The transmission was rebuilt about 3 years ago, and has about 5K on it.
The repair shop that replaced the engine says it's not *their* fault. The transmission shop that did the r&r on it says it's prob 'electrical' (maybe a solenoid) and wants $400 to fix (crazy!).
Any ideas?
I have a 2003 Explorer Sport, and I believe it has the same body as a Ford Ranger. It has 58,500 miles and is under a 100K, 7 year warrantly. I was told by my Ford repair shop that I need to have the Clutch Slave Cylinder replaced, and the price is $700 plus, as my warranty will not cover it. They it is not part of the transmission. From what I read in this blog, this appears to be a known design defect with this truck. Although I've been a Ford owner all my life, I think it's time to switch.
My Dad drove Ford trucks all his life, and I have, too - own 3 right now - would NEVER switch to Chevy or Dodge! (don't even mention a rice-burner).
So, apparently, this part can go out anytime, regardless of mileage, and each time, Ford gets to drop the transmission to replace it, and charge the consumer over 5 times the worth of the repair. I no longer trust Ford.
The transmission seems to shift fine. Has a whine in first. Was told this is a normal noise for Ford Rangers. I took it to my local Ford dealer for a transmission analysis. Apparently their diagnosis disclosed no code problems or issues. They determined the noise is in first and reverse. They say it is a "planetary" issue. They want to "further explore" the problem. Stated may have debris in the pan / throughout the transmission. (Extra money to pull the pan of course.) The fluid does seem dirty. Not bright pink as should be. They claim changing the fluid will not correct the problem. It seems to me that changing the fluid and filter could improve the function of the unit. I always thought the filter prevented debris from getting into the unit. So what am I missing here?
I'd recommend taking your truck to some place other than Ford for a second or even third opinion.
Just my 6 cents.
Anybody have a clue as to what's going on? - maybe a short somewhere?
I'm about ready to call it quits.
I have a 99 Ranger 3.0 automatic. I have already replaced the transmission once in it. Now the Over Drive light flashes and the transmission slams between first and second, with the check engine light constantly on. Can someone please give me a for sure answer on this? I would really hate to replace the transmission again for nothing.
It's a 4x4.
It's going to get bad milage.
I have an 02 ranger fx4 4ltr auto. the o/d light started flashing and would shift hard into second gear. I had planned on looking into the problem over the weekend, but on the way home yesterday I was going up a hill hen the trans shfted, then there was no power to the wheels. I coasted into a gas station and now I have no reverse either. Can anynoe tell me what happened and what i should do to get the truck back on the road.
Or, my extended cab Ranger had a 'split' drive shaft. There were two separate shafts, front and rear, with s bearing in the center. This bearing may be your problem, or the mount it rides in.
Driveline 'clunk' is a long-time problem, especailly with Ford products. Some older pickups even had a grease zerk on the spline. Grease on splines helps many times.
an looked at.
Or maybe even a U joint in bad shape.
About only thing I know that can be checked is the vacumn regulator on the tranny and the vacumn line to it.
