Ford F-Series Transmission Problems
1141516171820»
  • clewclew Posts: 1
    I have a 1994 Ford F150 that shifts periodically. We installed a new transmission, however the problem still exists. Can you please help me? My husband recently passed away and I now drive his truck. This truck scares me to death when it shifts hard. I’m terrified I will break down.
  • rmoyermoye Posts: 1
    I have a 1999 F150 4wd 4.6 reg cab with a trans that only goes in rev. I changed fluid & filter every 30k. about 6 months ago it started shifting hard from 1st to second and the od light always flashed on & off. Never any real trouble till now. No forward gears. 4wd shifts in and out ok but only in rev. no warning or check engine lights. Any ideas. I really do need some help on this. Any advise is greatly appreciated. Thank you.
  • Most likely the synchro dog springs are worn or need to be replaced. The synchro dog springs align the shift forks in the center to prevent the shift forks and synchros from ove shifting and actually rubbing against the gears, thereby causing them to wear out prematurely. Often times when the tranny is rebuilt this is something overlooked and the shifter forks premature failing is a result of the worn springs. As the forks tend to rest either slightly forward or slightly back. You can continue replacing the forks every few months or the next time the forks need replacing pop the tranny out and preform some minor surgery, or have a quality tranny mechanic do it.
    Ford F150 5 speed tranny M5R2 Actually built by Mazada or toyota and is a light duty transmission used in the f150 and t-bird, and mustangs. From 1992 to current. The M5R2 is a top loader transmission and depending the application depends upon the location of the shifter housing. F150 is a true top loader as compared to the stang, bird or mazada trucks. The shifter is located to the back of the tranny tail housing. Hope this helps.
  • I have a 2003 F150 4-6 automatic, which my son was driving at first it would not go in drive, after trying a couple of times he got it to go in drive then it would not go over about 30 to 35 mph and did not shift. I was told to change the filter and fluid first, I have done that and it still will not go over 30 to 35 mph and seems to not even try to shift. Anyone have any possible suggestions on what the problem could be.
  • bud70bud70 Posts: 2
    My transmission worked great unitl I pulled the motor and tranny out to replace seals and gaskets. I also power washed the engine and tranny. I put the engine and tranny back in, double checked all the plugs and grounds. I can put the tranny into reverse, 1st and 2nd it works, but it will not shift on its own. Any ideas out there on what could be wrong?
  • temj12temj12 Posts: 450
    When the transmission goes, it is designed to go into the lowest gear and stay there. I had the same thing, although it was not the entire transmission. It was a part and wound up costing me $300. I was lucky. You are not going to help it with a fluid change. It may be done for, but hopefully not.
    Mine is a 1992 F-150, I have all gears, it just won't shift on its own. What was the part you had to buy?
  • Probably shift solenoid pack. If any electronic faults, it goes to failsafe
  • Our F150 is our yard truck. It has lived it's life on the road, and has now been "put out to pasture".
    The problems we are facing now is when we shift the truck into any position. PRND21, they all go forward. Surprisingly when you get in nuetral, the truck "smooths out". There is no neutral or reverse, any ideas???
    Yes, we checked the transmission fluid.
  • topcat19topcat19 Posts: 1
    edited December 2012
    We just bought a used 1997 F 250 plow truck. Today was our first time using it. We were backing up and I noticed a line of rust colored drips. It appears that a cap of some kind was knocked off and all the transmission fluid ran out. The guy at Napa said there is no cap there. But my husband looked under and definetlynsaw where a metal cap would go. A anyone know if this is true, what it is called? And any other advise.
  • have 1991 f250 tranmission was rebuild because was not shifting out of 2 in to d &od was it still doing same thing was told it was elector or something else can anyone help and is there any way to scan a 91
  • I GOT A 1996 F150 FORD PICKUP..THE AUTOMATIC TRANS IT PUSH BUTTON OVERDRIVE AND LATLEY THE LIGHT ON THE BUUTONT TO PUT IT IN OVER DRIVE HAS BEEN FLASHING AND THE TRANS SEEMS LIKE ITS HOLDING BACK,LIKE TIGHTING UP SO WHAT DO U THINK THE PROBLEM IS?AND IF I TURN THR TRUCK OFF PUT IT BACK IN GEAR ITS OK
  • I GOT A 1996 F150 FORD PICKUP..THE AUTOMATIC TRANS IT PUSH BUTTON OVERDRIVE AND LATLEY THE LIGHT ON THE Button TO PUT IT IN OVER DRIVE HAS BEEN FLASHING AND THE TRANS SEEMS LIKE ITS HOLDING BACK,LIKE TIGHTING UP SO WHAT DO U THINK THE PROBLEM IS?AND IF I TURN THR TRUCK OFF PUT IT BACK IN GEAR ITS OK
  • KCRamKCRam Mt. Arlington NJPosts: 3,516
    While it varies from manufacturer to manufacturer, a flashing overdrive light usually means the overdrive has been disabled due to a detected problem (overheating, etc.). You likely now have a trouble code from this, so get the codes checked and that should give you a starting point..
    kcram - Pickups/Wagons/Vans+Minivans Host
  • rich37000rich37000 Posts: 1
    edited April 2013
    Have a 2004 F150 4.6 v8 w/130k miles. Have gone through 2 ignition coils (cylinders 1&3) the past few months after jerky idling and coding. Everything worked fine for a month, but now I am getting occasional wobble in the RPMs at a stop light accompanied by a "bump" from what feels like the tranny. Accelerates fine and on even highway is fine, but when it goes up a hill it will buck and jerk briefly as it downshifts under load. Has towing package and trans cooler but have only towed about 6 times with it. I'm the only owner and have kept all maintenance fully up to date. Any ideas?
    Oddly enough, if I accelerate up the same hill by giving it more gas it does not seem to act up...
  • mikekf150mikekf150 Posts: 1
    I have a 1999 Ford F150, 4.6 engine, with an automatic trans. The trans worked good , no problems , the guy I bought it from said he just had the trans rebuilt. It drove fine, then all of a sudden just started to slip completely in all gears , and when I shut it off for awhile, then started it again it run fine for a short distance , then went out in all gears again. Not sure if it is computer, a valve body problem or a torque converter problem. Can anyone here that knows what the problem might be, shed some light on this for me ? Thank you for any help you might be able to give. Mike
  • gcsod45gcsod45 Posts: 4
    I have this vehicle. It has a 302 in it and 85000 original miles. Drove it 2 days ago with no problem and then yesterday it only shifted when it wanted too and only after i was doing 25-30 mph. I made sure it was full on tranny fluid. I know nothing about trannys, any help. I was told to check vacuum lines but not sure which ones. Also i have no ideal if filter has ever been changed. thanks for help.
  • :confuse: My 1998 f 150 147,000 miles on it and runs fine under normal conditions.
    when I'm driving my pick up and I press the throttle fully to pass another car the engine increased approximately to 4500 RPM, the speed of my truck increases but will not release the passing gear or shift until I back out of the throttle. Some solution?
  • kayrokayro Posts: 1
    edited August 2013
    I have the exact problem with my 1990 F150. It's hard to shift at times and then
    it's ok for a couple of days. Mine is stick shift and sometimes when shifting to reverse, makes a noise like when you have the motor going and try to start it by mistake.
    Any ideas Any body?
  • tomottotomotto Posts: 1
    I just bought my truck last week with 183,000 miles on it, 7 days later the tranny is acting up. It takes 3 or 4 seconds to drop into reverse, vibrates like crazy going up hills. Fluid is full, doesn't smell burnt, Could anyone give me a suggestion what to check with the tranny first before I have to take it to a shop to have it pulled? I'd like to take it to someone who knows how to rebuild a Ford tranny the right way. Anyone know anyone that rebuilds them or the name of a good shop in the Daytona Beach, FL. 32114 area. Any info would be greatly appreciated. Thank You......Tom
  • cowboy9cowboy9 Posts: 161
    Dont be shocked to find they added saw dust to make it run. Your Transmission is shot. Where ever you live check on craigslist for a re builder for a good price.
  • I am having the exact same problem. While on a trip, the voltage regulator in the alternator went out. Now my truck is shifting the same way. if you find out what it is that's causing the problem could you let me know. My e-mail address is bccolling@digis.net. Send me you e-mail address and I will let you know when I find out. Please and thank you.
