Toyota Tundra Brakes Problems
I have a 2000 tundra that has the ultimate front brake problem. I was told by the dealer that front brake vibration was normal and to just drive the vehicle. I had it serviced at 76k including the brakes. My truck has 92k on it and my whole right side front just collapsed on me driving on a paved road. It took out my fender and door. The body shop said all the bolts vibrated loose from the bad brakes. Are there any other similar stories out there. I am thinking about hiring a lawyer because this could have been real serious.
Time for a new body shop. Every part in the brake system can break and the frontend will not collapse (unless you hit something because you could not stop). The front end colapsing is caused by a balljoint failing because it was not replaced via preventative maintenance. It is your fault (or the mechanic that last inspected it if you took it in regulalry). That is something that, number 1 would have been detected by a quality mechanic at the last alignment, and number 2, does not fail over night. Preventative maintenance is your responsibility. I am not saying that the ball joint should not last 200k (Ford is lucky to get 75K), but if the part is failing early, regular maintenance will catch it. I have encountered people that have driven 75K without changing the oil, and then saying that their Toyota was junk cause the engine froze at under 100K. HELLO.
Andy
My truck is an 02.
As I was travelling @ 100 Kmh (I'm Cdn) my fron end slammed to the ground, I had finally came to a complete stop and as I got out my vehicle, I noticed my tire had fallen OFF from it's assembly. Now that the truck is in the repair shop, we are patiently waiting for the lower ball joint however they are on back order becasue they have no stock on North America, hmmmmmm I wonder why their is no stcok? becasue pretty much every Tundra owver is complaining about this exact same issue.
I had recently found out that Toyota is having problems with the Ball joints, and what Toyota Corp has told me is that "they don't know of such a recall" or as they call it "Campaign"
Until now, I had never had any problems with the vehicle, it has never seen a Toyota dealership for any maintenace, the thing worked like a Charm ewvery time, I have a 108,000 KM on the vehicle and this should not have happened. People want to talk about regular maintenace? the thing has been at a servcice station regulary, I own 33 Franchises in Canada. I know how they are to be maintained.
Also, dealer said "Toyota has really tightened up on loaner cars" What? 30k dropped in January to buy this thing and no love? Anyone else have this issue?
I'm considering buying one, but would like to know if it and other problems have been addressed.
Jimmy
Message #6 by tundradude "Both the ball joint and brakes are on recall at Toyota's expense" Can anyone help me further in verifying this statement. I live in the Colorado mountains and experiencing a downhill run is a terrifying experience. Good vehicle for Iowa maybe.
Help will be much appreciated. Larry T.
What could be the problem.
Any feedback is greatly appreciated in advanced
Rooh
My wifes '06 Tundra (see a trend here), has 22,000 miles with ball joint recall completed, and she also got a new set of front tires, with the same premature wear problem.
Any other Tundra tire wear stories ?
Two weeks ago I replaced a pair of warped rotors with some drilled and slotted rotors, adjusted the rears. The brakes work great
. I now have an ABS? issue. If I come to a slow rolling stop, like you might when parking it, the ABS engages, though not always. The truck is probably going only a couple of mph at this time. I can feel the pulsation in the brake pedal and hear the system engage. The ABS sometimes still pulses for a second or two after the truck stops. This is the only time the ABS comes on for no reason.
I checked the sensors, wire harness, bled brakes.
Anybody have any ideas? Thanks!
Mechanics are unable to figure it out.
brake boosters fail because of several reasons. 1, the main body of the booster may become defective over time.1, damage on the power brake booster check valve may cause vacuum leaks. Three, leaks could also occur somewhere in the system, such as in the vacuum hoses. Leaks are the most common problems that cause a brake booster to fail. So, in case you encounter problems in the form of very hard brake pedal, the booster is one of the first things to check, and leaks are among the first problems that you need to find.
and i know a good site ,they can give you more suggest on brake problems , http://www.fiverhope.com
http://www.fiverhope.com/category-74-b0-Ford-brake-booster.html
http://www.fiverhope.com/category-68-b0-Toyota-Brake-booster.html
