Saturn SL Engine Management
I'm looking to get an Engine Managment system for my 96 Saturn SL, the only problem is I don't want to spend the thousand dollars for an AEM if anyone can tell me a less expensive alternative that would be great.
I got stuck on the road and Had AAA tow me to a Garage and was told that I never had a tune up??? after they tuned up the car it ran well untill I was told (once again the car stoped running) I needed a new Battery I replaced that. Then the Alternator went . Replaced that then the Drive belt went replaced that. Then the Freon needed replacing did that ...... Now My Problem is with My A/C When im idling the A/C Works great then when I start to move the car the A/C puts out very little cool air .... This does not happen all the time just some times any Hints as what to do????
In addition to the above the check engine soon light is on and I am wondering if I should attempt to correct this myself of take to the local Saturn dealer? And if anyone knows where I might find a free download on do-it yourself Saturn repairs. Please let me know! All comments appreciated! ">
I am working on 1998 saturn s series 4dr auto w air...I just replaced the trans which had serious transaxel damage.Broken case.... pinion gears came through case ect...I thought that damage was due to abuse from young driver.However I replaced transmission(used)Previous trans I had rebuilt.I had had problems with the nut on the hub for clutch pack backing off.The donor trans worked fine for about 3-4blocks...shifted fine thru gears..then check engine light appeared...car abrubtly shifted into 1st gear and would not shift out of 1st..no slipage but no shift...took home and placed on scanner..got codes for for improper gear ratios.I cleared codes and test drove agian..with same reasuts(shifted fine at first then down shift agian...then would not shift i cleared codes agian ...same results the book for what trans will work call for 95 thru 02 I took trans from 96 The symptoms made me think that the origional damage may not of been thru young driver abuse but from pcm being faulty and car shifting to low gear all at once at a good rate of speed.I replaced the pcm from the car trans came from and trans worked fine shifting gears and all...however the car ran rough and low fuel light stayed on and gas gauge would not work.I did more research and found that only pcm from 1998 would work,which i purchased and installed.which upon testing agian made the car do the same thing agian...after this i replaced all of the selonoids ,valvebody all the sensors all electronics on the trans...trans still will not shift has anyone got a clue as to what may be the problem ????...I am goin nuts!!!!Is it possible that i got a bad pcm???
Beasley
-mike
I haven't seen this before but I'm no mechanic. Please help !!!! I would appreciate it very much. Thanks Tim
