Issue #1: It is very difficult to get this truck in gear at times, when sitting still. As long as I am on the move it is fine. I replaced the bushings at the bottom of the shift lever and it did not help.
Issue #2: Today as I eased off in 1st the truck stalled. I cranked and tried again and it stalled a second time. On the third try I realized that the clutch pedal was stuck near the floor (but I think the transmission and engine were engaged). I pulled it up and pressed it down several times and it eventually loosened and worked fine after that. I have plenty of fluid int he clutch reservoir. Any ideas on either of these?
If you look at your owner's manual, you will probably see a maintenance schedule for the transmission at 100,000 miles. You are far from this milage. If you wish to be extremely conservative on this, you could go ahead and have the transmission pan dropped and the filter replaced (this is all that is probably called for at the 100,000 mile service, not a 'flush') and the 3 or 4 quarts of fluid replaced that is lost when this is done. The cost for a filter and gasket would be about $35 or less, and labor should not be over one hour. $135 at most. I bet the 'flush' would be about $225 dollars or more.
Or, if you have better things to do with your money, do nothing. As I said, you are far from the 100,000 miles that I bet is the schedule for tranny service. UNLESS YOU TOW with this truck. Then, I would change the filter/fluid now.
I would think the tranny service on a regular drive would be 100,000 miles.
The resolution I have come up with is to allow a few minutes for the system to warm up and I find that if I keep the RPMs up the shifting goes a lot smoother. Also, I've noticed that when it is difficult to get into gear, turning on the heating / cooling system will then allow me to go into gear so I'm guessing this is a load issue which is what makes me suspect the slave cylinder.
What I'm doing now, because I believe I may also have noticed slipping is to drive it until it gets stuck IN gear or flat out slips blatantly at which point I will exchange the clutch.
Wish I could be of more help but there are some other issues with the Ranger that I'm still working on - most recently a lit parking brake light on the dash that stays on intermittently (fluids are fine, could be emergency brake switch) and the check engine light that comes on every so often then disappears but the truck still drives normal, no stalling, squealing, pinging, knocking - could be a gas cap issue but like I say, still working on it - the code is proprietary to ford (tried to have it read at two separate shops) so I'm reluctant to dish out $150.00 to have it read when the truck's running fine.
If you do find a solution I'd be ecstatic if you'd let me know.
Cheers!
C
If anyone could help I would greatly appriciate it.
Is this an extended cab, which may have a 'split' drive shaft? Essentially two drive shafts with a bearing in the middle. The bearing may be bad.
99 Ranger 3.0 flex fuel 4 speed overdrive trans.
I noticed tonight that it was starting to whine in the lower gears as well. The fluid levels seem to be fine. Any ideas?
:confuse:
