Chevy Blazer/GMC Jimmy
lucglucg Posts: 1
Just wanted to let all the readers know that I
leased my Blazer 2 years ago. I put over 46K on it
already, and not ONE problem yet. The brakes are
still good! Unbelievable!! This is a great truck.
I recommend buying the Blazer. I am going to
purchase one soon.
«13456718
  • richman98richman98 Posts: 1
    I have a 1998 Blazer LS 2-door w/ almost 68K miles on it. About 6 months into my lease, the ignition wiring harness shorted out and left me dead on the road. A few months later, my alternator went out. Soon thereafter, it went out again. The recline levers have snapped off both the passenger and driver side seats. One during warranty, the driver side soon after (not the cheapest fix). Overall it's a good truck, I just hope the redesigned 2001 is a lot more solid like they claim to be.
  • sdc2sdc2 Posts: 780
    I had a 97 Blazer, put 55K miles on it with nary a problem. 6 months ago I traded it for a Trooper (needed more headroom). Just heard that the people who bought my old Blazer had the tranny go kablooie on them. That's a $2,000 headache I'm glad I don't have.
    Just goes to show, 46K miles without a problem isn't necessarily a trend...
  • Tranny life may be shortened due to a design flaw with the ATF dipstick/seal. The defect is it doesn't seal out moisture, and with it positioned below the passenger windshield washer nozzle, moisture can get in the fluid. So without periodic fluid changes, the tranny life may be shortened. On my '97 Bravada, I had the dipstick and the dipstick tube replaced under warranty at 24K last year. I also changed the ATF and filter at 30K miles, and replaced it with Mobil 1 ATF, since it has better heat tolerance than the std. Dex-III fluid. Incidentally, I periodically pull my boat with it, and live in a hilly region, so I think the tranny gets taxed more than a "normal" highway SUV, for example.
    No tranny problems, and the truck just turned 40K miles.
    Oh yes, my alternator and the belt tensioner developed a squealing bearing at 25K miles, so they were replaced under warranty. My '93 Grand Prix had an alternator let go electrically at 36K miles.
    My advice: if you own a GM, odds are good you'll replace an alternator at least once before 100K miles. Replace it with a remanufactured aftermarket (quality) alternator, NOT a GM re-man!
  • Thanks for your helpful input, poisondartfrog. I need to squeeze better than 200K miles out of my 1990. At 130K so far. I managed to get 120K out of the alternator and the tranny is still going strong (knock on wood). I change the fluid somewhat regularly, but I'll take your advice and try the Mobil 1.
    I'm going to push another six months on the front end, but it's shot. I need to do the whole works. The good thing is that the old models are easy to work on and parts are cheap. But if you can't do the work yourself, the Blazer is definitely a rather expensive truck to upkeep.
  • If you put deep-tread knobbie tires on a Blazer (which I wouldn't recommend), would the resulting vibration tear up the trannie any more quickly than AT M+S tires? What's a good type for 50/50 paved road & gravel driving?
  • I'd be more worried about the bearings in the differential. I bet the crazy harmonics from the "knobby" tires on concrete/asphalt would accelerate bearing ball/race wear.
    I'd check www.tirerack.com for an AT tire (Michelin & Dunlop come to mind). You probably want the LT rather than the P series tire - gives you better load capability (stiffer sidewall) and 1 or 2 more plys.
  • sandys2sandys2 Posts: 2
    I bought a used 1996 blazer last april 55.000 miles i also purchased the extenedted warrenty seems my tranmission had water in it and the warrenty will not cover it. ? why would i have water in my trans/
    but paying 2,350 for a new transmission
  • GM has a service bulletin about corrosion of the dipstick and corrosion of the dipstick tube. I had it on my '97 Bravada, which was fixed under the 3 yr./36K warranty. The fluid was also changed out (very iimportant).
    It seems the seal on the top of the dipstick is poorly designed; it allows water to get into the tube, and thus, the transmission. The source of the water can be from the passenger windshield washer nozzle/plumbing, or the water leaking past the nozzle seal. The trans dipstick is located right below!
    So it's two-fold - water drips into the tranny through the dipstick seal, and the rest of the water corrodes the outsie of the tube. Check the '97 Blazer forum for more instances of this problem.
    I would fight the warranty company on this one. As a design flaw, you shouldn't pay to replace the tranny.
  • Bought Blazer new in 10-98. Recliner mechanisms replaced 3 times, and adjusted, and "cannot detect problem" another 5. Design problem per rep, potmetal used. Failure on 2 door blazers and x-cab Chevy s10. This vehicle has been a nightmare, 35k miles, idler arms, trim, short in instrument panel, more than I care to remember. Pages of dealer visits-must have been one of those Monday or Friday vehicles !
  • I own a 97,,,and all of the controls and switches seem to be lit up ,,,all but my headlight switch,,,does the switch cover come off? I didn't try to take it apart,,It looks that there might be a micro bulb behind it...also I have a question,,my tires seem to lose air pressure,,I might have bad valve stems,, or is it a problem with these aluminum rims...
  • I too, owned a 98 lemon blazer......it's not to late for you to file a lemon law claim! GM knows they produced alot of these bad blazers. I owned my 98 ZR2 for two years, 36 service visits, (generally unsuccessful service visits)....bad loaner vehicles, crappy treatment from reps at the 1-800, we have your money, we don't give a [non-permissible content removed] hotline( aka customer service). You don't have to live with the nightmare, although it took 2 years to return the lemon to GM,1GNCT18WXWK149605, I got my money back, recovered my attorney fees, and resumed a normal life instead of sitting at the dealership listening to lame excuses for my vehicle problems.
  • I have a '98 Blazer I leased new...last year as the temps changed, I was having problems with the battery draining overnite...nothing on...but it was dead in the morning...they told me the battery had a dead cell...i replaced the battery with a Diehard(instead of the cheap A/C Delco)...this year as it gets cold...same thing...its happened for the dealer when at the service dept. but they say they cant find anything draining it...well, SOMETHING obviously is...went back in today for the 5th time in a month...anyone else had any similar problems? everytime they say the battery and alt. check out ok and they cant find any drains on the system!!
    Im ready to "lemon law" it!!!
  • Richman, read my posting..#13...is this what yours was doing before they found the wiring harness short?
  • There is definitely a short. The trick will be in finding it. There are only about a million things that could cause it. I once had an old Honda that did that. Fortunately, it took two days to drain the battery and it rarely sat for two days. Good luck finding it. Does it have a block heater?
  • Hello
    I was wondering if you could maybe help me out, my 1997 Blazer has a problem with its front wipers. The wipers work fine all the time except when we need them, they work almost all of the time but once in a while they go totally dead, including the washers. This has happened 5 times this year almost always when it starts to rain, I have been able to start the wipers by manually pulling on the arm from outside the vehicle and then they work fine, could this be the control module?
    If it is the control module where is it located and what is the best way to replace it?
    Thank You
    Also is there a recall on this problem Thanks again
  • I HAVE A 96 BLAZER. LOVE IT TO DEATH, BUT YES I
    HAVE A BUT IN THERE CHEVY. CHEVY NEEDS TO LEARN HO
    TO MAKE A BLAZER CORRECT. I WAS DRIVING DOWN THE
    ROAD AND MY TRUCK TEMP WHEN UP TO 260 AND IT IS
    NORMALY AT ROUND 210(RIGHT) WELL I TOOK IT IN TO A
    GOODYEAR, AND I WAS WATCHING THEY WORK ON IT. I
    DECIDED TO CHECK MY RADIATOR AND GUESS WHAT I
    FOUND. MUDD NO WATER JUST WAT MUDD!! SO PISSED OF
    I CALLED CHEVY AND THEY SAID IT'S A COMMON
    PROBLEM. HERE'S HOW IT HAPPENS. RADIATOR FUILD
    NEEDS TO BE CHANGE EVERY 2YEAR. I SAID OK FINE, BUT YOU HAVE TO USE THE SAME LIKED OR FUILD EVERY TIME OR THIS WILL HAPPEN, UNLESS YOU GET A 19.95 BOTTLE OF CLEANER EVERY TIME YOU CHANGE FUILD (2YEARS)NOW HOW MANY PEOPLE KNEW THAT! AND HOW THE HELL AMI GOING TO TELL WHAT KIND(BRAND)SOMEONE PUT IN MY TRUCK IF I BROUGHT IT USED OR IF I GET A SHOP TO CHANGED IT. SO I HAD TO GET A NEW RADIATOR AND $368
    CHEVY DEARLSHIP(JERKS) AND BUT BEFORE THAT CHEVY
    SAID LETS TRY TO FLUSH IT x2 SO I PAID $222.03 TO
    FLUSH IT TWICE AND THEN THEY TELL ME THAT IT NOT
    GOING TO WORK, BUT I HAVE TO PAY FOR THE
    FLUSHES.(JERKS)AND I NEED A NEW RADIATOR. AND THAT
    $368 THAT THE COST OF THE PART NOT THE LABOR. I
    HAVE HAD THE OTHER PROBLEMS THAT OTHER PEOPLE TALK
    ABOUT TOO.DIPSTICK AND O2CIN AND WINDSHEILD WIPER
    MOTOR, AND RUST UNDER THE SEAT. THE A/C DOESN'T
    WORK AND I'M NOT FITING THAT UNTIL SUMMER I JUST
    PAID $745 DOLLOR TO GET THE DAMN THING ON THE ROAD.I PUT OVER 3,000 DOLLORS INTOP MY TRUCK NOT IN REPLACING PARTS BUT MAKING IT A NICE
    TRUCK,TINT,STERIO SYSTEM, REMOTE SARTER, RUNNING
    BOARDS, AND EXHAUST AND MUCH MORE. I'M 20 YEARS OLD AND SPENT ALL THAT MONEY TO HAVE A NICE TRUCK ANDI'M STARTING TO THINK I SHOULD OF SPENT 16,000
    DOLLORS ON A DIFFRENT SUV AND THEN PUT THE 3000 OR
    SOME DOLLORS INTO IT.I LIKE THE LOOK OF THE BLAZER,BUT NOT THEN IT COMES OUT OF MY POCKET. THE
    DEALER CALLED IT MISSIPPISSI MUDD IN MY RADIATOR. I LIVE IN VIRGINIA NOT THERE. IF ANYONE HAS HAD
    PROBLEMS LIKE THIS PLEASE E-MAIL ME
    @BRASNICK12@AOL.COM OR BLAZER1202@YAHOO.COM
    WE CAN TALK ABOUT THE PROBLEMS WITH THE BALZERS
    AND MAYBE SAVE SOME MONEY.
  • tug3tug3 Posts: 1
    The problem with your wipers is going to be the motor itself. Just like the starte n a car, when it goes bad, it wont work, but if you apply power to it, and jar it, like tapping on it or forcing it to move, it will work. Once it stops, it depends on wether or not it stops on the "dead spot" if it will start working on its own next time.
  • 89n9889n98 Posts: 1
    I own 2 blazers. An 89 and a 98. The 89 has 140,000 on it and still runs strong. Beyond normal maintenance, I've only replaced the Battery, Alternator, and some throttle body gaskets.
    On the other hand my 98 LS 4door has put me in the dealer waiting room a couple times. At a little under 10,000 miles I had it in to replace some axle bearings.
    Just at 36,000 (ok a little over but the dealer was good to me) the alternator left me stranded in the grocery store parking lot.
    Then at 39,000 after some highway driving the transmission would slip and shift really hard. Yep they rebuilt the trans. Luckily I did purchase the extended warranty for the drive train(still had a $250 deductable). I wish I would have gotten the full 60month warranty.
    Now a few weeks ago and sitting at 45,000miles, Chicago got that 16inches of snow and I'm crawling to work pushing the 4x4 button and the back end is still coming around. NO 4WHEEL DRIVE!!!!! So I'm thinking its from the trans rebuild. Dealer comes back with "the battery wore away a vacuum hose for the 4x4 solenoid." But how can I complain when I leave the dealer and the bill is under $100?
    Oh I forgot about the lumbar support that when I was adjusting popped and doesn't move anymore.
    And what's up with the 95mph governer? Is someone really trying to corner one of these things at 100mph?
    Don't get me wrong, I love this truck. I could go on and on about how this is a great truck, but what happened to reliability?
  • 89n98, I hear you. I've done what I call the "typical" repairs to my 1990. It's had a hard life and has held up unbelievably well (except of course for the paint job). It's nearing 140k and I'll be rebuilding the front suspension. Based on the roads it's been driven on for most of its life, I'm not about to complain. When my wife's Nissan crapped out (it WAS a piece of crap) we went to look at the 1999 Blazers, since our 1990 had held up so well. I was appalled at what they wanted to charge me 24K for. It didn't drive or handle as well as the 1990 and there were already rattles. I had also previously tested a used 1995 and wouldn't have given them 1/4 of what they were asking. It was possibly the most awful truck I'd ever driven. Thanks, but I'll just keep my 1990... possibly forever.
  • ryanbabryanbab Posts: 7,240
    My mom has had an 87 and 2000 blazer
    I have driven both probably have drove the 87 more than the 2000.
    87 was a 2wd 2 door 2.7L factory ordered back in 1987. Truck was great first month there was a hose recall (we broke down and had to be towed) but never had a problem after that. It was only in for some minor rust fixing in the late 90's. Truck was solid and we sold it for $1500 early this past summer. I see this truck everyday at school and its still running with 120,000 some miles on it when we sold it.
    2000 is an LT 4wd 4 door with about 11K miles. Not a bad suv. It has its pros (4wd, more gadgets,4 doors easier entry exit, sunroof, leather better engine 4.3) and its cons (not as solid seems weaker, doubt it will last 13+ years like the 87 has) over the 87 blazer. The 2000 has been in the shop 3 times. Twice for alignment which was corrected after about the first 2 months and last month a front diff seal was leaking which is now fixed.
    I personally would take the strong feeling of the 87 and combine that with the 4wd, 4 dr, and gadgets of the 2000 and it would be a perfect truck.
    89N98 i know what you were going through with the snow. I live in indiana and we got a bunch supposed to get more tonight. I think my silverado handles alot better over the blazer in snow (weight wise more than likely)
    Ryan
  • What to buy and seeking advice by sasquatch_2000
    Looking at a Pewter 98 LS 4 Door with 40,000 miles on it. Dealer price $18,000. What is a good price to hit him with? What problems should I look for? Do I gain anything appreciable other than cosmetics by going to a '99? This one has the 5 spoke wheels with worn 235/70R15 tires. What are the biggest tires I can put on these? Can I get 245/75R15 or 255/75R15? How about 30X9.50 or 31X10.50 tires? Do I need a lift kit to mount these? Are lift kits available? I plan on doing some exploring this winter and summer, and want some good clearance. Also, anyone have experience with aftermarket header/exhaust/chip for power/mileage/reliability improvements? Thanks in advance.
  • Look at my post #20 for some things to look for. My opinion, $18,000 is a bit much... I paid $14,000 for a '98 Red LS 4door w/ 36K on it over a year ago. Got my '98 Bravada for $18,000 in May '99 w/ 40K on it. I do not know of any "cosmetic" changes from '98 to '99 other than a few added body colors, the side mirrors are hindged differently, and the daytime running lights shut off when the turnsignals are on.
    Good luck on the mod's, I have no idea. I'm just as happy when my two run :)
  • "When my two run"? That seems to be the sentiment about Chevys and sometimes JEEPs. I think I am starting to lean towards a Pathfinder, XTerra, or Trooper. Thanks for the words.
  • I have a 92 S10 Blazer (Tahoe) 4.3 liter engine that developed a bad oil leak. It's leaking from the "area" where the oil filter usually screws into the block next to the oil pan. I say usually because my oil filter is up near the radiator and is connected by two hoses to an "adapter" that is down below next to the oil pan. Does anyone know what this adapter is or how I can find out more info on this, such as how to replace or repair? thanks much,
  • drew_drew_ Posts: 3,382
    You may also want to post your message above in the Chevy Blazer - Topic consolidation discussion topic and the Maintenance & Repair message board.
    Good luck!
    Drew
    Vans, SUVs, and Aftermarket and Accessories message boards
  • I am looking at buying a 2001 2door 4X4 Blazer and I can not find any crash test info on anything past 98. Would anyone know how they handle on the road? I am not concerned with a bumpy ride, but what I would like to find out is if it is tippy. The 97 and 98 reviews made reference to taking it easy in the turns but that was before the new body style came into effect. Any info would be helpful
  • hengheng Posts: 411
    I think they are better than the minivan I had. And no, the minivan did not have worn out shocks. And with the premium Bilstein shocks they do not have a bumpy ride. In fact, the body-on-frame construction actually is smoother riding than the unibody construction of a minivan. It isolates road texture and other small stuff better.
    Make no mistake, SUVs are not to be driven like sport cars, or sporty sedans for that matter.
  • My 98 Jimmy with 36k miles gives off a burning smell from underneath, in the rear end. Took it to the dealer and they said the rear brakes were seized. Replaced everything for $900. Said it was 3 months over warranty.I still have the smell, dealer can't find anything wrong. It's worse after I wash the truck or when the roads are wet.
    Any help?
  • I have a 2000 Blazer and I'm trying to program my remotes, I just bought a third one. I found the steps below and they seem to work until I get to step #7. At this point none of the remotes respond. Am I missing something? Are there any web sites or newsgroups that might be able to help me with this?
    Mike
    _____________________________________________
    (1) With driver door closed, hold down power unlock button on door panel (and hold down until step #6)
    (2) Turn ignition switch on
    (3) Turn ignition switch off
    (4) Turn ignition switch on
    (5) Turn ignition switch off
    (6) Release power door unlock on door panel; the remote receiver will respond by locking the doors and then unlocking them.
    (7) Hold down the lock and unlock button on the remote transmitter until the receiver responds by locking and then unlocking the doors (about 7 seconds typically).
    (8) Repeat step #7 for each additional transmitter that is to be used with the vehicle
    (9) Turn ignition switch on to exit transmitter programming mode. Note that previously programmed transmitters will be deactivated after the programming procedure.
«13456718
