Toyota Tundra Engine Issues
I have the 03 v8 with 58k,, I started to get the po156 code for check engine. I replaced the correct sensor but just received the same stating "circuit malfunction". ive read here that there could be a heat issue to close to other pipes or something like that. Any ideas would be grand at this point.
cat system going bad??
I have a 2000 Tundra. Last week the check engine light came on. My mechanic got a po135 code. He said it was for an oxygen sensor problem. He's a toyota mechanic but not a dealer. He heard there was an issue with Tundra oxygen sensors and suggested I contact toyota to see if it was a recall. If it was covered it could save me $250 plus labor. He's an honest guy. I tried the toyota web site, 800 number and the local dealer and none had any notices or recalls. I spoke with him today and he said try again, he thought there was a notice or something but he doesn't have any more information. He said some bad parts don't get recalled, they call it a campaign? They won't contact all the owners and offer the repair but if you ask they'll pay for it. At the least we can get counted as another owner with the problem that may eventually lead to a recall or campaign.
I'm going to try again to see if I can find any assistance. I'll keep you posted. Please let me know if you learn anything. If anyone else has information to add it would be appreciated.
I'll keep you in the loop.
I replaced the spark plugs, I cleaned the KN mass air flow sensor. 300miles later I got the po161 code again. I'm really perplexed right now, I just may replace the cat system as thats all that left for thet system (i think), remember I already replced the 02 sensor and the code came back. I'm assuming it's noty the new sensor.
Maybe replace the cat system.
Any ideas left??
Anyone have this one happen before???? any guesses???
the other party that replied to you, is probably correct. I
would probably suspect the valve seals and or the rings as
the rulpret. And I want to ask, a supercharger or a turbo-
charger. There is a distinct difference. Is it belt driven,
or powered off of the exhaust. If this is the case, either
way you are probably running to much boost; which would
cause the seals on the valve or too much boost would be
putting too much pressure to the indiviual block bores. That
maybe why you are experiencing the deadly blue smoke. Be
concerned!
The service advisor advised me that the timing belt and water pump needed to be replaced at the same time with a cost of $800.00.
The tundra has $122,000 miles and the above service has not been done.
Is this the correct advice or is he trying to gouge me?
By the way, this truck runs like a top, burns NO oil and is one of the best vehicles I have ever owned.
And I wanting to replace my bridgestone tires [I dont like these tires at all ,at 40 psi its like having skates on the front]
I prefer an semi agressive ,heavy sidewall ,semi smooth ,semi quit ride,handles well with 40 to 50 psi , High milage [50,000 +]
good on snow rain dry and off road,and will handle my travell trailer.
This is a great truck and I couldnt be happier .
Also has anyone out there converted there 4x4 front axle to lockers ?if so ,was pretty simple and affordable ?
Best bang for the buck fulfills all your requirements.
increase hp and mpg ? This is pretty much my soul purpose for dual exhaust .
Thanks again .
Toyota sells a supercharger. I'd have the dealer install that and be done with it. That way you'll have the fastest and quietest Tundra on the street. :shades:
Change the timing belt & water pump, or sell the truck! You could find an independent garage that would do the job cheaper, but I'd be very cautious there, especailly what brand of parts they install I've alway used genuine Toyota parts on maintenance of this nature. Good luck, Steve
Thanks, R Budinich
How the heck do i get to it? wheel well? underneath? I'm lost.
Thanks much appreciated. :confuse:
Further, a third one went out on me about 3 months ago. I found that I'm getting BETTER gas mileage with it out than when it was working....just FYI. A catch 22, if you must pass the engine inspection service light test for a smog test (like in most counties in CA), they will NOT smog test it until it is fixed.
(i.e. engine, transmission, etc.) Not all 5.7s are created equal!
