Incidentally, there is a fuel filter that can be dissassembled, cleaned and reused sold in the automotive aftermarket for roughly $50. Or buy a fist ful of the disposable Fram in line ones for $2 each and change it every year or so. (These are sold by fuel line size: 3/8", 1/2", etc. so you should know the ID of your line.)
Someone had a leaking rear diff... try removing the plug (might as well check the level while you're in there) and then apply some Hylomar to the threads before reinstalling the plug.
Your socket drive fits the plug perfectly... no need to buy a special tool.
I don't think the boys at solihull would let one of these out of the factory headed for Africa, or South America without something to filter out the dirt in the fuel.
Lets agree that maybe a Disco might need a little more maintenance but, what the heck, underneath the guts of it are bullet proof. But then you learn that it doesn't have a $3 (at retail) fuel filter, that to change the tranny filer you need to pry the (boxed) frame rails apart to remove a cross member...
Unfortunately you have to spread the frame rails to change the fuel filter...
Consider 4-wheeling: you're out there jouncing over stumps and rocks, and you don't see a dropoff behind a large boulder. You ease a wheel over it, and the wheel falls into the hole, your frame crashing down onto the boulder. If you're in a Rover, you're in luck: the frame crossmember just saved your transmission pan... as designed.
Yes it does add complexity to a filter change, but the (possibly day-to-day) benefits far outweigh that complexity.
The engine oil sump is located far forward from the transmission sump, and it's tucked up nicely between the frame rails too. Its proximity to the front wheels and central (longitudinal) placement gives some measure of protection when dropping over obstacles: you're far less likely to get hung up by your breakover clearance at the front or rear wheels than you are at midpoint.
DM: How likely is it that you bumped the connection to the Air Mass sensor? It's inline with the air intake and with your removing the cover to the air filter you might have bumped it loose. The ECU depends on a good signal from the AM sensor to know how to map its fuel injection pulses. There's also a Throttle Position Indicator down in there that tells the ECU how to work. Just check all the electrical connections on the driver side of the intake plenum and see if they're all tightly connected.
By any chance did you change the air filter and get it in cocked or something? Maybe it's moving around and obstructing air intake at the snorkle?
I checked everything. THe only thing I found since this whole problem started was the blasted O-ring out of place. I only have a short 20 minute drive to work, so I am not sure if the problem is fixed, or that I just haven't been driving it long enough at a time to make it happen. I am still going to change out the fuel filter this weekend regardless, just because it makes sense, and I doubt if it has ever been done. This has been a most frustrating problem. I guess because I did several things at once and am trying to figure out if it was something I did, or just coincidence. I changed the oil, filter, tranny fluid and lubed the drivetrain, and also checked the air filter. The gasket is the only thing I can think of ourt of place. I haven't broken out my disk to look at the manuals lately. There are two sets of wires. One leads to a sensor that is on the air filter cover(two wires), the other is in the next section of the snorkel. The o-ring is the one between these two sections. I can see where if there wasn't a snug seal, there would be extra air sucked into the snorkel, not going through the air filter. If the first connection (The one in the air filter cover) is an air temperature sensor, then it doesn't make sense to me causing this problem. If it's a mass air flow sensor, then it does. I don't know. Let me know what you think.
You are correct about the check engine and service engine lights. The service engine light can be reset, the Check engine has to be done by the testbook. It was you who taught me this awhile back.
The Mass Air sensor on mine is toward the plenum from the o-ring you're talking about... in the cylindrical part of the air intake.
Does it seem to be okay under light throttle but then lugs down when you stomp it? And does it seem to lose RPM, instead of gaining, as you said?
Dang. You checked the ATF level when you were done, and checked the oil level too... so neither one is overfull?
How about the spark plug wires on the side where the engine oil dipstick lives?
This is sure a strange one.......
I do have a question regarding resurfacing the rotors. I haven't seen anyone recommend doing this. Are the disco rotors non- turnable? I assume the rough braking is due to the pads trying to conform to the old surface of the rotors. If so, how long is this break-in period?
Anyone have thoughts on this?
About the "roughness" you shouldn't really feel that when bedding in a new set of pads; if anything your braking power will be slightly less than when they're fully bedded in (and fit the unaltered rotor surface correctly). I'd think your pads would be well bedded in by the 3rd or 4th day of driving them.
You may have got a sticking caliper... they are supposed to self-center on the through-bolts. Did the bolts seem to bind when you put them back thru the calipers? If so your caliper may be running off-center and you can have the caliper body interact slightly with the rotor upon braking.
It really is an easy job. And a good time to rotate the tires front-to-back. Also a good time to bleed everything and get the old nasty brake fluid out of the calipers. Just make sure you don't push the calipers in to accomodate the thick new brake pads, without cracking the bleed screws. The ABS pump DOES NOT LIKE to have dirty brake fluid pushed back up the lines into it.
Good for you, doing your own brake job! It's simple and fun!
Best regards, -Bob
As for the roughness, the caliper bolts went back very easy. I made sure to hand tighten everything before breaking out the wrench. I'm always afraid of stripping bolts. How would I check for a sticking caliper?
I've driven it maybe 50 miles so far the ride is smoothing out. But, I may just be getting used to the roughness! Other than that, all is well.
This is a huge improvement over the current model, in terms of looks IMO. I think(?) it also has a variation of the Range Rover's independent suspension. The spare tire has now been moved inside.
I'm wondering if this a *pure* Land Rover, or if there is some platform sharing with the Ford Explorer? The wheelbase appears to be much closer to that of the Explorer, than that of the current Disco.
Bob
What about the suspension? IFS/IRS, like the Range Rover?
Bob
As for the New Disco From the site Nanuq sent, I don't think I like it too much. It looks narrower than the current one, and has lost a lot of it's uniqueness. Gone are the Alpine windows, and raised rear roof which gave so much to it's apprarance, and appeal. It looks like a shoebox on wheels, almost delicate instead of tough. What happened to the steel bumpers? What about the Class III hitch, or the dual tail lights and turn signals? I can understand moving the spare tire underneath, but I would rather pull it off the back than have to crawl under my truck to get at it. It's also harder to keep it clean and avoid rusting the steel rim. Out of sight, out of mind so to speak. Now the rear end looks like a minivan. This has become definitely a "Soccer Mom SUV" instead of the last great true 4X4 truck left in the world.
Personally I think I will keep my '96 until my son starts driving it in about 4-5 years or until it falls apart, if ever, then maybe get a used '04.
Now about that new Disco... I didn't send that link. Argh. I'm with you, I like my '96!
And you realize the problem is not with the spark plugs themselves... this is indeed a Lord Lucas problem. I mean really... you put BOSCH plugs in a Lucas electrical system? Tsk.
I recommend putting in some really poor el-cheapo plugs and pouring a pint of Guinness over the intakes... and I bet she'll run fine.
LORD LUCAS DISCLAIMER: My Land Rover is a POS that runs rarely and when she does she can scarcely summon the power to stay ahead of the street sweepers. Parts fall off of her continuously, though they are in fact of the highest British quality. She stumbles and stutters, she embarrasses me always, and her doors refuse to shut. She leaves the seat up on the toilet and charges ebay purchases to my credit card without my authorization. Run, do not walk, from her... for she is hideous to behold.
*wink* that oughta do it for a few more months
See 3rd story/link (as of today) on this site.
It does indeed have IFS/IRS. I too agree with Chuck. I have no concern about this vehicle being off-road challenged. I'm sure it will be a worthy replacement for the current Disco, and will uphold the LR reputation just fine.
Bob
Or looking at it another way, on this board I've learned that Discos have no fuel filter, to change the transmission oil filter requires using a hydraulic press to pry apart the boxed frame to get at a cross member, the ABS pump can fail and cost the national debt of Haiti, the engine is a GM cast off from the mid'60s, etc. Yet, people insist that they are well engineered and will take you places no other vehicle will. So, how is this reconciled? (Given what I know about the quality of fuel in the Third World, I hope that Disco owners there install a huge Racor fuel filte with a glass inspection bowl.)
Again, I'm not looking for an argument. I'm just puzzled.
As to Blockislandguy, there is a fuel filter in the Disco I It is behind the right rear wheel well, just forward of it. The Disco II has one integral with the fuel pump, and the cross member is there to protect the transmission as well as add rigidity to the frame. I would trust mu Disco where I wouldn't dream of taking the Exploder it replaced. Ask any Insurance agent about it's safety rating as well. Way I look at it, if you're not willing pay the price to maintain it, you shouldn't buy it. (And I'm a sailor) Everyone buys a Disco knowing the rep, and hoping it's not going to happen to them. I used to have a BMW that ran like a clock until the warranty was up. Then it wouldn't keep the time right for more than a month at a time. In 6 months I had to have the engine taken apart twice to replace a seal, and got stranded 4 times. Each time in the middle of the night, in the middle of nowhere. You couldn't take it to anywhere for an oil change that didn't want at least $100. So I got rid of it after 5 years. It was a love-hate relationship, but when my wife ran over a parking lot curb, and it bent the frame, It became a (I'm not gonna pay for that one)problem.
I pray to Lord Lucas that he not choose to visit me again anytime soon, for I beseech his shadow of darkness and am trying for the light.
I actually was in another business for a short time in the early 1980's servicing restaurant coffee machines for a food service company. At the time the labor charged for my work was $75 an hour and mileage charges to get to the site. Given that I had no where near the overhead that a Car Retailer has makes the $98 seem almost reasonable.
My wife and I are new to these boards. We've owned a Land Rover before (2000 Series II) and are considering buying a used 2003 SE7. We've found one at Land Rover Denver South (although we only want to deal with Land Rover Flatirons - which is near Boulder where we live and is the dealership that we worked with last time).
I've seen people posting VIN numbers on here and getting the history of the vehicle that way. Can anyone do that or is there something that needs to be done in advance of the request.
If the former, the VIN number is SALTW16403A812692.
The ABS system in the Disco either has a major engineering flaw or is just junk. I have had both front end sensor hubs, the rotors and brakes on both sides all replaced because the ABS, Brake, HDC, and TC lights were continuously coming on and staying on. I am told that the ABS hubs are sensitive to getting brake dust and dirt on them and that those conditions will cause the light to come on.
The right front side was the last hub replaced less then a month ago. This weekend all the lights are back on again. I take the truck offroad alot, it gets dirty alot and I'm sure the hubs are constantly covered in mud or whatever. Even after cleaing them up the lights stay on. Taking it back in this week to see what the "new" problem is.
Anyone else having ABS issues?
It's probably good they replaced those small hoses at the juncture there by the TPI as they eventually get gummed up inside that "T" fitting and then you have driveability issues. Or the hoses crack and then all bets are off as to what the ECU will do. And ideally now you have true rubber gaskets at the air plenum. Some Rovers of our vintage still have cork and those degrade over time.
Sorry it took so long to get back to you, I've been out of town.
I seriously doubt your problem is with the "hard" parts like hubs/sensors. It's got to be in the wiring or ECU.
My '96 had sporadic electrical problems with unrelated systems and I finally got a hint from another gent that my fuse block beneath the hood was the culprit. I disassembled it and cleaned all connections to restore "clean" power to the electrical systems (ECUs) and presto ALL the problems went away.
Your '03 is doubtless different but my fuse block is on the passenger side, midpoint of the engine, level with the intake manifold. It's about 3" wide by 10" long. There are some heavy black wire bundles entering it from beneath. I just took it apart in-place and cleaned all connections with a pencil eraser, blew out the dust and reconnected.
I thought my problems were solved, but nay. I got my truck back, and it is definitely running smoother, but the original problem remains. By the way I filed a claim with Shucks, for selling me the wrong plugs which (According to LR) caused the engine problem. The issue I have is something wierd. I can be driving down the road with no problem whatsoever, then all of a sudden my truck will lose power and shudder, for about 2-3 seconds, then the power comes back, and it may, or may not continue like this for awhile, or may go away after a couple or 3 instances in a row. It usually only happens after I have been driving for at least 20-30 minutes. Never right after cold starting. I don't think it's mechanical. I think I have an electrical problem of some sort that is random, and only happens when the truck is warmed up. I inspected my transmission, and discovered I had overfilled it when I changed the fluid, so I drained out the excess fluid, hoping that was the problem. But then it did it to me again yesterday. I only have a 20 minute drive to work, so on a normal day I will never see it. Only if I have to drive for a distance longer than about 20 miles does it happen. Unless I have a lot of stop and go driving, and then get on the freeway for the ride home. I don't know if it would be the ECU since it doesn't happen all the time. I am thinking about the fuse block issue you phrased in #3672 or something similar. Maybe one of those vacuum hoses didn't get replaced, but they don't look bad. The only ones I had like that were the Cruise Control hoses, and I cut the dry rotted part off them months ago. I sent an e-mail to my LR Rep, because I don't want to take them my truck, and they let it sit overnight, then they can't reproduce the problem in the morning. I need to talk to them so I can go pick up the rep, and drive on the freeway with him until it happens. Yesterday I noticed (after I was off the freeway and on a service road, that it did it and the speedo was all over the place and then settled out. If all I had to do was drive to and from work I wouldn't worry so much about fixing it until it got bad enough to track easily, but I am planning to drive cross country this Summer, and don't need something like this haunting my whole trip, or getting worse then (Like in the middle of Montana). Of course I get no lights or any other indications. LRNW says if it was ANY problem with the ECU I would have a "Check Engine" light. Let me know what you think.
BUT...
If your speedo hunts all over the dial as it acts up then I think you've got an electrical problem. When I was having my electrical problems I'd flip on the stereo and get a big BAM out of the speakers, the speedo would momentarily drop to zero then pop back up, and all dash lights would go off. With loss of power momentarily. Then the idiot lights would all illuminate as if I'd just started it, then they'd go out and all was well.
Try the fuse block cleaning trick. Take your time, remove EVERY fusible link and clean its connections (in the block and on the link) and reassemble. Blow ALL the dust out. Clean the connections where the wiring bundles attach. I bet it will help a lot and it only takes 15-20 minutes and a phillips screwdriver and pencil.
I run Nokian light truck tires rated for 85psi, but inflated to 50psi. I love 'em.
The VIN is SALTW16403A812692.
Any help would be greatly appreciated as we're probably going to buy it this week (unless the VIN search shows up with something really bad).
Charlie
What all did they replace in yours when it had the sticking valves, besides the Air-Mass sensor which it turned out not to be. I know yours was the battery (I too, have an aftermarket battery, but yours is too much of a freak thing for me to think about checking for that one)
Charlie
Over the course of finding the battery issue they also replaced the TPI, Air Mass sensor, an ECU PROM, and many other small things.
I sure hope the fuse block fix helps! More later.
Thanks to many of the posters here that made our decision easier.
Happy Rovering.
- William F. House
www.oceanofwords.com
1. The drivers seat creeks and squeeks like crazy at every bump or acceleration. I'm average size so that's not an issue. It sounds to be all in the back of the seat and where it meets the base of the seat.
2. Clock light out.....easy fix?
3. Rear door has slight leak (found small pool of water on cargo cover and watched it drip slowely in a rain storm. On the left side of the door opening looking in from the back where a seam meets. Can't see anything out of the ordinary.
It seems to be under warrenty still and I have to find out for sure. Are any of those covered under warrenty? The seat is easily the biggest complaint. the noise is taking away from the experience.
Thanks....glad I'm driving this beauty.
b
