Honda Accord Navigation
If I get the navigation, are some of the controls for stereo, climate, etc. put on the LCD touch screen of the navigation instead of the buttons and knobs on the console?
All manual AC controls, including fan levels are there. The auto climate controls are knobs and push buttons.
All the informational things like trip computer, calendar, calculator, etc are touch screen items as well.
Oh yes, all the navi controls are there too.
The whole thing is very easy to use. And you can also use voice commands for all of the above. For example, you can tell which radio preset you want to play.
2. How well does the voice recognition differentiate words spoken during conversation from commands given to the unit?
3. Are there any issues with doing 2 things at the same time with the nav screen? So for example, while the radio is playing in the background, I imagine I can click over to the climate options and the screen will change to that. Are there anythings that have to be stopped before something else can be done?
Can an aftermarket NAV be as nicely integrated with the stereo, climate controls, etc.?
That may sound bad, but keep in mind the climate controls in the model with the Navi option also has the Auto feature with dual temperature settings. Basically you can "set it and forget it"
I have an 04 EX-L, I hardly ever touch the climate control settings. I set the temps at 70 deg, and leave it there. When the car has been setting in the sun, the auto controls crank up the fan speed, and even turn the controls to Recirculate for max cooling, returning to normal once the car cools down a bit.
The radio volume, mode and channels can be changed with the steering wheel controls as well as the knob on the dash.
The voice recognition only functions when you hit the "voice" button on the steering wheel. You push the button, the system shuts off the volume to the front speakers, and you give it your command. If your lucky, it will understand your command. I love the Navi system, could go without the voice recognition.
I find that unless I'm using the Navi function, I really don't need to use the screen for much. Once you program your favorite radio channels, adjust the bass/treble/balance/fader to your liking, there isn't much of a need for the radio settings. If your interested in your current gas milage, how far you have gone on the tank of gas, and how far you got left, the trip computer screen is handy.
There is nothing that has to be stopped when you change screens.
The only BIG complaint that I and everyone else has is the 20+ seconds it takes before it becomes operational. The delay doesn't affect the climate controls from turning on when you start the car, or does the delay effect the radio. I also wish I could plan a trip on my PC and download the data to the Navi system. I'm sure, future models will have that option.
My suggestion would be to find an '03 or newer Accord at a dealer with the Navi and play!
If you do alot of traveling, or drive in areas your not familiar with, the Navi system is worth the $$. If your going to be driving the car back and forth to the same places you've been before, then what do you need the navi system for?
Mrbill
I agree with MrBill about the voice recognition. It works much better sitting in the driveway but it sure gets confused if there is any noise. With the roof or windows open, your chance of having it understand you goes waaaay down.
Of course the other thing that helps is to memorize the exact words to say to do something. I end up just pressing the screen most of the time.
The only complaint I have is that there aren't enough radio presets for me on XM. (Go figure.... there are two sets.) There are so many choices and I find myself liking different things at different times. Changing individual stations with the dial is the worst thing about the system. Otherwise, I love it.
On another note, while I drive in many places that are new (why I bought it in the first place) I still like having the map available even locally. There are some freeways that I drive and never have known what's "over the hill". The map lets me see roads, lakes, etc. Also, I've been able to find a few back roads in some areas that I didn't even know went through. Kinda fun.
I ment that the accord gets dual climate control, Xm radio and a nav system with voice recognition for 2004.
The accords styling was best in 2003, 2004, and 2006.
-Cj :shades:
I'm sorry, but it was hilarious. I asked him to key the mic again and I gave the car the same instructions and it understood me perfectly.
He has since been able to get it to respond to his voice, but he has to speak very clearly and try to reduce his accent. Good luck. - Kelly
-Cj
You sure about that? I thought all EX-Ls since 2003 had Auto Dual Climate Control... Honda very VERY rarely makes things stand-alone options, NAVI systems excluded.
http://www.edmunds.com/used/2003/honda/accord/index.html
I still think i'm right about the voice commands for the nav though.
-Cj
Having the text display and pushing the OK button is probably a legal "you can't blame Honda cause you agreed to the text" if you caused an accident while viewing the Navi screen.
Mrbill
That's exactly what it is, and its the same reason we have to have ugly yellow airbag warning stickers printed on sunvisors and such...
Mrbill
Doing this type of installation (if humanly possible) is going to cost you a lot, I believe.
Yes, you will need the Navi unit for the dash, antenna, wiring harness from navi unit to trunk DVD player and antenna.
The part that I would be concerned with is some of the other functions the navi displays. The complete climate control system, and trip computer functions are also displayed and controlled with the navi system. I don't know what inputs/outputs will also be needed, but it could get complicated.
I would like to think it can be done, and would love to hear it's possible, but I would also be cautious if someone posts "Sure it can be done, I did it" I would want a detailed list of EVERYTHING that needs to be installed.
Good luck, let us know if you do go for it.
Mrbill
My current problem with the Honda NAV is that one of the major roads in Sarasota is Bee Ridge Rd. However when I try to find a specific address on Bee Ridge Rd, the Nav system only allows me to enter addresses in the 5000 block...which is rediculous. I haven't taken the car to the dealer because all other Nav seems to work ok...but this is just incredible....one of the major roads in a pretty major city not working.
we'll see what the dealer and Honda say. It's one thing not to have a small/new road...but it's not OK to sell something that doesn't work correctly with a major road and state route.
My sentiments exactly. I have the Garmin Streetpilot c330 that we found in-store at Wal-Mart for under $330. Does everything I wanted it to, stores 500 of your favorite locations, has 5 million points of reference, and a pretty amazing battery life (for when you don't want it plugged in). I'm thrilled with it! I have had it in three cars since I got it this Christmas.
Webby
Going somewhere you shouldn't be? LOL (just kidding)
Mrbill
Just being lazy...when I got the car ( wife's car ) there were couple addresses someone else programmed....seriously !
Webby
The system is "voice controlled" with individual commands.
No question is stupid!
Actually, looking back I see that you said that there is a voice command option, so now I am :sick:
:P
I shouldn't have used the word "option" and instead should have said "feature."
The terms control and command are used interchangeably. You press a button on the steering wheel and speak your "commands" to the system (such as "Go Home", "XM channel twenty-eight", "Radio ninety three point nine FM", "Fan speed two", "Passenger temperature seventy one" etc. Simply put, your voice controls the system by commanding it to do whatever you wish it to do.
Voice command is not an option. All 2003 through 2007 Navigation System-equipped Accords have voice controlled navigation, climate control and audio sytems.
Now you are saying the terms are interchangeable, which is what I thought all along, and that's why I asked what is the difference. To me, your reply says they are two different things.
Sorry, I'm certainly not trying to argue with you, not at all, but I was confused by your first response and that's what prompted my question. If the point is that voice control/command is standard, not an option, then it all makes sense and it was indeed a dumb question!
Which will not stop me from asking "dumb" questions in the future, I assure you! :P
Otherwise, I always use the term voice controlled to describe my Accord's system.
You may not have been aware of the fact that the Garmin nüvi series units have a user-selectable pedestrian mode too.
-user friendly...my life is too busy to mess around with any sort of complication
-good maps: tomtom I can now say has the best maps in north american do to the recent update link title
-lastly this one is kinda picky but i really like the fact that tomtom has an arrow on the main screen advising you of which direction your next turn will be in.
That's cool that the Nuiv has a pedestrian mode similar to the tt one. Other good tt products that are worth loooking into b/c they are cheaper but you don't carry them around on foot are the tt 510 and tt 910 :shades:
You might not be aware that the Tom Tom One does not speak the actual names of the streets. It just says turn left, turn right, etc. The Garmin nüvi series units have Text To Speech (TTS) that say turn left onto Main Street, turn left onto Broadway, etc.
I have extensive experience using my 2004 Accord's Navigation System, which does not use TTS. I also use a Garmin nüvi 350 in my wife's car and in rentals. The nüvi uses TTS. Text To Speech is a major safety advantage since the driver keeps his or her eyes on the road, rather than on the screen.
