Toyota RAV4 Spare Tire Cover Noise
Hi there, i have been hear lots of rattling noise from my spare tire cover. i took it back to toyota and they said they insulated more for me, but still has the same noise. i am waiting to hear from them again on how to fix this annoying problem. my rav4 2005 never ever made this noise. i was wondering if any of ya'll have been having this experience. it's when the motor is running, not even with a/c or radio on . thanks for any and all input. :-)
The top and bottom part of the elastic edge is not too hard to fit in since it is not blocked. You have to open the door to fit the bottom edge but the sides is tricky since you only have a small gap there to get those elastics to fit. I tried to snuck my little hand in the gap and push the elastic with my fingers as best as i can, you wont be able to fit it in completely but it will be a good maybe 3/4 of the way. To completely fit the elastic, you have to push the cover where it doesnt fit snugly like in top, bottom, sides and wiggle it a bit.
Hope this helps.
Anyway, we were pretty successful as follows: First, orient the cover with the logo matching the manual picture. Second, put the top of the cover all the way over the top of the tire. Third, slip the 2 sides (non-elastic) over the spare. Finally, with the gate open, reach under the gate and pull the bottom part of the cover on. There's a little space there that gives you more access, but the gate has to be open.
If the tire has not been off for a long time it is probably partly rusted to the hub or there is dirt and salt on the hub. A little heat around the wheel near the hub might help but maybe a tire shop is the best answer. Most will come to your house if your stuck.
I have been having a similar issue with my RAV 4 tire cover. Were you able to resolve your issue back in March?
