Buying a used 5 Series
bmvmanbmvman Member Posts: 2
I have an opportunity to buy a 1993 535i Saloon, and it is in terrific condition inside and out. Seems like a great price at $4,500 with 120,000 miles. The owner is an associate of mine and I'm certain the mileage is orignal - no new engines along the way etc.
The car has a rough idle problem - suddenly, says the current owner after installing a used cold air or mass air flow sensor. He thinks it might simply be a vacuum leak in the system, but I'm wondering if this is a typical problem for this 2.5L V6? Also, with good care, how many miles can you get out of this engine? Thanks in advance.
Dave
«1345678
    div2div2 Member Posts: 2,580
    First off, let's get one thing straight- a 535i has a 3.5 liter inline six. There are a number of faults that can cause a bad idle inthese cars, and most of the fixes are fairly simple and inexpensive. That said, the only way to know for sure is to have an experienced BMW tech examine the car. I'd suggest a pre-purchase inspection prior to buying the car. As for engine longevity, BMW's M30 family is extremely durable. With regular maintenance you should get at least 300,000 miles out of that engine.
    Thanks for the correction. The car is a 525i. I had the right engine, but the wrong model number.
    This car rides and drives great, but a lumpy idle. The original owner says he was trying to fix a vacuum leak. Replaced a hose, and then the idle problem. Thanks again for your help.
    bmvman
    The 2.5 is a sweet engine as well, and it requires less maintenance than the 3.5. I'd still want the idle problem sorted before Ipurchased it.
    fos41fos41 Member Posts: 1
    i have an older 535 i and was wondering if anyone has ever used a reman. drive shaft/ i know new shaft will workout fine. the price difference of or a reman. shaft is more attractive ,but have had problems with some products that are reman. anyone have any feed back on this thanks donnie
    525lover525lover Member Posts: 1
    I recently bought a 95 525i and for the first 2 months it drove well.within the last month and a half though,whenever i turn to the right at speeds of 20-25mph there is really bad vibration.could this be ball joint failure or something else?
    I'd look at the ball joints, control arm bushings, and tie rod ends.
    djjaydjjay Member Posts: 1
    I am looking at 3 different older 5 Series cars to purchase and would like some wisdom to narrow it down (& negotiating info). Mileage is approx. & price is asking.
    1988 535iT, $3,500, 80k on new eng/trans
    1990 535i, $2,500, 207k
    1991 525i, $4,500, 120k plus
    The 88 & 91 both come from an auto shop specializing in BMW repairs/restoration and so will be thoroughly tuned in and out with a 6 month warranty.
    On the other hand, the 90 is a cash as is sale. The only problems I've noticed in a brief inspection are power lock issues (looks like the trunk lock was broken into at some point causing a lock/unlock action or just staying locked, the rear pass lock isn't activated by power it seems) and the cabin heat/cool fan doesn't engage. One more thing, when I opened the coolant resvoir it looked like there was some "glitter" in the fluid, is this anything to be concerned over?
    Any wisdom is greatly appreciated. Having owned old 5 Series' (86, 87, & 88 525e) I know they are dependable joys to drive so just want to get a car to last 3 to 5 years with little maintenance at a good price.
    bigbiz1bigbiz1 Member Posts: 2
    I am thinking of purchasing 1996-1999 528. I have no previous experience with these cars so I am wondering if anyone who owns one can give me some info.....reliability, problems, etc. Thanks
    Frank G
    NJ
    manybmwsmanybmws Member Posts: 347
    I owned a '99 for 4 years and 72K miles. Only out-of-pocket expenses were front brakes at 60K miles for $750.
    Thanks........just looking at finances as I heard these cars can be quite expensive
    Frank
    Get a car that has reasonable or is under mileage for its age - but more importantly has been nurtured by a "car guy" :)
    pearlpearl Member Posts: 336
    I have one of the first E39s (528)delivered in the U.S. (June 96 as a 1997 model). The car has premium pkg and manual transmission and has just crossed 150K miles. I get about 24mpg in town and nearly 30 in highway cruising and the car has never burned a drop of oil. Other than "normal" replacement items (belts, hoses, brake pads, coolant, oil, filters, tune-up items, etc), the only trouble I have had with the car is a leaking power steering hose/fittings, a broken fan-belt tensioner, a leaking transmission seal, and a bad front strut (replaced both front struts). The clutch is a little weak at this stage and my remote key fob won't lock the doors any more (but will open them). I have taken good care of this car and would say this is the best car I have ever owned. In early 06 I had the new car bug and drove many LPS models (GS, RL, M, new E60, STS, etc) but did not find any of them that made me want to trade my E39 - for example, none were as quiet as mine and only the E60 handled as well. No doubt others have had similar experiences with this model BMW as me, and no doubt others have had worse. I think you need to see if you can get the history on the cars you are looking at, but overall, I have loved my car and wish you success if you buy one.
    gkg680gkg680 Member Posts: 25
    If anyone would care to share their thoughts with me, I'd be grateful. I have an opportunity to buy a 1998 528i with 2200 miles on it. It's showroom new, been sitting for years in a heated, secure garage. Recently, all the fluids were replaced, I'm not sure about the hoses and belts, and the battery needs a charge, but it's new also.
    Blue Book trade-in value is $13,000, private party trade value is $15K, and dealership retail is $17,000.
    It's out of warranty, of course, but it's literally a new car, and I've known the owner long before she bought it new in 1998.
    Does anyone have any thoughts as to what might be a fair offer for such a car? Even though it's out of warranty, it seems like a great opportunity, however, I've never owned a BMW and have heard countless horror stories about the cost of maintenance and repairs.
    If anyone wanted to go to the trouble of sharing helpful comments, I'd welcome them. Sincere thanks.
    I'm assuming that includes brake fluid, coolant, transmission fluid, and final drive oil- using BMW approved fluids/lubricants?
    I wouldn't pay over $15K; why pay silly money for very low miles on a car you are going to drive? It's not like an E39 528i is collectable.
    Mostly false and passed on second or third hand by the misinformed, the jealous, or just plain fools. I ran a 1997 5er to over 130K and the maintenance/repair costs averaged @$80/month. The upkeep costs on my 1995 3er track rat average @$40/month. Join BMW CCA, find a good independent BMW tech(or better yet, buy the Bentley E39 Manual and learn to do the simple maintenance yourself), and you'll be fine.
    joyrider147joyrider147 Member Posts: 69
    I have an 87 528e. All the instrumentation on the gauge cluster doesn't work, nor does the power seats. No tach, speedometer, fuel gauge, heat temp, or SI level, but the cluster gear selector for the automatic trans. lights up. It doesn't look like these items were touched or disassembled, but the car is so original that it still has the original factory crappy plastic mini-fuses in the car's fuse box. Would all of these items work if the fuses were changed out with new metal ones? Can anyone tell me the most common problems with this model BMW?
    Also, I am looking for several body parts, exterior parts, and interior parts for this car.
    If anyone has an e28 parts car available and can give me a good deal on these parts, can they email me with prices for these parts:
    * Both fog lights and front yellow turn signals
    * Lower front metal valence for 528e and/or front spoiler for 533i or 535i or M5.
    * Driver's side front seat, black leather in excellent condition and rear magazine holding net.
    * fully functioning overhead BMW lights diagnostic computer with "check" button that doesn't fall out.
    * black leather automatic gear shifter
    * excellent condition black body trim and brackets mounted on body by rear driver side passenger door
    * black dashboard trim grill holding cigarette lighter and other accesssories in excellent condition.
    * headlight/ foglight switch mounting trim
    * original 528e BMW car phone with mounting brackets and connecting phone cable running to trunk, in excellent condition.
    * black trim surrounding radio on dashboard in excellent condition.
    * black trim holding e-brake and seat switches, in excellent condition.
    * floor mats with "BMW" etched on them in black, excellent condition.
    Also, i have an 86 325es. When the fan belt slips, does that affect the timing for the valves, essentially damaging the engine and making it burn oil?
    bfletchbfletch Member Posts: 4
    Hi, I'm currently in research mode, however I plan to buy one soon. A few questions:
    Sports package: I'm a mellow driver and looking more for comfort than race car performance. I heard the seats, and even the suspension is fairly ridgid with the sports package? Accurate?
    Premium package; still not sure what you get with this. Can anyone shed some light on this for me.
    Blue exterior; I have been cruising web sites and do not recall seeing this color. Does it exist in the 525 or 30?
    Are 16 in wheels standard?
    Roof rack; I will be carrying around surfboards periodically. Has anyone used the 725 tower from Thule with these? Secure fit?
    Regards, Bill in So-Cal
    dngarydngary Member Posts: 3
    I recently fell in love with the 530i during a test drive. I am looking to purchase a 2004 model with about 41,000 miles. It is pre-certified from a BMW dealership, so the limited extended warranty will last on this car for 3 more years from its original date of service. Price out the door will be about $36,500. I am currently a Buick Regal owner. I'm very worried that the cost of maintenance will be quite expensive. I drive about 12,000 miles per year. The dealership has a policy for purchase ($1,400) to pay for all scheduled maintenance costs for 2 years after the original warrant ends. Is it worth it? Can someone calm me down or am I right to be nervous? :confuse:
    As I've repeated umpteen times on these boards:
    Relax! Most of the "horribly expensive" BMW maintenance/repair stories are spread by people who heard that his best friend's sister's college roommate knew a guy who had a dentist whose broker told him that it cost his second cousin $3000 to change the oil on his 318i. Yes there ARE some dealers and independents who grossly overcharge their customers. Having said all that, there are good dealers and independents out there who charge fair prices and offer a BMW Car Club discount.
    Finally, I ran a 1997 528iA to over 130K miles and my service and repair costs averaged $90 per month. I only sold it was because my wife wanted an X3. I needed to keep my US built Wrangler for political reasons- otherwise I would have claimed the 5er for my commuter sled. The current owner now has 145K on the car and she still loves it. Right now I'm thinking about buying a 2001 M5, and its CPO warranty runs out in April. No way am I going to buy any "added protection".
    Thank you for the BMW "therapy" session response. I would greatly appreciate if you will indulge me for one more session. I've noticed that on BMWs and Volvos, there appears to be an accumulation of black brake dust on the wheels. I've never experienced that on my Buick or on any other American car I've owned. Why does it happen, how quickly does it accumulate, and is it easy to remove?
    Thank you so much again for your advice.
    No problem! I'm glad to help.
    If you continue to use the original equipment pads you will find that brake dust accumulations will be pretty much unavoidable. There are dust shields available that fit between the wheels and the brakes, but they can interfere with brake cooling. As a result, I don't reccommend them- and neither does BMW. The best solution to the problem is to fit Axxis Deluxe Plus pads. More information can be found here.
    You're welcome. Let me know if you have any other questions. BMWs have been my hobby for over 25 years, and I always enjoy talking about them.
    I'm glad you enjoy talking about BMWs. I tend to research any purchase in great detail. This will be the most expensive car I've ever considered and I appreciate your willingness to share your expertise.
    As you can surmise, I am a little hesitant, not so much because the 5 series isn't a wonderful car, but partly because it seems so spartan in comparison with other cars in the same price range. Even the radio in my Buick sounds better. (Well, it does.)(My frame of reference is about $36,000 out the door price for a used 530i with 42,000 miles).
    On another note, what do you think of the "dreaded" I Drive control?
    Please let me know when I'm getting on your nerves with all these questions. I especially do not want to spoil the holiday season for you!
    Signed,
    Still a bit nervous (now that I know I have to clean my rims of black break dust.)
    So do I ;)
    I think you will find that BMW places a great deal of emphasis on the overall driving experience; a BMW embodies a lot of impressive engineering- but most of it is under the skin.
    I've never been too impressed with the sound systems in the newer BMWs. As a matter of fact, very few of them sound as good as the OEM system in my 1995 318ti track rat. Go figure. Does the 5er you are considering have the Logic7 upgrade? It supposedly sounds pretty decent.
    I drove a 645Ci with iDrive for a couple of weeks last summer, and after a few days I became pretty adept at using it. Some people love it, others hate it. I think it is a flawed interface, but it wouldn't keep me from buying a BMW I really liked.
    Going back to your original post, there is some things that I think you should know about how BMW are serviced. In most cases, the best way to keep maintenance costs reasonable is to find a GOOD independent BMW tech; you will save 25%-50% on service compared to the dealer. That said, there are some excellent dealers that offer excellent service at reasonable prices. All modern BMWs use a Service Interval Indicator to inform the driver when routine maintenance is required. On a 2004 5er an Oil Service will be called for at @15,000 miles. To be honest, I don't like to run oil that long, so I perform an oil change at 7,500 miles. I also use Mobil 1 0W-40 synthetic, which I prefer to the BMW-branded Castrol synthetic. It's a VERY easy DIY procedure and it costs me less than $45. The minor service(Inspection I) will come up at 30,000 miles and the major service(Inspection II) at 60,000 miles. An Oil Service will cost $60-$150, an Inspection I $150-$300, and an Inspection II $450-$800. Coolant must be changed every three years(using BMW Coolant ONLY), while the DOT4 brake fluid gets flushed every two years. BMW also calls for changing the ATF at 100,000 miles, although I would have the procedure performed every 50,000 miles- and I'd have the differential oil changed at the same time.
    Finally, join the BMW Car Club of America. Many dealers and independent shops offer CCA members 10%-25% discounts on parts and/or labor.
    Ask away! It is not a problem!
    Ok Bimerfiles, looking at purchasing a 540i 2001-2003 with the sport package and 6MT. Any thoughts, ideas, suggestions also anything to look for on these cars?
    Debating between an 05/06 GTO and an 01/03 540i
    -mike
    taxesquiretaxesquire Member Posts: 681
    Hi, I'm also perusing this site to find out about the reality/myths of how well BMWs hold up - particularly post-2000 3 & 5-series'. Your comment, "Finally, I ran a 1997 528iA to over 130K miles and my service and repair costs averaged $90 per month" doesn't sound too encouraging to me. $90/month = $1,080/year.
    Please comment :confuse:
    Is it bad form to reply to my own post? :blush: I reread your post to make usre I understood it correctly, and I guess $90/mo is fine considering it's an older car with (presumably) no finance payments being made. Still, $1,000/yr on repairs is pretty significant.
    dbcafydbcafy Member Posts: 8
    Comparing a 540 against GTO (Pontiac?) is like comparing Apples and Oranges.
    BMW - The ultimate driving machine, will put a smile on your face everytime you sit behind the steering wheel.
    The GTO - a kid's car.
    Assuming you get a Bimmer in good condition, this car will have a higher resale value and will last longer than the GTO.
    Then again, I might be biased. I do own a 2003 540 with the Sports Package.
    Dave
    Actually the GTO demographic is 28-45.
    Heck the BMW 540i 2001-2003 is more expensive used than a new GTO. Biggest thing I'm worried about is out-warranty repairs, I hear on BMWs they can be quite costly.
    -mike
    tdb99tdb99 Member Posts: 5
    Wanted to know if anyone can share their ownership experiences with this vehicle, am considering to purchase. Thks. :D
    natedog03natedog03 Member Posts: 7
    I just bought a 2003 540I M sport with steptronic. It's the most amazing car I have ever driven, Black on Black with everthing from PDC to NAV and DSP stereo. I researched it intensley and I found BMW keeps great records.
    First I suggest CAFFAXing it, its $25 for a month long membership to run VINs, then contact BMW USA customer service, # is on the website. They will give you the selling dealership and you can confirm options on the vehicle to make sure nothing was altered. Then call the service dept of the original dealer, explain you are going to buy a used vehicle and BMW gave you the info, anytime the vehicle was serviced at any dealership a code is entered. The service tech ran through every code with me to make sure the vehicle was clean. I even found out it had the CPO & maintaince till 100K.
    Just to add...... the most expensive service on the 01-03 5 series will be the SL2 60K mile service about $400 for the V6, $700 V8 you can shop around for BMW dealer specials and before 100K, you'll need a brake job, between $600 and $1200, depending your sport package options, size, etc. But if you get the maintaince done as scheduled, the driving experience outweighs the cost.
    shiposhipo Member Posts: 9,148
    Last time I checked, BMW has never built a V6 engine. :blush: V8s? Yes, absolutely. I6s? Yes, and have for MANY years. V6s? Not yet, and hopefully never will. :shades:
    Regarding the other items of maintenance that you listed, the E39 530i and 540i have the same brakes, and so I can tell you first hand that they are a piece of cake to do yourself. I did mine with new pads, rotors and sensors, and the whole thing cost me just over $260 for all four wheels. Said another way, these brakes are so easy to do that I can do the job quicker in my driveway than the time it would take to drive to my dealership and back. ;-)
    Best Regards,
    Shipo
    I've only had the older 7's V8, so my experience with the 6 is limited. You are correct, I apologize. If you can do the brake job in your driveway then you should. More power to you. I would never buy a used car from someone that didn't have the service records. When making any kind of investment dealership service offers some safeguards, and at least a papertrail in your research, sometimes even a warranty.
    Hmmm, I guess we see things a bit differently. For required maintenance (i.e. oil and filter changes, brake and cooling system flushes and the first 30K scheduled service), I have no problem using the dealer. That said, even though brake jobs are effectively part of the "free maintenance" component of new BMWs, I would never use the dealer for those parts. Why? Because parts that offer superior performance (i.e. lower dust or better stopping power/fade resistance or even a little of both) are available in the aftermarket, parts that your dealer would never use.
    With the above said, once the warranty period is over, I would never buy an extended warranty or an extended maintenance plan. I would instead use a high quality independent shop for the messy bits, and do the rest myself. Oh, and of course keeping the necessary records all along, regardless of who performed the work.
    FWIW, following that policy with my 2002 530i, I changed my own oil at 7,500, 22,500 and 37,500 (mid-term oil changes) with Mobil 1 0W-40 and of course used a factory filter. I also changed out my brake pads with PBR/Axxis Deluxe Plus pads that generate virtually no dust and were able to keep my beautiful factory Style 42 two-piece wheels nice and squeaky clean. When lease turn-in time came, several folks here at Edmunds were actually interested in getting to my car before BMW-FS did. Why? Because of the work that I had personally performed on the car. Go figure.
    Best Regards,
    Shipo
    That's cool bud. Did you add anything to it Dinan? AC Schnitzer?
    Nope, I don't like modded cars. Hmmm, maybe not quite correct. I suppose if I was to keep a car to say, over 100,000 miles, I might be tempted to breathe on it a bit, however, that really isn't my style. Pretty much bone stock or I don't want it.
    Just as my 530i was heading back to BMW at lease end, my annual driving profile changed dramatically. I went from an annual average of about 14,000 miles per year, an average that I sustained for twenty years, to more than 30,000 miles per year. Being very unsure of how long I could sustain that kind of mileage and what might come next, I opted to not replace my wonderful 5er, and instead opted to drive our spare car, an old Home Depot hack in the form of a 1998 Dodge Grand Caravan. :P
    Fifty thousand miles in twenty months later, it looks like this current situation is workable, however, come this September my annual mileage rate is going to get bumped again to more than 40,000. Needless to say, racking up that kind of mileage in a new BMW is simply unreasonable. Looking at my options, I'm finding low mileage (60K-80K) pristine 2000 vintage 528is (that's plural not an "is" model), with PP, SP, "M" Seats and a 5-Speed for between $15,000 and $17,000 (asking price). I'm thinking that such a car would be good for another 200,000 miles with just reasonable maintenance.
    Hmmm, buy a new 535i for say $60,000 and drive it 160,000 miles in four years. Resale value? Not pretty. Buy a seven year old 528i for $16,000 and take it up to say 230,000 miles. Resale value? Who cares. ;-)
    So, I told you that so that I could tell you this. I've looked at quite a few cars since I started this shopping process, and when I see a car that has been modified even a little, I move on to the next car. My threshold for modifications? Upgraded brakes and clutch? Yup, bring them on. Wheels and tires? Unless they are the factory size, pass. Body panels? Not a chance. Engine mods? Can't run away fast enough.
    Best Regards,
    Shipo
    Dude, I already have an 03 540, I just asked if there were mods on your 530 b/c you said you did brakes in your driveway??? Its a 530, there's alot around I don't care about your driving habits, this is a forum about someone buying a used BMW, not you.
    Best Regards,
    ND
    Lose the attitude dude. You asked a question and I answered it in a complete manner.
    FWIW, I am in the market for a used 5-Series, one that is bone stock.
    Best Regards,
    Shipo
    xwildmanxwildman Member Posts: 2
    I am looking at some 2001 5 spoke X5 wheels. I believe they are 17" x 7.5" 5 lug...
    Will they have the correct offset / close enough offset?
    Scooter
    I could be wrong, however, I don't believe that the X5 uses the same offset and such as does the E39 5-Series.
    Best Regards,
    Shipo
    wbb56wbb56 Member Posts: 45
    I've narrowed my new car choices to three: 2005 CPO BMW 525i; '07 Toyota Avalon Touring; '07 Lincoln MKZ AWD.
    I like them all but have always been partial to BMWs. My concerns: The '05 525i has 45k+ miles (Seems like a lot in only 2 years.)-and in comparison to the other two, seems underpowered.
    The car is well equipped-Premium package, Navigation, Parking sensors, etc.. but the dealer is asking fairly high price-$39,995.
    Questions: Any advice about buying the '05 w/45k miles? It is CPO--with the warranty extended to 100,000 miles. I think $35k is about right for the 525i-is that reasonable? (The MKZ and Avalon are both 35K fuly loaded). Is there a big enough difference in the 530i to pay the higher price?
    I've owned (3) previous BMWs--but it's been 15+ years since my last 3-series. So I'm not sure about service, warranties, etc..
    Any advice would be greatly appreciated!
    azdinoazdino Member Posts: 9
    Boy do I have advice. Simply said, move on. You would be paying for a "newer" car with high miles. Cars depreciate by age & mileage. Go look for a 3 1/2 -->4 year old lower milaeage 5xx. My son just acquired a 2003? 530 with 44K miles and the remaining warranty. Quite loaded - sport & comfort? groups. He paid $24,000 + T & L here in Phoenix. He spent about 45 days looking around. He is a "frugal" engineer. AZDINO
    woodywwwoodyww Member Posts: 1,806
    Paying $35-$39K for an '05 525i with 45k miles sounds nuts to me. You can buy or lease some really nice brand new cars for that much, or less.
    I'd say, either just buy or lease a new bmw, or go back a few model years and save a ton of $$. You're not "saving" enough (if anything) to make it worthwhile to buy a miled-up '05, IMO.
    PS: Is the avalon new? If you like it equally, I assume it will treat you much more kindly with depreciation, & would be nice to have Brand New "everything".....
    manhattancarmanhattancar Member Posts: 1
    I wanted some of the opinions of the very experienced forum members here. I'm currently leasing a 2004 BMW 530i and my lease is up this summer. I've barely used it (total of $12K miles so far). Apart from some idrive glitches (to be expected i imagine!), the car has given me no problems.
    The residual value on the lease is about $35K. It's loaded with SP, PP, Xenon, Auto (original MSRP was $55k).
    Question is: should I buy this car knowing that i only plan on driving 5-6K miles per year max? If I keep it for 5 years, how much do you think it will be worth 5 years from now, assuming I drive 5K miles/yr?
    Finally, i've seen different responses, but it seems most people on this forum don't think its worth paying for extended maintenance. Would you agree?
    Thanks for all your help.
    circlewcirclew Member Posts: 8,666
    I guess the kid's age bracket changed. The biggest difference is the resale value. That's where you'll loose. CPO can limit these costs.
    OW
    ttb69ttb69 Member Posts: 1
    I am thinking of purchasing a 2001 530i with 50,000 miles. I have never owned a BMW before. Anything that I should take into consideration such as engine, suspension or electronics quirks?
    kamdogkamdog Member Posts: 28
    My daughter is in the business, and one of the dealerships in her network is BMW. I can get a 2006 CPO 530i with steptronic, cold weather, sound, and luxury packages, and nav for about 41000. Im sure this is a good deal financially, but is there something I should look for? I have always wanted a BMW, but racked up over 20K a year commuting into the ghetto, so never could buy one. I am now retired, and this will be my keeper car. What should I look for?
    carjaxcarjax Member Posts: 2
    I am in the market for a used (but not too used) 530 or 545. Like everyone else, I'm looking for the most bang for the buck, but I am also thinking ahead to re-sale value (I have a bad habit of not keeping cars more than 3 years). My budget is about $30k - $35k. I'd prefer not to go older than a 2004 model (forgive me, but I actually like the Bangle style). I have my eye on a 2004 545i (51k mi., PP, SP, CP, prem. audio; asking $34k) and a 2005 530i (31k mi., no options; asking $34k). My heart (and right foot) are telling me to go for the 545, with 325 hp and lots of extras. My conscience is telling me I don't need the "extras" or the bigger engine and to just get the 1-year "newer" vehicle with 20k less miles. Who do I listen to?
    carguy70carguy70 Member Posts: 10
    The 530 will give you plenty of bang for the buck over the OUT OF WARRANTY 545. The 3.0 I6 is very smooth and has plenty of torque. These cars are very particular when it comes to maintenance and you will save a fortune and have a lot more peace of mind driving a car with some warranty left. You can call a dealer ahead of time with the VIN# to confirm how much warranty is truly left.
    Good advice. Thanks!
    Before asking my big question, I need to get this off my chest and just wondering: WHY DO MANY CAR MANUFACTURERS MAKE AUTOMATIC TRANSMISSION CARS THAT SUCK, BREAK DOWN QUICKLY, AND BURN GAS RAPIDLY BUT THEY RARELY MAKE NICE STICK SHIFT CARS THAT GO FAST, LAST LONGER, AND ARE MORE FUEL EFFICIENT?
    I was looking at several cars available; a 1993 325is Stick Shift Coupe, a 1995 740i or a 1990 750iL witha v12 and low mileage, and a nice 1994 530i or 540i with an automatic.
    First, I was looking for a BMW with good condition and at a low price but runs great because soo I'm looking to strip the car and rebuild it with some high performance parts. As for my driving needs, I need a car which might have a manual transmission that would react better in a city environment as opposed to an automatic. Don't get me wrong, I can take an automatic as well, but it must shift nicely in stop and go traffic. Also, I need a car which has nice horsepower and get up and go, like a v8 or v12. But, since the car's being used in city driving, I need overall fuel efficiency in a car.
    Let's look at the 325is. It is stick shift, which I might like since I don't like automatics. But overall, what would be good for city and highway driving, as well as Motorsport driving? Auto or stick? Stick has 5 gears which can be selected rapidly at lower RPMs for increased acceleration where as autos have 4 and are slower at shifting with power reduction. The problem is this car has a inline 6 which might have nice power, but may have struggling against cars with 8s or 12s and it might not catch up to an M3. Also, the car is small and agile, which is great for cornering and grip and reduced weight for faster acceleration, but it is only a small 2 door car. And, it weighs just as much as a 5 series or a 7 series and is only limited to a 6.
    Next, the 1994 530i. It has a 3.0 V8 which is a peppy, fuel efficient v8, it is a 4 door sedan with a pretty roomy trunk, and is reminiscent of an M5. The downside is it is an automatic, it is a bit heavier than a 3 series which may reduce acceleration, grip, and cornering. Also, I don't know how good a mini-v8 performs it Motorsporting.
    A 540i stick shift is a M5 knock off, but is very rare, pretty high in price, and are more available in auto than it is in manual.
    Third car is a 1995 740i. Newer model car, but may cost more in parts and probably spend more in replacement parts than high performance upgrades. Heavier car, bigger car for even more reduced acceleration, grip, and cornering. And its an automatic.
    Lastly, a 1990 750iL. Again, v12 excellent for high speed, acceleration is no problem for a v12, extremely roomy interior and trunk, but it is an automatic and a v12 will cost astoundingly more than its 740 counterpart and may still need more parts even after repairs.
    I'm leaning towards the 530i since it has less drawbacks, but should I go for it since 530i stick shifts are rare? Or should I do a tranny swap out and end up with all advantages and no drawbacks? Or should I enjoy it as is?
