I have always had a rubber band or two on my shift stick but now it is a problem. The dealership of course only figured this out on the 2nd try after the tow truck suggested it. Before that, the dealership kept testing the battery and telling me it's fine (which is what i told them when I brought it in the 1st time).
Other problem - low set idle point which send extra vibrations throught out the car and the dealership says they cannot do anything about the signals the computer sends to the idle point system (or whatever it is called).
I also had water leaking (pretty heavily) on my right foot while driving...aparently some tube got plugged up.......
I also had the horn go off wildely. The dealership put me through hell with fixing it and now 8 months later it is finally fixed.
SO, between the problems with the car and pain & difficulties from the dealership - I HAVE HAD IT and will be taking it further to Toyota, BBB, Consumer report!!!!!!!
1 piece of advice to the others who seem to have problems with RAVs > buy a honda
Cheers,
Nazlym
Shame on Toyota for their poor service.
Don / Tacoma WA Realtor
Don Leske in Tacoma WA
Realtor / ASE Certifice Master Mechanic
I tried everything I could to get someone's attention at Toyota America. No luck. I would never, ever purchase another Toyota based solely on the service issue. Aren't there any attorneys out there who want to pursue this??
Beth
When I have my foot on the brake pedal and push the starter switch I hear a 1-2 second unusual almost grinding sound before the car starts up. This does not happen everytime but more than 50% of the time. The car starts ok every time.
Now a new issue has come up that frightens me. In the past when i pressed the start button 2 times to activate the accessory mode without my foot on the brake as recommended by the manual I heard the same sound for a second or so as though some signal was sent to starter and maybe because brake pedal was not activated some relay stopped it from engaging. So out of fear I stopped doing that.
Today I left a window open and used the acc mode once and now ,even when running the engine , when I turn engine off and open drivers side door the same sound happens without touching the start buttton! Any ideas. As I am in Greece I have no warranty and am really afraid of any electrical problems.
Does anyone else hear any sound with the keyless start button before the engine actually kicks over, and has anyone experienced the door opening causing any starter related sounds
Please help
Is this atypical, or common to all new, keyless RAV4s?
Could you try that, and tell me if it works for your car
http://rav4world.com/forums/viewtopic.php?t=23861&start=15
Its RAV4 Athens. Good to see you are spreading the correct info to all
Huh??? I have lived in Maine for decades and have never heard that, nor had a new battery die. So now the dealer says they will keep the car for 24 hours and hook it up to see if some sensor is not turning off and draining the battery.
Has anybody else been told that?
One feature I note about the Rav4: if the headlights are left on when the ignition is turned off, they remain on for, I guess, several minutes before turning off automatically. Can this be a bad design that drains the battery if done a lot?
I don't have a RAV-4, but many vehicles keep the lights on when you walk in from your car so the path is lit, but you can turn them off early by hitting the remote lock button a second time once your at the door to your house. Something worth trying if you haven't already.
I will never purchase another Toyota since the problem has occurred on past models of the RAV4.
TSB Number: TSB-0348-09
Bulletin Title: Intermittent No Crank/No Start
Release Date: September 30, 2009
Applicable Year(s): 2006 - 20010
File Size: 171 kb
Download: Link
Description: Some Highlander, Matrix, and RAV4 vehicles may intermittently exhibit a “no crank” condition. The engine can usually be started after moving the shift lever to the Neutral position or by cycling the shift lever in and out of the Park position. A revised neutral start switch assembly is available to address this condition.
Download TSB
My toyota never had any battery issues and today 90 degree weather I went on two trips, the second time there was an all systems failure, nothing worked, I could not even lock the doors. Called AAA which checked the battery after they jumped it they mentioned that the alternator may not be working. After they disconnected the battery and I try to start the car, it still did not start. Only after they connected the battery again I could get it to start. I drove the car home, however it stands dead in the street. Contacted Toyota dealer however they will be able to get the car taken care of in 4 days.
Oh, and if you disconnect the battery on ANY car, it will not start!
I'm having starter issues with my 2006 currently and am getting nowhere with answers either.
I just recently bought a 2005 RAV4 and have had no problems, but have had it only a few months. Hopefully, it is a vehicle that is problem free. I do have a AAA membership and a cell phone, however, so maybe I can be worry free.
I have owned two long-running Corollas that never gave me ANY problems but I needed a larger, "taller" car for medical problems with arthritis, and since my daughter loves her car, went with this one. I've read nothing about any recalls for 2005. I hope I will not rue the day I bought it!
Can I get a heads up on where to start? Wiring looks fine, cluster works, doubt it's a short at the headlights...thinking short at dimmer, ignition or a relay.
Thoughts?
This same 'starter' problem happend to me only about 2 or 3 months ago. The ignition wouldn't start, turn over or make any sound what so ever. I called AAA and their person told me it was a battery problem, so he sold me a new one and installed it. The very next day it happened all over again! Another AAA person came out and said he felt it had to do with how we use our remote control car alarm systems versus the locks on the inside of the driver's door. He said to ensure that all doors were locked each time, to hit the remote three or so times. The same when you want to disarm the locks. So I've followed that directive religiously ever since. Unfortunately, I think it almost happened once again a couple of days ago! It hasn't happened today, but now I'm becoming anxious all over again. I believe I'll follow the advice of one of the other writers/readers here who said what to direct the dealership to do when I take it to them for repair. I've sworn by Toyota for many years and this is the very first one I've ever had issues with. Between this issue and now the recall for the floor mats and excellerator, I couldn't be more disappointed and concerned than I am presently.
Dealer is now replacing the battery & starter because the starter must have been "hung up" (on what?) and the rubber casing melted. Need the battery and the starter to do further diagnostics....
Any thoughts? Any similar experiences. RAV has just over 77K miles and the 75K service was completed about a month & a half ago. Do I trust the car going forward?
That was followed by a door that wouldn't close at an estimate of $487. I got on here and read about Dupont Silicone and fixed it.
In 2011 so far, I have had a Timing Belt Tensioner put it as well as Crankshaft Seal and valve cover gasket -- $703.18. The Timing Belt was changed at 105k and the car now has 156k. I checked to see if it was under warrantee which it was and they were going to replace the whole kit, water pump, belt, etc. but the person I took the car to did not take the "kit" saying it was only the tensioner pully. I have to say that I was not comfortable with this and being a woman, I feel that I may have been "taken" on this. Is there a way to find an honest mechanic who won't take advantage of my female status?
Oh did I say the car was still leaking something? So I took it back and was shown that the power steering fluid was leaking. It is now fixed -- $470.
When I took it in, I mentioned that the car was making a clunking sound, not the usual power steering squeak. When I picked it up, I asked if they found out what the noise was. They said there wasn't any noise. Well as I drove out of the station and down two blocks, the noise happened again while I was waiting to take a turn. I am so disgusted and so not trusting, I did not return. I did have a muffler replaced a month ago (under warrantee) and by the person who originally put it on who is another person that I am unsure of as to being taken advantage by him.
In the old days, you took your car into be serviced or repaired (or at least I did) and the mechanic (my cousin) took the car for a ride to see if anything else was going on. He also washed it for me. He is now deceased and his shop is going and I am still trying to find someone I can trust. I admit to being spoiled but I knew that I could trust him and he knew I was not totally ignorant about cars having worked as a teenager in a dealer service dept so he listened to me if I thought something was wrong with my car.
This morning I looked at my car and there is yet another leak under it!!
Do I take it back or do I just chalk it up to a car getting old and it will keep having to be repaired? I really can't afford to buy a new one and I really want another Toyota but maybe this is not the time to buy one.
Sorry for rambling on.
because if u notice when u jump a rav 4 and try to drive it the power steering will work on and off due to the lack of battery power
Does anyone know what to do?
