case in my 2001 and now the speed meter does not work and will not shift gears.
  • jbh40jbh40 Member Posts: 5
    I Have A 1999 K1500 the transmission [4L60-E] Bangshifts from 1-2 & 2-3.I rebuilt the trans. with all new silenoids and torqueconverter,replaced speed sensor,coolant temp sensor. It still bangshifts after its warm.shifts fine when its cold. I can pull off the road and shut the truck off for just a few seconds, start back up and it will shift fine for a little while then right back to bang shifting.i noticed that when it does this it loses lockup aswell. Does anyone have an idea of what's wrong with this thing? PLEASE HELP!!!!
  • capurrocapurro Member Posts: 2
    I have a 97 gmc sierra with a 1st to 2nd bang while shifting.It has been doing this for years.Truck has 160,000 miles.This seems to happen when the truck is hot.I have been told by a friend to drive it until it breaks.I have also been told it is backlash from the rearend.The local mechanic scanned it (dont remember the code)and said there was a fix that gm had a wiring harness that would do something?Maybe a shift solonoid ? A shift servo ? I would take it to the local tranny shop but the guy is a crook,he bent me over my last experience with him.I was also told that doing a tranny service would make things worse.Can anybody out there shed some light on this problem.Thankyou.
    the 97 gmc sierra has a 5.3 engine 4x4, I dont know what tranny it has.
  • Smitty66Smitty66 Member Posts: 1
    Have 00 Silverado, appears to be slipping while in OD, @ hwy speed. does not do this in 3rd. checked around, possibly OD is going out. Recommend just replace tranny, repair would probably cost more.
  • WhiskeynickWhiskeynick Member Posts: 2
    Did replacing that solenoid fix it? I have a 97 Z71 That will only use 3rd and reverse. It has a po785 code. I replaced the 2-3 solenoid today and it did not make a difference.
    I have a similar problem with my 97 Z71. I drove it for 100 miles the other day got to stop sign heard a loud clunk, and the truck would only use 3rd. What did you find out about your problem?
  • levans498levans498 Member Posts: 2
    I have a 96 step side silver. with the 4L60E tranny. Well I want to get away from that tranny cause it is such an odd ball . I know it is the electronic tranny . But is there ANY WAY to go with a different tranny ? all I do is HWY driving . no pulling and such . O YEAH the tranny in the truck now is shot .
  • beaver_lf65beaver_lf65 Member Posts: 1
    i recently towed my car from wisconsin to missouri i got most of the way here and the trans started to make noise so i checked and it was out of fluid.. it appeared to come out of the transfer case main seal is but i didn't think that they shared fluid do they? also now my second gear isn't working and i think also 4th gear. will a flush help anything or should i just rebuild the trans?
