I have the same problem. The tail lights and parking lights work, but no headlights. The high beams will work, but only as long as you are holding the lever back.
Did replacing the switch solve your issues?
I believe the problem may be, the Day Running Ligth Sensor.
I would like to replace it myself.
If you have any information, about the location of the
above sensor, please let me know.
Thank you very much.
The power unlock doesn't work from any switch on the passenger door. Lock works on it, but not unlock. I have checked both switches and the mechanisms, but those all work. My thoughts is that it is a single dead wire somewhere? It is none of the wiring in the passenger door but that's all I have checked. Anything else I should be looking for?
The related OBD trouble codes indicate P0141 (O2 sensor heater circuit bank 1 sensor 2) and P0404 (Exhaust Gas Recirculation control circuit range)
My car has started to die on me now. I was told that it could be the fuel pump. It's in the shop now, so we'll see.
Fuse (if a seperate fuse, not sure)
Fog Lamp switch (is it really working)
Relay
I asked about the high beams since the factory wired fog lamps will go off when the high beams are turned on.
