Dodge Ram Climate Control
We will single out comments and complaints about Dodge Ram climate control here.
kcram - Pickups Host
I have a 2004 ram 2500. The problem I am having is the heater is stuck on dash- I cannot switch to defrost or floor heat. I bought the heater control which was pretty easy to install and not to expensive figuring this might be it. It wasn't. Now what? As far as I can tell it is not vacum operated. Any help is appreciated.
Dana
Steve
I took my truck to dealer #3 today for the same faulty air conditioning problem (4 times in two months). Yesterday the fan blows but no air comes out of the vents on any selector position.
I demanded a conference call with D.Chrysler warranty department when the truck was checked out. They looked at me like I was crazy, so... I called D.Chrysler and asked to speak to a manager or supv. After 5 minutes on hold they said they were all in meetings and would return my call.... well, it never happened.
Towards the end of the day I got a call from the dealer and they said the Recirc. door came apart!! Guess what? There is a nationwide back order for the part(#24028090)sounds fishy. Can you spell recall? I told the dealer.
I work for a large corporation that is an OEM parts supplier to the major auto manufacturers, so I know how the system works. Auto manufacturers DO NOT want quality problems to go public!! It can start a very expensive recall program.
I am use to the run around now!!!!
I have also filed a written complaint to D.Chrysler over the poor service and lack of trouble shooting to fix my lousy warm air conditioning. After two visits at two different dealers all they did was put a thermometer in the dash vent and record the temp. The lowest temp recorded is 48 deg.F at a 92 deg. F ambient temp. The problem is, it usually runs about 58-60 deg. F at the vent and it will not cool the cab interior off with several passengers. If you are luck after 30 minutes the vent temp will hit 50-52.
The last service manager told me my truck was a dark color (bright silver inside/out), it is the sunroof and I should have a truck cover on it when it parked. The bottom line......B.S. This truck cost $44,000 and the A/C should handle the cab size and while driving in the sun on a warm day!!! The A.C works about as good as the 1990 Ford Bronco I replaced. Its a shame because the truck only has 4,500 miles on it!!
Check out www.dodgeforum.com...AC Coldness- There more of us out there!!!!
I have an '04 3500 dually 2WD with a Cummins and started hearing the same thing (clunk after I started the engine) and it would blow cold then hot back and forth. Since my warranty had not run out, took it back to the dealer and asked them to check it out. They said the clutch and compressor were going bad and replaced everything for me. I picked it up yesterday and it is blowing cold now.
-bruce
Thanks!!
-bruce
Before you go that far, be sure to check that you have a full charge of R134a.
No shipment = no tracking, what do you think?
inefficient. The vents for the drivers side hardly blow at
all. The one vent for the passenger side seems to be ok
and the vent in the back blows pretty good. If there was
a way to shut off the back vent I think most of the problem
could be solved but there is no shut off for that vent.
Driving to work in the morning when the temp is 78 it is not
a problem but when driving home when it's 95 the ac takes
forever to cool the cab. I saw an earlier post that
mentioned that Dodge probably did not upgrade the ac enough
to run that extra vent in the back. That's exactly the way
it seems. Has anyone else noticed this problem on their
Megacabs and have you found anything to help with cooling.
I keep a sunshade in the window and the windows cracked
while parked.
Sorry to hear about your problem, I have an 06 Mega Cab also with poor air conditioner performance. Be ready for a battle with the dealers and Daimler Chrysler!!!!! I have been to several dealers and now for 19 days with NO A/C or any air from the vents. They don't even know when the part will be in and they dont't care either
Please see my past postings and log on to www.dodgeforum.com (re.ac coldness). Lots of good info especially from Manatlarge! Start now and document every conversation/details, you will need it.
This is a big problem and the dealers and Daimler Chrysler customer service center is playing DUMB. Already filed a written complaint with no results, I have moved forward with the next step and it will get their attention!!
Silverbullet06
Took it back in and after 5 hours, they said they charged the coolant. It was now cooling a little better. That lasted two days and it is back to the poor performance stage. I am very dissappointed. This is my first Dodge and I am very uncomfortable with the way this is going so far. I am bringiong it back in for a third time tomorrow and I have only had it a week!
BCC
Mega cab/Quad cab owners are all faced with a serious design flaw, with the weak air conditioner performance. For a standard cab the air is probably fine, as the cab sizes grew the systems capacity did not. Any combination of high heat or extra passengers pushes the limits to the minimal system.
As I stated before, document everything and all the details of the condition. I am on day 25 with no air circulation at all, I might as well bought a truck with no A/C!! As you will find out the customer service/support is the worst. They want to sell...sell...sell... not fix.
Good luck!
Silverbullet06
BCC
The door(s)and it's operation or lack of explains why there is an uneven air discharge or it allows heat to be sucked off the heater core.
This is why my truck has not been fixed, they are waiting on the parts...so they say.
Mega cab owners with faulty A/C or climate control need to log on to www.mydodgemegacab.com. This is a new web site documenting this serious problem. We need the help.
Silverbullet06
I filed a complaint with the California New Motor Vehicle Board (mediation) to get some action. Since 2002 D.Chrysler has not participated in the CA certified lemon law program!!!!
Once the complaint is filed the manufacturer has 10 calender days to respond. It took 13 days and a then phone call to D.Chrysler in Irvine, Ca to make something happen.
The same day the call was placed from the mediator I got a call from my dealer to pickup a rental car and the part would be at the dealership in 1-2 days....I picked it up last Friday and the air does come out of the vents but it will not cool the cab off. It was 92 degrees and you barely reach a comfort temp with the fan one notch below high and on recirc. I noticed the vents on the passenger and rear seating vents felt warmer. After a 30 minute trip I checked the temp on those vents and it is 60 degrees vs 50 on the drivers side.
The truck has the dual zone temp and they are on cold. We will be hitting over 100 by the end of the week and I will be back to opening the windows or sweat! The operation is as good as it gets, poor......Everyone needs to call and write D.Chrysler to file compaints.
:lemon:
I have a 2003 2500. And can, or could, here the "clunk" after start up. I am at the conclusion that is was the fresh/recirculate door. a few days ago I experienced the same no air flow problem, but could not here the usual "clunk". After reading this post I checked the system My self. the problem is that the Fresh/Recir door had broke off the control rod and had fallen onto the fan intake. The door can Be removed thru the blower passage by droping the blower (3) screws. Its a bit tricky to position the door thru the outside intake allowing it to pass thru the blower passage, allowing air to flow.
This is only a temporary fix to this specific problem. the unit still has to be removed to replace the door, and it allows outside air to flow thru the recirculate opening. One has to either block the outside opening, or the recir opening. but cold air is nice in 100+ deg temps.
I hope this helps someone.
Thenutti
Now i used to hear some thing similar to that Clunk in the above post at start up, but i was thinking it sounded more like Removing an air tool from the air hose with pressure still on.
Ohh i have been to a professional and he wanted 650 bucks to replace the temp. thermocouple, he was saying he had to remove the dash, and replace some thing that turned the air on and off by temp before it froze up. similar to an old pressure switch. any thoughts ?
Silverbullet06
Trying to set up an appointment with the factory rep next week, either fix it or give my money back. Four months without a properly working A/C is not acceptable.
Silverbullet06
Thanks sooo much!
DannyB
Thanks sooo much!
DannyB
Redramman
Sorry to hear you have the same problem, and glad to know I'm not the only one working on it! My truck is an 01 1500 with 27k the failure to drain did not begin until last summer. not one person I've spoken with can tell me anything about it! Man if you can figure this out you'd be one of my heroes!!!!!!
If I get it I'll post it - please do the same
Danny B
I started my truck and the blower motor did not come on for my defrosters. I tried just the fan and A/C without luck. I waited about 10 minutes and when it was apparent to me that it wasn't going to come on, I start to drive. After about 20 yards, it started? I did not have a re-occurrence of the problem for many months so I thought it was just a computer screw-up. Then it happened again, this time while turning on the A/C. I have now had the problem about 10 times (five this week) and it only happens when I first start the truck and the blower always kicks on after moving about 20 yards. I don’t know if moving is a key or just a timing issue? It doesn't matter what speed the fan is set on, A/C, heat or just the fan, it either works or it doesn't? I now fear that at some point there is going to be a failure with the fan and it will not come on. Is this related to the resistor problems I’ve been reading about? If so, it seems to be a different flavor of the problem. Any help or suggestions would be appreciated.
PS I am new to this site and could not figure out where to post this question? If this posting is incorrect, could you please direct me to the correct area and process.
hope this was helped!
DannyB
Can you tell me where the fan/blower unit is located in my truck? I believe it is under the dash on the passanger side but i'm not sure.
your correct, you'll probably need a socket extension to reach the bolt behind the unit. the bottom of the units housing is kinda rounded. it is very simple to replace. I'm not very good at this sort of thing and it was easy to figure out. Let me know how it goes?
DannyB
