Town & Country/Caravan Heating / Cooling
Could not find a good answer to this problem of my climate control blower running on high even when the climate control was turned off. I found the solution through my own research. The control module went bad. This used to be called a resistor pack. Now there are no resistors in it, but only a solid state silicone FET. It is located behind the glove box. Simply open glove compartment and make it swing all the way down by squeezing in on the sides. You will see the module attached to plenum with two plugs connected. Unscrew the two 8mm screws to get module out. New part number from dealer is 5179985AA. The original module part number has been discontinued.
If you know somebody electrically inclined, they can fix the old one by replacing the power FET on circuit board.
What is the year of your van?
If our's has a resister pack where would we find that?
How likely is it that the resister pack would be the problem instead of the body control module which you described?
What is the cost of replacing the body control module (used?)
Can you put this unit in yourself?
We were told that you have to reset the computer after replacing the body control module, is that what you experienced?
I moved your post to the Chrysler Van Transmission Problems discussion where you're likely to get more feedback. Click the link below to get there:
Dodge Chrysler Minivan Transmission Problems, post #1067
Maybe somebody can help me here :sick:
1998 T&C Lx AWD
AC does not work when push AC button (button lights up but air temp same as outside air)
AC works when turn the knob to windshield defrost (but of course air is blowing onto windshield).
Any ideas?
Thank you kindly~~~
Another possibility, if you bought it used from a dealer, they may stand behind it.
Since it cools in the rear, this has to mean the A-C system still works and has not sprung a refrigerant leak. It may be just some sort of simple damper control in the ductwork or bad switch in your dash. I
Any insight would be very helpful. Thanks!!
Thanks for the input and any other suggestions are greatly appreciated!
Thank You,
R.Corbett
In both cases, the problem was solved by replacing a fan power regulating swith located behind the glove box. That part costs $20 with a simple fan control and $64 if you have an auto-temp control feature.
In the meanwhile, there is no need to disconnect the battery terminal. To stop the fan, you can simply pull the fan power connector from the regulator located behind the glove box. Pull the glove box toward yourself (it will easily go if you bend the sides inward). You will see a small box with a heat sink. Then unplug either of its two wire connectors.
First heating issue we have with this car.
Our 2000 Town and Country LXi 3.8 FWD today would no longer produce warm or hot air. It was still functioning normal (at least I think) yesterday and the past few days. But maybe it had slowed down producing warm air? I don't know. Yesterday it pre-heated & warmed up fine and gave warm air into the passenger cabin while driving. Today we drove one hour in the cold.
The temp needle would barely move up from cold, and drop back down as soon as we tried to get warm air. Even after 20 min to ultimately an hour of highway driving, we still had no warm air coming out of the vents. I confirm that both sliders were on hot, turned on blower and it would blow air. Recirculation made no difference.
The temp needle remained on cold the whole drive. As soon as we stopped at a traffic light near our destination, the temp needle would go up while standing still, then drop rapidly again when we continued our way.
I'm hoping to get some help in:
- determining what the problem would be / could be
- and get an idea of the repair route & cost.
Maybe this is something I could fix myself?
I have not been thrilled with the dealer(s) (trying to get a $1500 repair for a $20 hose with a little puncture in a hose and things like that) and the small shops have been good, but I had mixed results with both local 'good' shops recommended by multiple parties. (missed diagnosis & over charging in hindsight )
Appreciate any help.
Thanks for the information on the T&C blower problem, we are experiencing a real cold winter here in Ontario Canada and your easy fix was much appreciated. The installation of the new module returned the climate control system to normal and it took less than 15 minutes!
Let me know where to send the reward!
It was easy to get fixed.
$7 part at the local parts store.
20 min to install at a local gas station's service bay.
Two garage shops I called told me this would be a 45min-60min job (and thus towards $60 in labor) which was way out of line, as you can see the part and access it without removing anything. I just didn't want to try it myself as the bolts looked a bit rusty.
Two garage shops I called told me this would be a 45min-60min job (and thus towards $60 in labor) which was way out of line, as you can see the part and access it without removing anything. I just didn't want to try it myself.
Ed
Frank
It worked perfectly. Thank you bravado1! ">
auggievan
Write to Chrysler and lodge a complaint. I also sent to NTSB as safety hazard as trying to adjust the controls at night is a problem. IE can not find the defroster setting...
Any ideas?
Thanks, Greg
Willem
Greg
Dinos
I am pretty sure it is not:
* A/C Unit - It works fine in the rear
* Fuses - I swapped them all out and the rear still worked
* Relays - Same as fuses
* Dash unit - I took this thing apart and actually ended up fixing my stereo
- I guess there could be an issue with just the front knob, but I did not see anything suspect
* I looked under the glove box to see what was there, but did not see a whole heck of a lot (is part # 5179985AA small or something - what does it look like?)
Thanks for ANY suggestions.
The part in my van did not have the same pin connectors. One of the two connectors (the larger of the two) in my van had 6 male tabs, mounted in the same fashion as the smaller of the two connectors - which had two metal male tabs. The part number for the one in my 2002 T&C EX (3.8L) is 04885583(or 5)AA.
Was I looking at the wrong part in my van? There were no other connectors in my van that I saw that would come close to fitting.
My connector in my van looked like this (the equal sign represents two horizontal metal tabs):
The one I bought (5179985AA) looked like this (the "I"'s represent vertical metal tabs):
| II | III |
Does my 2002 T&C EX use a totally different part number? :confuse:
