When I put gas in, the fuel handle keeps kicking back. I have to hold the fuel handle on as soft as possible to keep it from kicking back. It takes for ever to fill up.
Anyone know why & a fix?
Any help would be great.
Thanks Mike
Ran new ground wire at bumper in place of a rusty one. Inspected for loose cables, checked bulbs, checked fuses....Now I am lost, and need help. :confuse:
by erberichr
Jun 08, 2013 (7:53 pm)
1995 Silverado - Ran out of fuel.
1) Added more. Vehicle started ran a few seconds and died.
2) Replaced Fuel Filter Same symptoms.
When vehicle does start, I can pump the gas at it will run a little longer.
I think it might be the Fuel pump relay.
Any Suggestions?
I have a 2002 GMC Sierra extended cab 4.8L V8 was having trouble on cold start with the ideal smooth ones warmed up now the truck turns over but won't stay on and I hear a clicking poping sound from under the truck center consol location can someone help Thanks
Silverados are famous for fuel pump problems. To make changing the pump an easy snap not requiring dropping the tank or shifting the bed, I cut a trapdoor in the bed right above the fuel pump. 7" wide X 12" long. 14" in from the side and 6" back from the front of the bed. I riveted two strips of sheet metal to the sides of the cut out piece and these secure the trap door to the bed with sheet metal screws. Changing the pump is a 20 minute job for one man. This fix will work on any truck with the fuel tank below the bed and the pump in the tank. Why didn't Detroit make a door here? Perhaps $300 dollars for fuel pump replacement will give you an idea why!
In desperate help ! I have a 97 chevy tahoe with 5.7 vortec i been having on going problems with this damn truck and once i locate the problem another one appears. changed alternator because it went out then it just died one day to find out the pump out. Changed that along with relay and filter. Did complete tune up. spark plugs cleaned throttle body. New camshaft position sensor.. Distributor cap and rotor. Finally found the problem the ignition coil went out . bam i changed it then it started worked for few days then didnt want start one morning. Yet again im back at it change fuel regulator sensor still dont start. Pump activates but no fuel is coming out of bleeder valve What so ever im figuring its clogged somewhere but i dont even know where to begin Checked injectors located in manifold they seem be fine but engine isnt getting fuel . i use starter fluid starts but seconds later shuts off. Im beat Ideas input anythinggggggg !!!! I have so much faith with my damn truck but i became very irritated with it 830.890.1637 please txt me if i dont respond ive never done this online crap before but im at a loss rn please help
