RAZR and KRZR both have decent battery life. I don't know how anyone can get along without a car battery charger that uses a cell phone in their car a great deal. Hey Cheap Skates get the cobwebs out of your wallets and buy one for $25 at the Verizon store or go to EBay.
Every bluetooth enabled phone should work with this car. If it's on the Infiniti recommended list that just means the particular phone was tested with the vehicle. It doesn't mean other phones won't work.
Likelyhood is, you'd not get your desired numbers sent if it started at the beginning and ended when full.
Does anyone know how to get it to alert me to incoming calls?
Unfortunately....that was the only time the car has successfully connected to the phone. Now it will simply not pair with the phone.... very annoying. Ours are Samsung phones.
I actually now wear a bluetooth earpiece which works in and out of the car....but it would be nice to get a clear bluetooth connection in the car.
I'venever had a problem connecting the phone to the car.....they always find each other quickly.
If you have two phones, you have to tell the car which one you want to use. I wonder if that's your problem.
There's another menu, but I think you need the dealers computer to adjust, but you can adjust the headlights (if you have the auto adjusting option) +/- 15%, which sets the default height which might be of interest.
I believe the headlight adjustment has to do with when the lights come on, not the height of the headlights.
We do have 2 phones (same type of phone), and each is setup for the car, but neither of them will connect despite trying many times. I guess a trip to the dealer is next step.
My only problem is now the Infiniti will only take 40 phone book entries. This day and age, this is rediculous. A meager amount of memory for an address book in $45k automobile.
I stopped by my dealer today so they could verify the bluetooth problems on my 06 M35 and they agreed to put the TSB on my car. They have already done one car and the service manager said that it really fixed the bluetooth problems in that car and the new microphone in the roof liner looked just as if the car came that way.
Note: this is not a recall. Some owners find the current bluetooth works just fine. As with any TSB, it is only applied if you can demonstrate the problem to your dealer with your phone.
Have been trying to get this resolved for a year and finally they cam out with a bulletin that says it can be fixed. Anyone out there have the same problem? What kind of cell phone do you have?
Cindy
Cindy
Cindy
Cindy
Net-net, phone and carrier all exhibit different characteristics with bluetooth on vehicles.
Surely there must be a way to get my contacts into the car's phone directory, but for the life of me, I can't find it. I see that I can set the car to receive the directory...but none of the devices can send the entire directory...that's normally a sync function.
How do I do this?
Why do I think that the same person that decided that it's unsafe to scroll thru restaurant pages while driving on an interstate (mis-)designed the bluetooth phone interface?
So the question remains...the M35 sits waiting for a bluetooth directory to be sent via bluetooth. I have all these bluetooth devices and I can't find any way to actually send a directory to the M35. How do you use this function?
However, is there any alternate way to upload a contact list? Can it be done through the compact flash card? WHat about via the itunes or other cable interface?
Followup question: If i did have a phone that can push the contact list to the M35, is it stored on the hard drive or does it need to access the phone each time? If the first is true, maybe i could use another phone to get my contacts onto the M35 and then switch back to my iPhone?
Larry
I go to menu and click on the tools options. The go to bluetooth, then to options and I can connect all the numbers on my phone to the phone directory in the car.
Therefore I can just say "Dial Cindy Home" and it listens.
Hope that helps.
my iphone does not push the contacts.
My guess is it MIGHT work from the phone if you have voice recognition on the phone turned on and have recoreded voice prompts in the phone. Haven't tried that.
it is hard to understand why a system with a flash drive and other inputs would not support a simple contact file transfer
So far, I've not tried to download our 'phone's directory, but the procedure is clearly spelled out in the 'phone's handbook, and I'm optimistic!
-Karl
I also had my microphones in the car changed and that helped a little.
http://www.bestbuy.com/site/olspage.jsp?skuId=9274778&type=product&id=1218072893- 837&AID=10597222&PID=3357745&URL=http%3A%2F%2Fwww.bestbuy.com%2Fsite%2Folspage.j- sp%3FskuId%3D9274778%26type%3Dproduct%26id%3D1218072893837&ref=39&loc=01
So, after that long-winded introduction, here's the details of...
What I have:
2008 M35x
currently using ancient Motorola Verizon phone
What I need:
BASIC bluetooth phone (Verizon) - no smartphone; no 3G neccessary
:confuse: Does anybody out there have a basic Verizon phone that works with their Infniti which I can easily buy (either through Verizon or another trusted retailer)?
