Ford Escort Engine Problems
Have a question about an engine problem? Post it here and get the help and advice of other Escort wagon owners.
«134
    beachlovbeachlov Member Posts: 2
    Need alittle help asap please. My engine had shut off as I was driving and the check engine light came on. Could not re start car and had it towed. Any ideas what may have caused this and the cost of parts to repair? Thanks for any replies. Beach
    liranrazliranraz Member Posts: 1
    I have a ford escort 96 station wagon.
    The "check engine" indicator had turned on and didn't turn off.
    After a few days it turned off, and now it's not turning on when I'm starting.
    Anyone know what is the meaning of that ?
    Do I need the car serviced immediately ?
    Lira.
    vr5vr5 Member Posts: 1
    I have a 95 escort wagon. It has been in the family since new and has 124,000 miles on it. 4spd auto. The check engine light has been coming on for quite sometime. However Ford has been unable to pull any codes, and wants an outrageous amount to check the car system by system. The car runs and drives fine, however occasionally on the highway the car will surge, as if the fuel supply were being momentarily cut off. Also when the car is warm sometimes I have to really crank and crank the engine to get it to start. Recently the car has started stalling if you don't veeerrryyy slowly take off from a stop when the engine is cold.
    Any ideas?
    93escortwagon93escortwagon Member Posts: 3
    Hello forum crew. I was hoping to get some expert advice for some experienced escort owners. I just snatched up a 93 Escort Lx 1.9 auto, SFEI wagon. The car is nice and clean 75,000 miles,but of course you new it was coming. Here's the problems. The car stars right up and idles fine in park. If put in gear sometime it stall's and has rough idle. When driven up through the gears its great. The problem is if you start in drive form a dead stop the car will start to pick up speed, Then into second gear and now your going 25 mph.(FOOT OFF THE GAS)This will also happen in reverse.(WOW NOT COOL) But wait it get worse when you try to stop or when the trans down shifts from 2 to 1st just before you come to stop. The car jerks into 1st as if it was being forced to down shift at a high idle. I had the computer checked on the engine it showed no codes or problems. Maybe some trans problems??) I know someone out there in Escort forum is sharp enough to get this one. Well I hope so. For you rookies like me any help will be great and thanks to all. Steve
    vandeadvandead Member Posts: 1
    check to see if the vacume lines and fittings are in good condition. My standard shift wagon had a good idle, but under load and at higher rpms it would chug and run like [non-permissible content removed]. There is a rubber coupler on the manifold that connects to a hard plastic line that goes to the pcv valve.
    the rubber looked okay but was deteriorated and collapsing when at higher vacume levels.
    when replaced it ran tip top
    rroseckyrrosecky Member Posts: 1
    3/7/06
    I owned a 93 1.9 Escort. I had 'overspeed' problems. No sensor lights came on. It turned out to be an easy to replace Throttle position sensor (You can buy online ... use Google with "ford parts escort". Now I own a 96 1.9 Escort. These are really reliable cars. Good luck
    Dick R.
    clarson4clarson4 Member Posts: 1
    hi all!!! was just wondering if any one could help me out?
    trying to fix my girlfriend's 92 escort wagon; it's hard to start when cold and idles very rough. but it also wants to stall at stop lights. the car has no power and has a very hard time starting out. also noticed it back fires lightly? just did spark plugs and wires. could it be a coil?? any help would be great thanx
    earthssonearthsson Member Posts: 2
    :cry: My escort wagon is idle very rough, it is like it wants to stall now and has. Today I replaced the plugs and wires. Could it be the coil?? injectors??
    I think you may have had the same problem and I am wondering what fixed that problem for you??
    :sick:
    My car and I need your help, thank you.. Jord
    mine is a 96 escort wagon, 1.9 liter.
    It ran out of gas and has seemed to have gotten worse as well. Thew only time in my life I have run out of gas and I think it will cost me. Off the start it has no guts and takes time to get going. Sometimes the idle is so rough it hurts me ;)
    Changed the fuel filter and air filter, thinking maybe the pcv valve change???
    mdhugmdhug Member Posts: 9
    95 Wagon Auto 1.9 According to my neighbor she was driving when the car just cut-off. Checked timing belt and it is like new, It is getting spark at all four plugs and it is pumping fuel when I checked the bleeder valve. Hope someone can help!!! One bad thing is it sounds very funny when trying to start and has about 1-2 quarts over the full line for oil. Could the motor just be gone??? She said it started and shook violently for 3-5 seconds. It will not start for me and backfires through there air filter housing. Any help is appreciated. Has 93k
    sam8thsam8th Member Posts: 4
    car has less than 68k miles on it. had to fix the air conditioner (dryer replaced) and then just 4 days later, car breaks down for first time ever! turns out my harmonic whatever was out of balance. so another costly repair.
    could this harmonic imbalance problem have been caused by the air conditioner repair? cause it sure seems questionable that my car would break down for the first time 4 days later.
    any thoughts? anybody else heard of this repair? thanks!
    jaddyjaddy Member Posts: 1
    will the engine out of a mercury tracer 1.6 liter bolt up to a 1993 ford escort gt the monts look like they are in the same place please let me know by my email addyjohn_l@hotmail.com the mercury is in bad shape but he escort is in good shape other than a plugged radiator and a blown head gasket but worried about a crack block or head please reply :cry:
    madmartianmadmartian Member Posts: 2
    The temperature of the air coming out of the air vents on the dash is never cold. The compressor is working.Can someone give me an idea on how to find out the problem?
    after wasting several dollars on a recharge kit, i took my car in for an air conditioner check and had to have a dryer replaced, ac refilled and oil for ac and was worth every cent.
    the ac check was free with a coupon, but i've seen it advertised for 30-40 bucks for a checkup on ac. maybe the shop will put the check cost towards the repair??
    sounds like what my car was doing. no cool air. compressor was fine.
    d_rockd_rock Member Posts: 1
    i have a 93 escort 1.9 lx that started idleing high then it would dropd dwn sometimes so far it would stall. it would drive fine in cold weather till it warmed up then idle rough. now its doing it all the time. i replaced the idle air control sensor the throttle position sensor and the fuel filter but it stil drives the same. i did a check engine test and the car wouldnt respond. has nebdy had this problem before?
    retpmonretpmon Member Posts: 1
    I have a 1992 Ford Escort LX 1.9 with 187,000 miles on it. In the last 2 months I got the Alternator and the steering wheel pump and belt tensioner change, plus I put new ignition cables and spark plugs. It runs good, but when I am going 55 to 60 miles per hour up hill it seems like the car cylinders get lost and don't know which one should fire and the car start shaking and I have to down shift gear from 5th to 4th and then is ok. Anybody knows what is going on?. Thank you
    radarmaxradarmax Member Posts: 1
    When I got this car it had a broke timing belt and the battery had been hooked up backwards. Also the fan has been wired to run whenever the eng is running. I have replaced the timing belt, alternater, 100a main fuse, head gasket and bolts, t/stat and #2 inj. The fan is still wired to run when eng does. When the following are disconnected it has no effect on the engine: TPS or Air Charge Temp Sensor, disconnecting the MAF Sensor causes the eng to shut off. For some reason when I try to retrieve the eng codes it does not work like the manual says. I have checked every thing I possibly can using a Haynes Manual and this is what I have: At first startup the RPM's surge about 300-500 and as it warms up it stops surging ALL MOST, still has a very slight surge. It idles rough, like intermittent firing. I can remove the #2 (new inj) plug wire and can not notice any change in eng, I have power to the inj and it ohm's out within specs. The TPS has 5.05 volts going to it. Is this normal or should it have 12v? When the eng is switched off it keeps running for abt 3 seconds before it stops, and the tach goes all the way to the high side of the gauge. When the eng is restarted the tach does not move until you rev the eng up to abt 2,000. Any help would greatfully be appreciated. Thank you. :sick:
    rhodesterrhodester Member Posts: 1
    OK my buddy has a 1990 ford escort pony.he was driving and something happened and it just died.now if im not mistaking i had a 93 escort that had a fuel relay shutoff switch in the driver side rear corner panel.would a 90 have the same thing in the same place or would the switch be somewhere..or not have one at all.the car will turn over but wont start.and the fuel cutoff light turns on when trying to start..any help asap is appreciated :confuse: :mad: :cry:
    aandpaandp Member Posts: 1
    I have the same problem. I changed plugs, wires, ignition control module, fuel regulator, fuel filter, O2 sensor. Compression check is 180psi. Swapped ignition coils with an old one. I think its the ECU. But I am going to turn up the throttle set screw first. No check eng light. Used the obd1 scanner no communication. Jumpered the plug. the check engine faulted 02 sensor. Already change that. Out of ideas. When it warms up runs like cramp during idle. After a minute at the light it shutsdown.
    jpescortjpescort Member Posts: 1
    I have a 93 ford escort wagon with a 1.9l. The check engine light was on for a while and then it just died one day. It will start back up if left for a while, and run for about 4 seconds before dying. After starting it will run fine, I held it at about 5 grand and there was no sputtering or anything and then after about 4 seconds something cuts it out. It just dies completly with no sputtering. Any advice would be much appreatied. Im thinking it has to be some sensor but i dont know what to try.
    fordman77fordman77 Member Posts: 1
    WHEN YOU TURN THE KEY ON NOT STARTING IT JUST TO THE FULL ON CAN YOU HEAR A WHINEING NOISE IF SO IT IS THE FUEL PUMP OR FUEL PUMP RELAY...THIS IS TYPICAL WITH AGE AND MILAGE, ALSO IF THAT IS THE PROBLEM I RECOMEND DEALER PARTS ON THIS AS OEM FUEL PUMPS LAST ALOT LONGER THEN AFTERMARKET ONES DO AND IT IS ALOT EASIER TO GET WARRANTY ON..
    lostyanklostyank Member Posts: 2
    1999 Escort Wagon, 2L, manual, upgraded to everything past SE except choking seat belts, 130K miles.
    At 120K engine lost two head bolts (cracked just past the head) on opposite corners ... right rear, left front. Replaced timing belt, water pump, shipped out the head (everything fine), etc. Since then the idle, when warm, stays at roughly (no tack) 1300 RPM for several minutes, then falls to roughly 600-700 RPM. "Give Ford $" light now stays on. Speed will not hold steady when car is ideling high ... I can't put it in 4th gear & hold speed, it falls, but not to proper idle. Mechanics have not fixed the problem. Over the last 10K, problem has increased in the duration (up to 2 minutes now) till normal RPM. This only happens when engine is at normal op. temp. & driven for 1/2 hour +.
    Thanks for your advice.
    osokthedevilosokthedevil Member Posts: 1
    ;) if you are finding that your starter on your escort just clicks, replace you body grounds and main power wire for the battier and add 2 more body grounds to you car. the clicking of your starter will stop and everything should go back to normarl again. like a 0 gage wire from the engine to the chase of the car and make sure they are well clean. ;););)
    goatman54goatman54 Member Posts: 2
    Hi im new here and was wondering if someone could help me out. My daughters boyfriends car is making a metalic noise when he revs it up. It idles fine with no noise but when he revs it up it makes the noise. It kinda reminds me of the older cars being out of time. I don't know squat about these newer cars so can someone out there tell me if it's possible that this could be the problem. Also, how do you time this car. thanks in advance.
    My daughter went to advance auto today and had them hook up the dianostic reader. The code was...P1744 Torque Converter Clutch System Stuck in Off Position. What does that mean and is it something i can fix.
    rhoelrhoel Member Posts: 1
    Hi, i have a 98 ZX2. Just recently broke the timing belt and brought it to mechanic to have it replaced. it runs good but the problem i'm having is, that the car keeps stalling after a 100km or so. i would let it sit for about 10 to 15 min and it would start again after it cools off and it would let me drive it again but not longer this time maybe 30 km and it would stall again :confuse: . cooland seems to be ok and it's not smoking or anything like if it's overheating. i just replaced the spark plugs i though maybe its the plugs but still the same thing.
    it has 220,000 clicks on it and it runs pretty good till u drive it for a while then it starts to act up.
    Anyone knows whats causing this ?
    Would really apreciate if anyone could help me.
    Tks... :)
    jimbopbjimbopb Member Posts: 1
    I have a 1995 Ford Escort 1.9 liter. NEW PLUGS, WIRES,O2 SENSOR,FUELFILTER,CHECKED FUEL PRESSURE,OK,new cat. converter,Had exhaust noise in engine compartment,replaced exhaust manifold gasket,new muffler.That fixed noise.I have to feather the gas to pick up speed. accelerates very slowly, hesitates badly.The engine compartment still gets very hot,the nut on the EGR tube gets cherry red and the cat. converter gets red. please help. I like working on cars but this is driving me crazy.
    jasmine26868jasmine26868 Member Posts: 1
    Hi!! i'm new first car on the road its a 97 ford escort only 79K miles on it, here it the problem. after driving for awhile the car seems to decelerate or should i say not accelerate as it should, there was a point in time where i put the accelerator almost to the floor and it was only going 30mph. and then at the same time the brake gets stiff. i had the oil changed, i also put in transmission fluid as well as fuel injection cleaner, nothing. then when i parked the car yesterday i noticed a green substance leaking from it, i am told this is anti-freeze. what is wrong with my car??? please help me!!!
    token2token2 Member Posts: 5
    m 98 escort snapped timing belts twice. just take off the acc. belt and then take off the crankshaft pully, then take off the timing belt cover and the timing marks shoud be aroud the cam pully and the crank pully, but remember if you belt has alot of miles just replace it while you got it out. but remember when putting the belt on, when you tighten you tbelt it will move forward about 2 or 3 teeth because the the tensioner.
    where was the fuild leaking form? but i would get a compresion test and find out if all you cylinders are good, after that i depends on how it did on the test
    i have an 98 escort lx, and i have had it for about 3 yrs. now i got out of school and have money im thinking bout making it into a project car. i put about over 190,ooo(mostly highway) on it sense i got it. now it has over 270,000 on it, but the motor only has bout 20,000 the last motor dropped a valve seat, but both motors ran great it still got up and went for an escort. i just want info on how to make it a sleeper. plus i have alot of memories in it i've had it sense i was 18. any info on like turbo kits, suspension kits or anything that will make people say "are you sure the was an escort?" thanks
    it could be your fuel pump. i've worked on cars like that and when the fuel pump overheats in will shut off. but you shoud hookup a scanner and look at the pump and see what it does. IF it is the pump then change it but check it out first
    nerilpnerilp Member Posts: 1
    I have had this car for almost 2 yrs now. I have replaced a bunch of parts like power steering pump, cv axle, struts, oil pressure switch, radiator, a belt, spark plugs & wires, etc. My new problem is that no body seems to know whats wrong with it now. It started at 1st making this strange noise...like a shushing, water like sound. Then the next day I turned it on and it sounded even louder. I went driving in it and got about a few blocks when it started smelling burned and over heated and shut itself off. I put it in neutral and parked it. It turned back on in like 5 mins. I got it back home and my family looked at it and said my fan wasn't workin right. They messed with it and then thought it was the compressor. But my a/c works just fine. Ever since then its been shutting itself off when I go to stop at a light or stop sign. And smelling burned on and off. Today I stopped at a store and when I got in the car and turned it on my battery light came on and the steering wheel was hard. I got it back home and when I popped the hood the belt that I bought brand new back in Feb. was broken. The belt looks great except for the fact it looks like someone cut it in half with a pair of scissors. I don't know whats wrong with the car. I have people tell me the compressor and some have said maybe the alternator. Can someone lend their advice please!!! I would highly appreciate it. Thank you.
    joyrider147joyrider147 Member Posts: 69
    I found a "brand new" 1987 Ford Escort EXP with a stick shift, 87,500 miles, and I think its had only 1 owner for $900.00.
    I heard about several people having problems with Escorts, but would these problems still be there even if the original owner maintained the car extremely well, including all wiring and wiring harness?
    But I heard the Escort engine itself is powerful, dependable, and reliable. And I've been seeing a lot of Escorts being sold cheaply for low miles. But, is it to make a quick sale for 16 to 20 year old Fords that were forgotten about or are they cars that you dump money in?
    To buy or not to buy?
    igotthisigotthis Member Posts: 9
    I have a 2000 Zx2 automatic. When I bought it, it had 86,000 miles on it and it ran pretty good. About a month after I bought it, I put a ram-air-intake in it for various reasons.
    That was two years ago and now it has 120K miles. The car always seemed to have problems accelerating once it gets into 2nd gear. In 1st it is awesome and 3rd gear and up it is fast and smooth. But once it hits 2nd, it seems something is wrong. It could be at a dead stop, I would floor it: at the start I can keep up with any V6 or V8 car that wishes to race me, but as soon as it shifts to 2nd gear it seems to not accelerate much and over the past year, I have noticed a strange "gargling noise" as if it is not getting enough power, or fuel, or something. I replaced the fuel-filter and I keep all the fluids clear.
    I wasn't too worried, but I want to upgrade to a cold-air intake and I don't want to damage something by putting way more air than it can handle.
    PLEASE HELP!!! I'll accept any advise with appreciation.
    :confuse:
    gep2gep2 Member Posts: 2
    1.9l engine... am told the #1 plug is fuel-fouled, Firestone claimed the fouling was caused by a bad coil (so why no problems with OTHER plugs?) Anyhow, we got a new replacement coil and new plugs but don't even see the coil on the car...!! where is it? Is this something we need to have the shop replace, due to accessibility or something? And what are even the odds that it IS in fact a bad coil, if only ONE plug was fouled and misfiring?? How hard is it to replace this coil, and where is the little puppy to be found!!??
    Please disregard the message I'm replying to... the reason for the confusion was because the parts store gave me the wrong coil, hence it (obviously) didn't look like anything I could see on the car...!! (They gave me the wrong plugs, too...!)
    Anyhow, we managed to get the RIGHT coil, (how amazing, the RIGHT one is VERY obviously visible!!) and the right plugs, and now everything is running fine again...!!!
    escort41escort41 Member Posts: 1
    This car is automatic, power windows, remote starter,and has 97K miles - just replaced the air filter, oil filter, brake rotors. The car runs fine except---it starts fine, takes off fine but after about ten minutes' drive time, a strange noise seems to come from outside the car. The noise stops when idling but after going for a few minutes, the noise starts again.
    I have opened the hood with the car running but do not hear the noise.
    Any help out there?
    kwaldrepkwaldrep Member Posts: 1
    :) maybe too late but it sounds like your timing belt has jumped one tooth and needs to be looked at
    escortluvescortluv Member Posts: 1
    94 escort lx with key on no indicator lights come on all fuses checked out ok all acessories work. was shopping and now car will not move/ could this be a ignition problem,fuel pump reset button in did not trick,I really love my car and any advise would be helpfull :(:(:( :sick: :confuse:
    mstaevskimstaevski Member Posts: 4
    Hi guys,
    I have Escort 1997 and I have some extraordinary vibration and noise when I start the engine. It does occur random (not each time when started), and disappears in 20-30 seconds. There is no engine check light on, but a noise as from a vacuum leak. The car runs good,there is just this strange noise, that is making me think something with the air intake might be wrong. Any ideas if it might be something else or where to track eventual leak down on the hosing???
    rirish7780rirish7780 Member Posts: 3
    I have had a 97 escort for over 4 years now and the only problem i have had with it is the alternator. I have aftermarket parts on it and it still runs great with 113,000mi. on it . It seems to me that you got a bad deal from someone.
    check your iac sensor (idle air control) that could have something to do with your throttle problem. As for the coolant leak you might want to either put a stop leak mix in or see a mechanic.
    i have a 97 escort with 2 1/2 inch pipes from the cat back. a K&N typhoon cold air intake and some other here and theres. To me it sounds more like a transmission problem. You keep saying it happens in 2nd gear. Unless it is just a sensor in your trans.
    lclaytonlclayton Member Posts: 1
    I have a '94 Escort wagon. The only problem I've had with the car, except for a blown head gasket, is a persistent vibration at idle and low revs. Disappears when up to speed. The motor mounts seam ok. Local dealership said that there were upgraded mounts at approx. $200.00 for each( x3). One fellow suggested that the harmonic balancer might be screwed. Yet another mentioned something about a balancer shaft, whatever that is. Have any of you had a similar problem and did you find a cure?
    ckone0814ckone0814 Member Posts: 71
    So I'm looking for a car for my college-age daughter and have found several very nice Escorts at good prices, mileage in the +80k range. They are in very good condition and are equipped nicely. I know from research that they are fairly reliable and are safe but...both of the cars are LOUD - I can hardly hear myself think! A salesman told me they ware all that way because they don't have gel-filled motor mounts.
    Are they all loud? Is that the reason why? If so, can anything be done about it for a reasonable cost?
    chrisg88chrisg88 Member Posts: 4
    I wouldnt be able to say all escorts are LOUD! because i havent been in that many but i can say my dad owned a 94 escort 1600 , and i own myself now a 97 ford escort zetec , and i can tell you ..theyre not the most silent of cars :/
    i remeber mine , getting to a point that was unbearable :mad: but eventually changed the wheel bearings to a smoother lot ...and had no problem since. but yes its still pretty loud... no idea why thou ..but they are good reliable cars soo.
    Definatley could be the harmonic balancer , i have the exact same noise on my 97 ford escort zetec , all started happening when i hit a speed bump at excessive speed and ripped the alternator belt ... seems to fit into the pattern, ive tried to see if it was a thousand things and havent botherd to check that out, later when i head home i shall check it out :) ill let you know.
    caliberchiccaliberchic Member Posts: 402
    We've had a few Escorts and yes they were all loud. :shades:
