Don't let this issue sour you on the S series vehicles. I have had five and all have been very dependable vehicles. I have to believe that these guys are missing something obvious like a motor or tranny mount loose, spring pad missing, something like that. There just aren't that many things under there to go clunk.
Jim
(ducking and running for cover :surprise: )
Im stumped...1995 GMC Jimmy, The ECM fuse (fuse #10) keeps blowing in my truck, which causes the truck to stall out until fuse is replaced. I've looked for loose wires, shorts everything and I cant figure out why it keeps blowing! Anyone have any help? What should I check since its just the ECM fuse blowing?
Darren
On a different subject....through all the searching of problems....I saw that a MAJOR issue with these newer Jimmys that use dexcool is that the heater cores clog(I see that post ALOT) I'm wondering if its from everyone says DONT let dexcool get low or it will sludge up.....well, what happens to your heater core when temp switch is set to A/C or the cool setting.....it closes the valve to allow coolant to flow through the core, so in my eyes....thats the same as letting it get low, and I'm thinking thats why it sludges up in the core......from driving in summer months with the temp set to cold(coolant just trickles through the core clogging it up!!!!! IS THIS CORRECT??????????should I switch to green coolant to avoid this problem? or will it mess the gaskets up??? :confuse:
The biggest problem with dexcool it that GM was being more than optimistic with the life span. If changed every 5 yrs, 60K miles, it doesn't seem to sludge up. But if you let it get low and get a lot of air in the system, problems.
And never, ever let someone "top it off" with the green stuff. If this happens, the whole cooling system must be extensively flushed. The two chemistries just do not play together at all.
Darren
Thanks, iSOiA
Thanks, iSOiA
My power locks work, BUT neither power seat does.
I have the 96 Blazer
It means that your piston has become deformed due to excessive heating which, in turn, was caused by your head gasket problem.
SUVs and Smart Shopper
I was thinking about converting my rear mounted spare tire to be inside of my truck, anyone know if there is a way to do this?
I have wondered why they didn't put a small spare in there. I am supposing it has something to do with that little doughnut being completely useless in an off road flat tire scenerio.
Then again, with four inches of ground clearance, my xTreme sees pavement only!
sometimes the SELight comes on...other time it doesn't I've taken it to 3 mechanics....no one can figure it out...Have gotten two codes...MAPS sensor bad...Replaced...fuel pump, dist, cap rotor....plugs...wires....crank sensor...cam sensor..ignition lock assembly...One mech already told me the CAT was fine..
Any help would be appreicated as I am at a loss...Planning on giving this car to my kid next month but it has to run right first...thanks again for any ideas.... oh I forgot...replaced the computer...also...got a code once that says engine is -7 degree on timing...can't adjust since the bracket is notched and holds dist in postion...also...sometimes the cruise works..sometimes doesn't...and sometimes only one side of the speakers play...help please.....
Another dirty little trick; if you do not hear the pump "prime", take your foot and kick the bottom of the fuel tank. Don't try and cave it in, just give it a good thump. Then cycle the key and see if you here the pump prime, and start. Common failure in GM fuel pumps for years is that they get "stuck" and won't spin up. Give 'em a good thump and they will work again. For a while. Once they get to this point it's time to change them out. I have seen this on pumps with less than 50K miles on them.
Good luck
An thoughts?
There are other guys here who are better at A/C than me, but I seem to recall that is the cause of your symptom.
