Suburban Tahoe Seat Questions
I bought a 2006 Z71 with leather seats in the middle row. I have a kid on the way and was test fitting the car seat. it didn't fit well in the buckets and would like it in the middle better. can anyone tell me how I could or if its even possible to swap out the buckets for the split bench. the parts guy at the deal said I would have to buy the seat part by part and didn't want to total it up for me. I did't get the feeling that he really cared anyway. can anyone help?
___________________________________________________________
He probably didn't want to total it up because of the price. These seats are incredibly expensive to order from GM. For example, I was quoted a price for a factory order for a Suburban leather 3rd seat....of nearly $2,000 and was told "that is if we can even get it". Seems there is no stock on this kind of stuff so GM has to actually pull the seat off the line then do shipping and handling, etc. They really don't want to do it...therefore the high price and limited availability. Your best bet would be to try to find a middle seat on Ebay....I know there are plenty of 3rd seats for sale. Middle seats probably much harder to find though.
I have a 2007 Suburban and have no problem getting a 4x8 sheet of plywood in the back. You need to have the 2nd and 3rd rows folded flat and it goes in nicely and the plywood sits flat (a couple of feet before the tailgate are up in the air). Yea the Expy has the "fold flat" seats with a power fold option but you can remove the 3rd row completely in the Burb, tumble the 2nd row forward and have a pretty decent cargo capacity. You can also get a cargo mat that covers from the tailgate to the 2nd row (with 3rd row removed), protecting that GM carpet from Fido...
-- Gregg
Boston, Mass
I have a 60/40 3 person bench seat on the second row and a 50/50 2 person bench seat in the rear. I can remove the third row seat but can only tumble the second row forward. (The second row is not removable). So, how do you "fold them flat" when, at least according to GM, they don't
Carl
Fold the 3rd row flat (do not tumble forward) and also fold the 2nd row flat (do not tumble forward). The folded flat 2nd and 3rd rows are at the same level (at least they are on the Suburban) and a 4x8 sheet of plywood fits nicely. If you tumble the 2nd row forward you cannot fit an 8 foot item behind the seats and close the rear hatch.
-- Gregg
Boston, MA
i just started researching. did you find the problem?
I want to take the seat cover off, but I'm afraid that I might trigger the airbag. Does anyone know how to disarm the airbag?
Additionally, I think since the problem started, occasionally my airbag light will come on, and my engine will hessitate a bit. The light turns off, then the engine runs okay again.
Anyone selling a 2nd-row bench, or who would like to swap?
I'm in CA, SF Bay Area.
It use to go up about another inch or two higher. Well I guess I'll just have to live with it unless someone post a message on how to repair the problem. I'm not going to take it to a auto shop and pay hundreds to fix what isn't that bad.
I'm guessing there could be either a mechanical problem, or an electrical problem. On the mechanical side, I'm guessing that there are worm gears with position sensing switches, similar to many garage door openers. Worm gear turns until it gets to the max position and a switch senses it is at max (or min), and turns off the motor from going further. Perhaps this switch is loose or bent somehow, perhaps the worm gear is loose or bent, perhaps the seat scissor mechanism has something jammed in it that won't allow it to go to full extension (like a bolt that worked loose). You may have to unbolt the seat from the floor and turn it over, to get a better view of everything.
Electrically speaking, I don't know if the Z71 has the auto-position memory functions. I'd try resetting both of those memory positions, wiggle all of the switches back and forth as perhaps one of the switches has gone bad.
Sorry can't be of much help, I'm really only speculating as to what I'd look at.
can also email me at robert.lombardi@us.army.mil
brandon.carder@risd.org
214-282-5056
Dallas, Texas
Fort Worth, Texas
___________________________________________________________________
Check out Ebay and your regional Craigslist...you'll find a seat.
I live in Los Angeles. Condition is like new.
Lloyd
Nebraska
lmcintyre@hastings.edu
Ricky G
Be sure to check the wrecker yards
I am looking for captains seats for a 2001 suburban in Grey cloth in good condition. What do you currently have in your second row?
mari
Warren
