Volkswagen Rabbit
  • I have those features on my 4 door...although I'm not sure about the heated washers. But it had the other things you mentioned, although they are part of the standard package, not an option.
    Does that fuel light come on when the needle hits empty? I'm barely one mark above empty and still no light. The manual says it will come on when there is 1.8 gallons left.
    I have 320 miles on this first tank, so I think it's already doing better than the Camry!
  • Oh my...I was looking in the wrong place for the fuel light. It came on above the clock, and may have been on a while. I put in 13.5 gallons...only one left! Got about 24 MPG...not bad on the first tank!
  • wcottwcott Posts: 35
    I've heard two, is that the 07 Rabbit doesn't come with frost plugs in the engine block, thereby not being able to install a block heater for cold Canadian winters. My dealer says my 07 will have only an adhesive electric oil-pan warmer.
    However, other posters have said that their '07's DID come with block heaters...or at least were available for aftermarket installation.
    Can anyone verify which statement is correct?
  • Although I'll miss those Caribbean waters, I was glad to come home to drive the bunny some more. No rattles yet...tight as can be. I might actually start reading the manual now!
    I've heard we can have the dealer program the car not to lock the doors when it hits 10 mph. There are 3 options actually. Have any of you heard about this?
    And, what's up with the hatch seems like sometimes I have to touch the W release twice before it will open the hatch, and other times only once. I'm sure there's a reason for this. I's probably all spelled out in the manual, right? I'll put it on the bedstand and read a page or two every night.
    Someone told me it looked "sporty" today...I liked that better than "cute"! But, mostly I love the fact that it is such a rare car on the really turns heads. I love this car...very fun to drive and has a sporty feel.
    How's everyone doing out there with their rabbits?
  • jeffyscottjeffyscott Posts: 3,855
    Why would you not want to have the doors lock? It is safer to drive with doors locked as they are less likely to fly open in an accident.
    I do know you can have the locks programed so that they will all unlock when you turn the car off and pull the key out. We had our Jetta programmed that way. Note that the auto unlock will only do it's thing if you allowed the doors to auto lock, if you manually lock a door it will not auto-unlock.
    I believe that those with the multi-function computer can change the programming themselves.
  • Thanks, Jeffyscott....yes I think it is best to have the doors lock, and I like your program option. There is a 3rd option as well, but I don't remember what they told me. Anyway, it's nice to have the back hatch ready to be opened after you exit the car. And when the car is in the garage, it's nice to have all the doors accessible at any time.
    The little hatch release button seems strange...when I pull on it, there is no noice...I know it's electronic, but one would think it would give you an indication that the hatch had been unlocked? And, any ideas on the double-functioning hatch release on the hatch itself?
  • seminole_kevseminole_kev Posts: 1,722
    Yeah on my GTI I've noticed that the behavior of the hatch release doesn't always seem to be consistant. I'm sure there is an actual reason for it, but I haven't necessarily figured out why sometimes it works and sometimes it is still locked. I'm sure there is logic behind it (and probably is spelled out in the manual, I've just been too lazy to look).
  • I've actually posted a similar msg about a month ago with no response..hoping for a 2nd time others may have heard of this problem..
    I have a 2007 rabbit with 3,100 miles on it that has had 3 out-of-round tires in the same location - drivers side front. Each time that the tire was found to be defective all other tires were checked to make sure they weren't out of round; and still has only been in that same location. After 2nd brand new tire I took in my car to dealer. Dealer found nothing mechanical...however they thought it was unusual. Now this is my 3rd out-of-round tire and I will be taking in my car again. Has anyone ever heard of this being a problem on the rabbit/golf? It seems it takes a few weeks after getting new tire for it to become out-of-round, so i find it difficult dealer doesn't see anything mechanical. It is really bothersome, considering it makes my overall driving experience really unpleasant.
    I would appreciate any feedback to this very annoying problem.
    I think our manual has the programming instructions and shows what the choices are, even though our car is not equipped to allow us to do this ourselves. The three may be all doors unlock, driver's door only, and no doors unlock. Not sure if the hatch would be included in the "all doors" choice...I do know our trunk does not unlock when key is pulled from ingition ;) .
    I can't imagine how the car could affect a tire in this way, so it is probably just coincidence that you had two bad tires in a row, but if you want to be sure you could maybe put the new tire in a different location and move one of the existing ones to the problem spot and see if it goes bad.
  • yeah that has been tried seems that no matter which tire is placed on drivers side front always goes out-of-round..
    its just so strange.. :confuse:
    oh...that is wierd then...
  • eldainoeldaino Posts: 1,618
    hey den! glad you had a good vacation.
    The bunny is doing great, got 15600 on her right now. Had to reset the maintanence minder since the dealer set it to go off at 15k when i'm not due until 20k like the manual says.
    As far as the trunk release goes, i used to think that there was something wrong with it too; there isnt. I actually did read this in the manual too; you have to HOLD the hatch release for about 2 seconds. Thats all it is. don't just press it, hold it for a couple of seconds. Thats just how it works. Dunno why, i guess its a safety thing, but its not that its being unresponsive, its just programmed to be that way. if this gets annoying i just hit the hactch release button on my side of the car; it doesn't make a sound or let you know that you pushed it, but it will unlock the hatch.
    I know i love the feeling of never seeing my car on the road.
    I like the auto door lock feature, we don't have a garage, since we live in an apartment, but maybe ill get shim reprogrammed when we do get our own place!
  • Thanks, Eldaino...
    Okay...sometimes...and I can't yet figure out when...I have to push the W symbol on the hatch a SECOND time to get it to open. The first push seems to disengage the hatch halfway, then the second push on the W releases it completely to open. Of course, I just went to test it in all ways I could think of, and I couldn't get it to repeat what I just said. It opened everytime on the first push of the W. So...just a little mystery if anyone has any thoughts.
    Also, I keep messing with the stereo to see what combination of settings gives the best sound. I have the 4 door, so I know it's a bit of an upgraded stereo. But frankly, I just don't think the sound is as full and rich as it should be considering all the speakers, etc. I move the fader towards the helped a bit...but there something I'm missing or am I just going deaf? My XLE Camry had a better sound. But, I do love the functions on this radio. Thanks...
  • micwebmicweb Posts: 1,617
    It's probably a problem with the wheel hub, not the tire (the wheel hub attached to the axle).
  • when I took it in I asked them specifically to check the wheel hub,making sure it was centered not defective, etc. and they said everything looked fine...
    I will be taking the car in again next week and -hopefully- they can find the problem. I will keep you guys posted...
  • gogogodzillagogogodzilla MarylandPosts: 706
    Does anyone know if VW will be offering a diesel version of the Rabbit for 2008?
    the clean diesel jetta should be coming out in 2008...and when the sportwagen debuts ( a wagon version of the rabbit/jetta) it will initially be released with the revised 2.5, then the 2.0t and the 2.0 tdi will be the last to show up...but i have yet to hear anything about the diesel rabbit, i think they will, but we are gonna see sportwagen and jetta versions first.
  • jbaustianjbaustian Posts: 78
    It's looking pretty certain that a Jetta TDI will be available in the March-May 2008 timeframe. There's no reason why the Rabbit TDI shouldn't go on sale at about the same time. The Jetta TDI is supposed to have a 2.0-liter engine -- I assume the Rabbit will get the same engine and not a new version of the recent 1.9-liter engine.
    A Jetta wagon is coming soon -- it should get the TDI engine when the other Jettas do.
    I do not know if the New Beetle TDI will be back -- VWoA is only selling about 28k New Beetles a year, and the numbers keep dropping year by year.
    A lot of folks are looking forward to the Tiguan all-wheel-drive model, which was introduced at the Los Angeles Auto Show with a TDI engine. It could go on sale in autumn 2008.
    No firm information on a TDI option for the Passat.
    I read last week that the number of manufacturers planning to offer diesel engines is now up to eight. Most of these will be coming for the 2009 and 2010 model years. So it would be a shame if some other company gets diesel-engine cars into the showrooms before Volkswagen can.
  • chiefjojochiefjojo Posts: 39
    VW needs to release the TDIs ASAP. As someone said, a Rabbit TDI 4-door with solid performance and 40mpg will be a HUGE sales winner. I would strongly consider buying one.
  • ike3ike3 Posts: 81
    Did I hear right that production has been ceased for 2007? And that 2008 production is about to or has started? In late April?
    The 2 door US Rabbit will get what was already on the 2007 Canadian Rabbit. A center armrest/console and the upgraded 170 horsepower 2.5 litre engine. Beyond that, are there any other changes?
    totally. I like the sportwagen, but i know that if it came down to it, i'd probably take the 2.0t. Give me a bunny with a tdi badge and the mileage to match and i got a solid performer with great fuel economy and a place for my dog/drums/stuff etc.
    the trim levels have changed names. I think its like the rabbit s or something like that.
    standard armrest? nice. i'll have to order it . I don't think that there are any other changes tho, i've already heard about the 2.5's upgrades, (its an ecu reflash and a modified intake manifold, both things that 150hp 2.5 owners can get done.)
  • erikerik Posts: 21
    The fifth generation Gold/Rabbit was released in Europe three years ago with a sweet 16 valve 2.0 liter engine. Too bad, the NA market was stuck with the old body style until this year. I would love the G5 TDI, but V of A has there dipstick where da sun doesnt shine.
    Smoke you later
    this engine would never work in our market; yes the mileage would be better than the 2.5 now, but with all that weight to lug around, it would hardly be nimble and peppy the way the rabbit is now....europeans worry more about gas seeing as how much more expensive it is over there, then acceleration times it seems, which is why the 2.5 is excluxsive to our market.
  • golfievetgolfievet Posts: 3
    The 2008 production model should hit the dealers showroom by mid August 2007. Aside from the 170HP 2.5 litre engine, the new production model will have a revised front end similar to other VW products, like the 2007 Jetta.
    See the following site for preview pictures of the new Rabbit model (called Golf V in Europe):
  • backybacky Twin CitiesPosts: 18,878
    That's too bad, about the new Jetta-like front end. I prefer the snout of the current Rabbit to the chrome-chinned Jetta's nose.
    don't worry backster, i dunno how rock solid this is; i posted this site awhile back, because it has some pics of what the next gen mk6 could look like, but A LOT of the pics here are totally photoshopped, i have not heard that the front end will get the chrome treatment, since the noses of the jetta and rabbit are exactly the same, the rabbits being body colored just to differentiate the two models. I doubt it will change.
  • ezshift5ezshift5 West coastPosts: 855
    ....VW needs to release the TDIs ASAP. As someone said, a Rabbit TDI 4-door with solid performance and 40mpg will be a HUGE sales winner. I would strongly consider buying one.
    What's in my garage: 1982 Rabbit Diesel Pickup....52HP, 5M, air........55 MPG @ 55 MPH (go faster; less fuel efficiency)
    odo 290k.
    What I would like in my garage: a NEW diesel pickup with about the same parameters........
    ..realizing that people in Hell want ice water.......
  • denverdavodenverdavo Posts: 38
    Hi! I've got about 1,200 miles on the new bunny and he/she is still purring right along! I got a chance to really use the anti-lock brakes the other day when someone switched lanes into me at a fairly low speed. I'm happy to report that they seemed to work rather well! A few questions have popped up however:
    1. In Denver, the regular unleaded is 85 octane. I've burned some of that and the 87 octane mid grade as well. The book calls for 87 as a minimum, and I know this would be important on a turbo, but how important is it with the 2.5 to burn 87 or more? I didn't notice any performance issues with the lower octane, but I don't want to cause any long-term harm to the engine.
    2. I just noticed that all the bunnies on the dealers lot have the stumpy antennas. Mine is the long one...what gives? Somewhere I saw someone refer to a different antenna, but what is the price and pros & cons? I guess I don't mind the longer antenna, but after seeing the squatty thing, I thought they looked pretty sleek.
    I've been getting about 24 MPG with a 25/75 hwy/city mix. I guess that's not too bad, huh? With gas at $3.10, it would be nice to get about 34, but at least I don't drive too much for the most part.
    Overall, I'm very pleased so far with this car. I have a hunch I might get some more dates too! LOL My only complaints would be the somewhat lackluster sound quality from a stereo that has 10 speakers. Any ideas on how to improve this? In the late 90's, VW offered some sort of add-on to boost the sound quality. I don't remember what they called that. Anyway, thanks for your help everyone! I might write about separate topics under another heading.
Volkswagen Rabbit - Page 15 — Car Forums at
