Volkswagen Rabbit Audio & Entertainment System Problems
Sylvia
Member Posts: 1,636
Volkswagen Rabbit Stereo, Audio, iPod, AUX issues and questions
Not sure how to change it, since I bought the 2 door, which I dont think has that feature.
It should be a simple fix in the manual.
• Optional iPod adapter
• Audio auxiliary input added
• Simplified cruise control actuation
• New Rabbit exterior colors – Tornado Red, Candy White, United Gray
• Tire Pressure Monitoring System optional
I traded in my 03 Civic LX...we'll see if that was a good decision :confuse: No comparison in the performance, styling, etc., but my Hondas have been good to me in the past.
I wanted to see if anyone with the new 2 door has the IPOD adapter? If so, does it work through the radio like other VW's?
http://forums.vwvortex.com/zerothread?id=2480895
The 4 door comes with a "nicer" stereo, which is why I'm wondering if the stereo on the 2 door provides the same function. I'm sure between someone on here and the dealer I'll be able to find out.
Figured I'd share the love since my next step was to start dismanteling the dash to see what setup the radio had for inputs.
TSB (Technical Service Bulletin) number is - 91-06-02
Condition
Radio Volume Varies Resulting in Poor Sound Quality
91 06 02 May 15, 2006, 2012018/2
Technical Background
Panasonic Premium 7 radio (FM and CD) sound quality may be poor due to excessive amplifier clipping. Radio sound quality varies too much with speed dependant volume feature disabled. Radio sound is muffled at various volume levels or may be perceived as fading in-and-out. This amplifier clipping can be verified at higher volumes with various types of music and is most noticeable when playing music via the radio or CD.
This is due to the radio unit software for amplifier clipping.
Production solution
Radio software updated.
Service
If vehicle is equipped with Panasonic Premium 7 radio, use software CD Part No. W42PANASONICPRE7 and VAS 5051, VAS 5052 or VAS 5051B tester to update amplifier-clipping software to prevent this condition from occurring following the procedure provided.
Follow guidelines below to determine if radio is a candidate for this type of software flash:
Determine Panasonic Radio type and software level
1. Connect VAS tester to vehicle. Switch vehicle’s ignition to ON position.
2. Activate Vehicle Self Diagnosis from VAS tester.
3. Access Address Word 56 – Radio.
4. Look at header information which appears at the top of VAS screen. Panasonic Premium 7 radios can be identified by either PM6 or ZSW letters as shown in figure 1.
Is vehicle equipped with Panasonic Premium 7 radio?
• Yes, go to step 5.
• No, go to step 6.
5. Is software level 0016 or 0017 as shown in figure 2?
• Yes, press Go To button to Exit VAS tester. Turn ignition to OFF position. Go to step 1 in Programming procedure for Panasonic Premium 7 Radio.
• No, go to step 7.
6. Radio is not Panasonic Premium 7 type. Do not complete this TB. Further diagnosis required.
7. Radio software has already been updated. Do not complete this TB. Further diagnosis required.
Tip:
For software programming to execute properly, vehicle’s battery must be maintained by an approved VW battery charger / maintainer. Failure to comply with these guidelines may result in software programming failure.
1. Connect an approved VW battery charger/maintainer to vehicle’s battery.
2. Insert update programming CD, Part No.W42PANASONICPRE7, into VAS tester.
3. Turn vehicle’s ignition to ON position.
4. Activate Vehicle Self Diagnosis from VAS tester
5. Access Address Word 56 – Radio.
Tip:
Radio may be in the on or off position. Radio station presets will not be lost after the software programming has been completed.
6. At the bottom of the screen, select Update-Programming.
7. Read Note displayed on screen, and go forward to next screen, the Software programming process will begin.
Tip:
A bar-gauge will appear showing the programming process. If a pop-up appears on VAS tester stating that Diagnostic link is faulty, ensure ignition is ON and select repeat.
8. After programming process is completed, follow steps on VAS tester.
Tip:
If a pop-up appears on VAS tester stating that Diagnostic link is faulty, ensure ignition is on and select repeat.
9. Once programming process has completed (100% on bar-gauge), the VAS tester will display Programming Log – Save Results?
This screen displays old and new radio information. Software level in header of screen should now be 0018
Press forward button on VAS tester.
10. VAS tester will now prompt to Erase Fault Memory?
DO NOT press forward button on VAS tester.
Instead, press the Go To button and select the option to Exit the VAS tester.
11. At the VAS start screen, select Vehicle Self-Diagnosis.
12. Select Collection Services.
13. Select Erasing DTC memory – entire system
14. When DTCs have been erased, Exit VAS tester.
15. Disconnect VAS tester from vehicle.
16. Switch ignition OFF and remove battery charger / maintainer from vehicle.
Warranty
When procedure applies to vehicles within the New Vehicle Limited Warranty, use the following:
Claim Type: W2
Part Identifier: 9105
Damage Code: 9105 39 000 1
Labor Operation: Includes all procedures necessary to re-program radio 91052540 = 20TU
Diagnostic Time: No Additional Diagnostic Time Allowed
Claim Comment: Input “As per Technical Bulletin Instance Number 2012018/2” in comment section of Warranty Claim.
Required Parts and Tools
Description Part No: Quantity
CD W42PANASONICPRE7 1
I thought maybe it was a mislabled 06... but the VIN on the sticker matched the VIN on the car and the window sticker said "07" Any ideas what happened?
Thanx,
Ben
I also found out today from calling VW HQ, that the iPod option isn't available until Nov. At this time, it will be installed in or near the armrest is what the rep told me. If you do hear of an iPod option currently available, it is just the old iPod adapter that they've been using for other models. It is NOT the one that is specifically designed to be used with the new 07 Rabbits.
Personally, unless they completely overhaul the interface of the nav menu from the iPod adapter, I'm just going to stick with using the AUX input. It's not worth paying over $300 to get the iPod adapter installed.
Also if you are using the standard stereo jack out don't turn the IPod above half way up. That yields better quality sound.
My XM works in it well also
yimmer
It seems weird that they didn't put it in the dash or armrest.
i took the car in yesterday (saturday) and explained the situation to the service advisor and he told me that he doesn't have a clue to what is causing this and also that this is a common problem among rabbits.they won't replace the radio cause the radio and cd player work fine.one of the service advisors jokeing around said maybe my stereo was haunted which i did not find very amuseing to say the least.anyway,they basically told me to live with the problem because there was nothing that they could do.this is getting very annoying.
And the iPOD docking station is a joke. In theory it sounds like a cool feature. No need for adapter cables hanging out of the glove box or radio. A nice professional, concealed docking station that will securely hold your iPOD while interfacing through the docking connector. However the radio will only recognize six playlists (which must be labeled CD1, CD2, CD3, etc). And the dealer told me the limit is 99 songs per playlist. I was assuming that the menu on the iPOD screen would appear on the NAV system screen and I would have the full iPOD capabilities. No such luck. I would recommend getting the 6 CD changer instead, less frustrating.
rpms on the left... come on it`s not that hard to rem... and rpms go up and down quicker than speed does...
The lack of iPod functionality is really annoying, and makes it almost useless, at least for the way I use it. I use random play sometimes, but usually I look up an artist and play an album. The iPod adapter won't let you do that.
My rabbit came with the 6cd changer and sirius radio, which i love, so being able to just plug the iPod into an aux input will make things that much better.
I didn't realize that they could install the aux input for you
The dealership is shocked, they say everyone wants the iPod adapter... if it actually worked I'd dig it.
Just wondering where the speakers are located in the 2 door mdels and the sizes?
Does the stereo sound good for a stock stereo?
Alison
i'm not exactly sure of the sizes are, but the locations are as follows (for 2 door models)
On the door itself:
two small (not tweeters) speakers by the door handle
and two large (probably 6 inchers) speakers on the bottoms of the door, and 2 tweeters up by the dash.
on the back there are two large speakers by the side armrests and then two small sized speakers on top of that.
also for alikeith: i went into best buy to figure out the sizes of the standard speakers for my current scenario. they have 6 or 6.5 inch ones in the front and 4 or 4.5 inchers in the back...hence the drilling involved if i wanted to keep my recently purchased infinity speakers in my old car.
anyhoo HELP!!
You already have it in your car! just use the auxiliary jack (the cable for it is a male/male and i got mine at best buy for 10 bucks) set the radio to the AUX input and you are good to go!
you may not be able to control the ipod throught the radio itself, but the sound quality is great and there is no costly things to do to use it! Its WORLDS better than a stupid fm transmitter!
Other then that I LOVE IT! Haven't had any other problems yet but only had it for three months.
:shades:
is anyone else just planning on upgrading the system with new speakers/headunit anyway and never have to deal with this again?
i don't think anyone has really made a differentiation on wether the car in question with the audio is a 2 or 4 door.
i just thought that given the amount of speakers vw give you, upgrading to an aftermarket kit would be amazing!
SOMEHOW I managed to get it to switch over to the AUX, but now I can't get it to pick up the AUX anymore suddenly. I have the cable, I have the player on, everything worked great before, but now...nothing.
Any help appreciated.
