p0171 system to lean bank 1, p0174 system to lean bank 2 and p1309 manufacturer control. I have replaced fuel filter, spark plugs and wires, and pcv valve.also replaced the tranny filter and fluid. any suggestion's?
Mike
Mike
Mike
Can't take this rough running, gas chugging, no power stuff anymore. Any advice
would be appreciated.
i have been back to the mechanic who tuned it and also to another one; both say it checks out fine on the analyzer and to wait for a "hard failure'.
by the way, after it dies,i put it in neutral/park and it starts right up. any ideas?
larry
Note...wear a good dust mask. Those insides are toxic. Cadmium and all sorts of nastiness.
You have a choice to spend lots of money or try some tricks of the trade.
Use a MAP gas torch and heat up the spark plug and aluminum area where it screws in. After its hot try and tighten it a little and then loosen it. Keep repeating this working the plug back and forth until you can get them out. These rear plugs are hard to drill out because they are in the back but it can be done at a last resort. Use a vaccum cleaner and ducktape a hose that will fit down the hole to remove any pieces and a tiny magnet tool ect. Poor oil in the cyclinder and crank the engine over with the starter repeatedly to allow any crap that fell into the cylinder to escape through the open hole or exhuast valve. Repair any damaged threads with thread repair inserts. Im a mobile mechanic and this is a common repair that I get. I would save a customer like you at least a thousand dollars on this repair. Good luck.
Lucky in Ga.
How can I diagnose this situation?
thanks,
Jerry
last week. It started and ran fine. The next day it would not start but turned over fine. I charged the battery the following day and it started fine. It ran for about 1 minute and cut off.It will not start again. Almost like a vacuum thing? Any ideas??
