Yukon xl front end squeak
I have a 2001 yukon xl. The front end squeaks all the time. I happens when traveling fast or slow, rough or smooth road. Any one help?
keisha40, "GMC Yukon/Yukon Denali Problems" #471, 15 Aug 2006 8:07 am
Please continue over there. Thanks,
Anyway, I "fixed" it by coating the outside of the cable with grease. This is best done from underneath and placing your hand between the firewall and the plastic wheel well liner just in front of the driver's door. I also wrapped the cable as best I could (it is tight in there) with a small piece of foam pipe insulation. I find this holds the grease there quite a bit longer. I now can go a year without the squeak before needing to put some more grease there (it seems to dry out/wash away with time).
Good luck. The problem was very annoying before I located it.
Rob
I've been chasing "the sqeak" for weeks. Lubed the bushings with spray silicone (NOT a petroleum based lube/ eats rubber!!!)
I also used a wooden dowell as a hearing device.
I'm changing the shocks now! The frt. pass. squeak is embarassing. Must be salt/sand deteriorating "stuff" more on that side as that's the side the plow trucks push all the road goo.
I noticed a chafe on the front pass. shock where it was rubbing on something (control arm).I also soaked every bushing, shock mount with silicone spray and greased all fittings.
Quiet as a mouse now!!!!!!!!!!!!!!!!!!!!1111111111
