Toyota Land Cruiser: MPG - Real World Numbers
steverstever Viva Las CrucesPosts: 49,741
edited April 2014 in Toyota
Please post your Land Cruiser mpg here (plus any notes that you think may help others compare, like your driving style, model year, odometer reading, etc.). Thanks,
Moderator - Buying questions? Please include city or zip code and trim you are shopping, FWD or AWD, etc.
  • albivalbiv Posts: 35
    2003 LC with 30500 miles. Mostly city driving (short trips - 2~3 miles)in South Florida (A/C on all the time). Average between 14.5 and 15.5 mpg. I was using 5w30 Mobil 1 but changed to 10w30 Mobil 1 at the last oil change interval. No difference in mileage. Tires inflated to 30psi front and 31psi rears. I rarely push the tach past 2k RPM and I always try to coast to a red light.
  • joe116joe116 Posts: 3
    I have a '06 Land Cruiser with 2000 miles and I have been getting 13mpg around town and 16 on the open road with average speed about 70
  • steelcruisersteelcruiser Posts: 402
    With 285/75 BFG AT tires and a lift (inflation 35F 38R) I'm getting about 13.5 -14.5 mixed driving. On straight, flat Interstates using cruise control and 93 octane, I've gottne 20.2 a couple of times with 18-19 being fairly routine. And yes, coasting when ever possible sure helps. Saves gas AND brakes too.
    While I've found no difference between 89 and 91 octane, I have seen mileage increase with 93 or 94 octane--both in town and on the highway. About 1mpg+
    2002/43,000 miles
  • Around 9 miles a gallon on a 1991 machine. It used to get 14 - so age seems to matter.
  • suedesuede Posts: 3
    The new LandCruiser 70-series will make 23 miles/gallon with the new V8, with more power!
    http://www.4wdcentral.com.au/70seriesdetails.htm
  • f3579f3579 Posts: 1
    I have a 1986 FJ60 w/ a 5 speed manual transmission. Stock 4.2L gas 6 cyl. 2F Motor. 254,000 mi. on the odo. Average MPG is still 13-14. 15mpg on flat hwy cruising @ 65mph. Last year's trip driving 320 miles off road in Baja (mostly in 2 gear and less than 30mph, but a lot of 1st gear and occasional 4WD low I got 10.5MPG.
    I LOVE my LC!
Toyota Land Cruiser: MPG - Real World Numbers - Car Forums at Edmunds.com
