Dodge Ram Lighting and Electrical Problems
1910111214
  • spanky_mcpspanky_mcp Posts: 6
    I have a 2004 Dodge Ram 1500 5.7L 4x4.
    I was out yesterday and someone pulled up next to me and told me that all three of my brake lights were not functioning.
    I replaced my brake light switch (easy fix) and checked all of my fuses with a fuse tester and still the lights don't work.
    Can anyone help?
    I have a 2004 Dodge Ram 1500 5.7 4x4.
    The interior/dome lights work fine when I open either of the passenger side doors, but do not come on at all when opening the driver's side doors.
    Any ideas?
  • dh56dh56 Posts: 7
    i have had this issue but, its not too harmful chances are that you will need a new alternator in the near future.
  • dh56dh56 Posts: 7
    ok guys, i was just speeking with a dodge tech and he said that if your instrument cluster has fouled up then the cluster control modual needs to be replaced and then your truck needs to be REFLASHED meening that it needs to be reprogramed. good luck
  • dgegirl84dgegirl84 Posts: 3
    only my rear left blinker works. my right low beam works. when i turn my high beams on only the left highbeam works. i have no 4 ways. and it only does it when it rains. my blinkers will blink inside the truck fast but not outside and my four ways only blink inside not outside. sometimes the truck will tell me that there is low washer fluid when it is full. please someone help me.....i checked all the bulbs individually and they all work....im guessing that theres a short or switch that i dont know about and/or havent found yet.
  • sundance69sundance69 Posts: 1
    My '02 Dodge Ram 1500 is doing the exact same thing, only it doesn't have to be raining, it does it constantly. Did you ever find out what was wrong?
  • djmacdjmac Posts: 1
    My problem is that the brake light are on all the time the engine is running. I changed the plunger switch under the dash near the steering column but they are still on. Any ideas?
  • indianmanindianman Posts: 1
    check the connection.. where you would hook up trailer,(rear of truck) mine was melted together , where the " Y " is .... take off tape . look good .. inspect line from front of cab to back or cut brakewire from front and run new line to the back ( try once you cut line turn on truck to see if brake lite goes on ) if its on its fuse together . some where from firewall to rear of truck good luck !
  • My 04 ram is doing the same exact thing. No turn signals, except passenger side back. No brake or turn on drivers back. No turn signals on from, either side. One head light on dims on passenger side and one on high beams on driver side. I have all my running lights. Just happened all of a sudden. Checked bulbs and all check well. I would be greatfull for any help......
  • arnie59arnie59 Posts: 2
    Sitting in driveway dogs barking at truck.... seems the entire rear end of the brake light
    system lights up/stays on, for no apparent reason? watched it and in a few seconds it flickered then
    went out by itself. occurs both with trailer attached and by itself.... No electrical problems
    since purchased 22000 miles ago.
    edited July 2011
    truck sitting in the rain today and I watched the third brake light and the
    right rear tail light on the attached trailer come on for no reason at all?
    seems if it were the brake switch all the lights on that circuit would flicker
    at the same time but they don't. 1. I hope the battery doesn't run down,
    2. hopefully the truck won't go up in flames from a short under the dash or
    where ever the problem is?
  • 03ram103ram1 Posts: 1
    i am having the same issue with my truck what did you do to fix it
  • i have the same exact problem that dgegirl84 has with her 2002 dodge if someone knows whats causing this i sure could use the help in fixing this problem
  • did you ever get an answer on the fix for the lights? same year same problem here!
  • Jason,
    I have a 2002 and it is doing the same thing. Did you get your problem fixed and if yes what was it? Ive already replaced fuses, headlight switch and checked everything else but no luck with the problem.
    Chuck
  • I have a lighting issue with my 03 dodge 1500 hemi same thing left side doesn't work bulbs are all fine the turn signal comes on and no head light still. do you have an answer. tonyleemia@yahoo.com email as well.
  • jeffl6jeffl6 Posts: 1
    I have a 2009 Ram 1500 with factory tow package. The marker lights on the trailer will go out while driving. Lights will go out after half mile to 30 miles of driving but the trailer brake/turn lights and electric brakes work fine. This does not happen every time though. After you stop and restart the truck, trailer lights will work again. I have replaced trailer 7 pin plug and cable and all trailer lights work. Any help would be great.
  • I have finally figured out my electrical gremlin issue with my 2004 Ram 2500 5.7l HEMI. The light going bright to dim and on occasion the headlights(only) would go ot so I decided to remove the entire dash from the truck and chase every wire. While I was removing the instrument cluster I observed that one of the plugs was partially unplugged. I plugged it in all the way until I heard and felt it lock into place. I then started the vehicle and checked the lights and they were all working perfectly. It has been over a week now and my old problems have not returned at all. I'm sure if this is the solution to all of your problems but it worked for me. The good thing is that it isn't all that difficult to remove the dash and be able to get a good look at all your wires. It is a possibility that anyone that has installed an after market auto start system in their RAMS may have some of these issues. A couple other RAM owners that have talked to with the auto start feature have expierenced similar problems. If I get any other info with this problem I will advise further. Thanks to all that have answered questions here and Thank You to Edmunds for the forum.
  • Same problem. At my wits end. All lighting worked properly when truck was parked;"Lamp Out" illuminated when I started it at the end of the day and all the described problems began. Bulbs have been replaced all around. The suddeness of problem seems to suggest a relay?
  • Just stopped by a local dealer to try and get an answer. General consensus is the TIP module (Totally Integrated Power) also known as the fuse box.
    Apparently, Dodge has a corrosion issue which causes this. Dealer price for module: $830.00 plus 1.5 hrs labor = $1000.00
    Will continue searching, for now.
  • Some model year 2006 Dodge Ram trucks have the bizarre habit of turning on the wrong turn signal, for instance you are making a right turn and you push the stalk up, the left turn signal turns on. This is an intermittent problem and can be hard to track down. If you have a truck with this problem, you will need the multifunction switch (the turn signal/wiper) replaced. There was a bulletin released and the government is involved so they should know about this.
  • flh62flh62 Posts: 1
    same problem as alot of others no directionals, and low beam or rh high on left replaced the fcm still not working. checked all fuses and relays, checked for a signal to fcm i have low beam input on one wire and a high on another hot sure if there should be 2
  • hi
    im having basically the same problem with my 93 cummins did you find any sloution to this ? thannks
  • I have a 03 1500 ...my passanger headlight will not come on..changed bulbs checked fuse....light works whenever it wants.....i turnd my brights on and only driverside works...everyliight works but the front passanger...no turn signal either ...but if I turn my hazzaeds on both sides work....but passanger side is dim...enyone know a fix?
  • I found that 2002 and on up.With that the Fuse Box on the fender Rots out PC Board rots out in the box and shorts every thing out >>>> need to replace if you see GREEN corrosion coming out of the weep holes on the bottom of box.
    Witch WATER enters the BOTTOM of Box Through the weep holes
  • I own a 2002 dodge ram pickup 1500, I lost power to my Brake lights, blinkers, horn, windshield wipers and low beams... I checked my fuses and relays which seem fine, Does anyone have any ideas of what may be causing this issue or had the same problem and fixed theirs.. I do have a after market auto start that was installed back in 2003 and never had an issue with that.. I pulled out and checked the auto start to see if there was any loose wires with it and couldn't locate any. Ive noticed several similar complaints on this forum but nothing that anyone has followed up stating they found the point of interest! Please reply
Dodge Ram Lighting and Electrical Problems - Page 14 - Car Forums at Edmunds.com
