Dodge Dakota Transmission Problems
Our 2000 Dakota quad cab has this problem sporadically. When you start it (sometimes) it won't come out of park. Usually after 5-10 minutes, we can get it into gear. The dealer can't repeat the problem so can't fix it. They did say the parking brake needed greased, but since we rarely if ever use that, I doubt it is contributing to the problem. Any ideas?
Can you get a fault code to read out?
Dusty
kcram - Pickups Host
I'm a brand new member so I hope I do everything right.
When I put the truck in reverse it will engage as long as I don't accelerate. When I accelerate it makes a sound as if something is disengaging. A local garage said it could be fixed for $2000.00 Is there a cheaper method??
Ken
I had simular problems with my 2000 Dakota. Try replacing your throttle position sensor. It's a $23.00 part at most local parts stores. I replaced mine and it cured my shifting problems as well as the bucking issues. You can also try moving your throttle pedal from the idle position to full throttle repeatedly before You start Your engine and determine if it's a tps issue. Sometimes just doing that cleans the contacts in the tps momentarilly. If that doesn't do anything for Your problem, I'd suspect something wrong with the transmission.. also, make sure it's not filled with Dexron. I read some place the Dak transmissions are directly related to the same transmissions used in the H bodys and Dexron causes them to do all sorts of wild things. Did You put Chrysler fluid back in when You changed the fluid and filter? It's my experience that Chrysler 7176 atf is the only thing to use even though the owners manuals say You can use Dexron.
Hope this helps
Ken
Thanks for the information. When I changed the fluid I used Valvoline ATF+3. It says on the container "Recommended for Chrysler vehicles", and "Recommended for transmissions requiring Chrysler MS-7176. You never know though, sometimes in spite of a message like that it still does not work like the original. As you mention I'll start with the tps. Thanks again.
Hope this helps.
Ken
Bill
Larry
Bill
Just after I posted it started doing the same thing even after it was heated up. Doesn't down shift until just as I'm stopping and then slips a bit when I'm taking off and then not shifting again until I let off. The tran shop did a flush until the fluid was pure red. But I think they had a one type fits all trans. fluid so I'll drain and replace with the ATF +4. And maybe replace the TPS?
Larry
Any suggestions on what it needs? Speed sensor?
Dave :confuse:
Any suggestions on what it needs? Speed sensor? How much and where located?
Dave
I had a slip in my tranny and shifting problems , rough idle, followed by a check enginge light in my 2000 Dakota.
I pumped the gas pedel a few times before I started it the next day and it drove fine. When I came out of the first stop on my errands the check engine light was no longer on. I replaced the TPS this morning and truck runs better than it has all year.
THanks Ken for saving me a bunch of money!!
Neither I or anyone I know personally with a Dak of any year have had transmission issues.
Dusty
I recently bought this 96 Dodge Dakota,3.9l with 115k miles. One time I got off the freeway,and as I was waiting for the green light the truck would not move forward.
As I was looking for a tow truck to tow the truck away because I thought the transmission had gone bad (after only a few miles of owning the truck),the truck would run OK again.
I have also noticed that when I go from park to drive, it takes the transmission a few seconds to engage.Moreover, when driving the truck on the street, some times the RPM's would go up to 3k or 3.5K before shifting gears.
I took the truck to the mechanic and he told me that the transmission is staring to slip. I still have not done any transmission tune-up but I am going to before moving to the the more expensive step of replacing transmission.
Since I have only own this truck for a week or so, I would like to ask your opiniong as to what may be wrong the the trasmission and if there are steps that I can take to improve the problem.
Thank you in advance for your help.
Sincerely,
Handymex.
Deb
jlanham
Thanks again,
Deb
Dave :confuse:
Best regards,
Dusty
Thank you for you help. :sick:
I noticed when I am idling and my foot is off the clutch, the clutch makes a dry spinning noise, when I depress the clutch it stops making any noise any clues as to a sollution to quieten the clutch noise and why it makes this noise?
I have a 98 Durango with the exact same problem. Fluid is extremely clean, no wear displayed... just the occasional refusal to shift into third... typically, mine will not shift when cold... so I drive slowly about 2800-3000 rpms in second until it begins to warm up... then let off the accelerator and presto... smooth shift into third.
I've been researching this extensively for the past few weeks. Still no luck.
I was able to obtain a manual online. You're welcome to a copy if you would like... High speed internet is a must... it is 61 mb compressed!
The manual has the troubleshooting/diagnostics in it and that's where I'm headed now. Laying in the driveway... one of my favorite spots! Nothing like the soft feel of pavement under your spine... or a creeper wheel to tweak your fingers... :-)
I was hoping to find an easy electrical problem, but my instincts tell me that I'm in for a lot more than that. I'm prepared to rebuild my tranny myself if necessary. Twenty years ago, I rebuilt transmissions frequently.
I'm confused and intriqued as to why Space Shuttle Engineers have to sneak their way into the development of our automotive transmissions... I suppose that there has to be something for them to do when they get out of college... :-)
Hmmm... on second thought... for the astronauts sake... I'm assuming that the engineers who don't get to work on the space shuttle, obtain jobs in the automotive industry...
:-) (if it is any consolation... I'm an engineer myself)...
Walt
