Chevy Silverado and GMC Sierra Transmission Problems
avanger9220
Member Posts: 1
I have a 2001 chevy silverado 1500 5.3l v8. I am wondering if it anyone has any information on what it takes to convert it from a automatic transmissio to a manual transmission. I love my truck but i dislike the fact that chevy wouldn't offer a manual as a option on this truck.
See also: 10 Most Common Transmission Problems
thanks for any help in advance.
Intermittent problems are the hardest to diagnose and evidently, these trucks are full of intermittent problems as identified in the Silverado/Sierra problems and solutions.....
Other than the obvious, what does the HOT TRANSMISSION error message mean from the D.I.C.?
Dave
I would say that the towing temp would be in the correct range, depending on the weight you are towing and the type terrain.
Do you just tow intermittently or most of the time?
What weight are you towing and in what sort of terrain and open higway or in city traffic?
Just to be on the safe side I would go ahead and install a bigger after-market cooler.
kcram - Pickups Host
Yep as in general motors
Problem: Truck is not shifting into reverse, and makes and winding noise in reverse. When driving, shifting from 1st to 2nd I have to let off the gas to make it shift. Other gears will shift on their own but with a slight delay. Thanks
I have recently been noticing a possible problem with my 2003 Silverado (automatic transmission/4 wheel drive system) Z-71. The problem is kind of weird in that the transmission seems to be working harder then normal under normal operating conditions. The truck only has 40,000 miles on it and has really only been used on the highway. It almost seems that the truck isn't driving as smoothly as it once did. Almost as if the front end is ready to lock into 4 wheel drive when only 2 wheel drive is selected. I also had one instance where the transmission seemed to slip back into neutral. I even had a passenger ask if I was dragging something the other day. I have noticed some slight changes in the handling characteristics of this vehicle but nothing that I thought was serious. Has anyone experienced anything like this?
Thanks for any assistence.
I have a 1996 Chevy Silverado pickup truck. It has a automatic overdrive transmission. I recently had the transmission filter replaced and put about 5 quarts of dexron 3 automatic transmission fluid in it. So I thought that it would shift right but I was wrong. It shifts into first at about 10 mph but when it goes to shift into second (which is suppose to shift at about 30 mph.) it doesn't shift i even had it up to 35-40 mph I would appreciate any advice that anyone can give to me.
Now when I shift into 2nd gear it makes a slipping-whining noise, I dont know if I have a clutch problem or a tranny problem. The truck is low geared, so I mostly start out in 2nd gear. I have not noticed any problem in any other gears.
The second problem is that the fuel pump will not always shut off when the truck is shut off and runs the battery down if I dont dis-connect it each night. Any help would be appreciated, thanks R.R.
Are there any other problems you are having with this truck? I would like to know!
I own a 1999 Silverado Z-71 4x4 bought used, and loved it.
Now after 77350miles transmission went,no kind of warning just broke down,managed to get to Clinton Chevy Dealer and was told I need a new trans. They put a new rebuilt in truck gave me 75,000 mile 3year warranty for $3420.00 bucks well the truck made it to 99,925 thats only 22,925 miles but as luck would have it I was over the 3-Year limit by 63Days and was sent on my way Busted Truck and all. So much for customer service. Now before the tranny went the 2nd time the Truck needed a new "REAR" $1200 bucks and lets not forget the Brake lines along the frame rail blew a hole and was unable to stop. Lesson= I WILL NEVER OWN CHEVY TRUCK WHILE I AM ON THIS PLANET! GOOD LUCK TOO YOU A.R.BLEW
waring out any suggestions.
...........you could try singing to yourself.
kidding. i'm trying to laugh. backed out of my parking spot at work today put my 02 silverado in drive and BAM!!
had forward gears but man did they whine. pulled into a gas station for a look-see and found out i no longer had reverse. towed to a tranmission shop for the good news. "busted sun gear,common problem".i guess i faired a little better than some of you guys. i've got 95k miles on her and he says about 14-1500 total rebuild.
U2105 CAN Bus Error ECM
P0700 is Transmission Control System Malfunction
Sounds like your Allison has a computer glitch. Dealer will have to diagnose that.
I have a 4l60-E transmission with no reverse, It had reverse when I took the trans out to replace a broken pump. The truck is locked down and will not move even in neutral. It shifts and everything in other gears, what could the problem be? any clues?
He said next time it did this, to stop, turn motor off, then start it up again and see if transmission shifts properly. If not, the problem is in the shift valves. My transmission did not correct itself.
On this forum an Chevrolet Service Tech said to try LUBEGARD in the transmission and many times it will free the shift valves. I did this: http://www.lubegard.com/automotive/trans_atf_mv.html
I have driven the truck over 300 miles and it has shifted perfect, even shifted out of OD on a hill and back into OD once I was on a level road.
If I had any money I would invest in this company.
Just my opinion.
I've noticed it shifts kinda rough at low speeds or when its downshifting from first to second.
Parking lots are where I notice this most of the time should I be worried about it or has anyone else noticed this?
problem that GM is trying to avoid. Should we join forces and contact the consumer protection agency or something?
Miles? 2 or 4wd? auto or stick??????//
Take it to another dealer...............
