as an owner of an 05, I know exactly what you are talking about. Toyota has iundoubtedly taken a most aggressive approach to its transmission programming and likely one of the reasons why the Av's FE is superior. However, what you are perceiving as a transmission problem is not really a tranny problem at all, it is a programming problem, that undoubtedly is effecting the way the car responds to your 'commands', but is also something that is becoming a common problem with many many of these new fangled multi speed 'electronic' trannies including those on some of the cars in this group. Ford's 6 speed as it was originally in the 500 was noted and reviewed to be 'hesitant', as has Hyundai's, as has GM's, as has VW's etc etc.. It's kinda a condition of the breed that I would imagine will continue to be a problem as long as these mfgrs. chase the almighty mpg (as well as all the 'safety' features that can now be added with all the electronic/computer 'interference'). Not to excuse Toyota for its overly aggressive (IMO) programming or for that matter how they are handling it afterward, but the fact remains that the tranny (5 or 6 speed) itself has been rock solid and it is 'working as it was designed' as I'm sure your Toyota dealer has told you.
In my case I have 'learned' to drive the car as 'it' wants me to drive it, and on that basis it works just fine, in all respects. It has been over 2 years and 60000 miles since I remember any tranny delay or hesitation even happening, although I'm sure I can 'induce' the beahvior if I wanted to.
The whole concept of the car 'telling' us what it wants (and FTM making a decision (of sorts) on driver 'intent') does sound ridiculous, but I'm afraid is something that will get worse before it gets better, and is not at all uncommon. There are computer nerds somewhere that are definitely deciding how we should drive and what our individual capabilities are. Isn't technology wonderful?
I do agree with you. It seems that Mazda, to keep up with their Zoom Zoom image, they're doing just that instead of following along with Toyota's blue print using DI and finding a good balance between power and gearing to offer great power and FE at the same time.
One thing I will say about the new 6, it sure looks slick! :shades:
As a testimony to how far we have come - many of the cars on this group - call them family sedans or whatever, will easily run with many of those big V8 honkers of 40+ years ago - and consume half the gas doing it!
Okay, okay...before we get in trouble...back to the topic at hand!
Don't forget Holly dual pumpers, high rise intakes, Hooker headers, dual point distributors, 4:11 rear ends, solid lifters,4 bolt mains,etc....I bought a new Z 28 in 1969...$3995 with a 5 yr/50k warranty....Gas was 0.28/gallon then...ran Sunoco 260 in that beast....as you mentioned earlier...many V-6's today can out perform and out run those old muscle machines...
the better the acceleration times, not necessarily the torque."
Obviously you've not driven any late model diesel powered vehicles recently.
Take the E-320 CDI as an example. Maximum torque for this 3.0L motor is 400 ft-lbs from 1600-2400 rpms. Horsepower is only 210 at 3800 rpm. What this means is that almost all the time, it is within that maximum torque band. In other words, at most speeds it is almost always in the maximum torque range no matter
what the speed. There is no need to down shift to accelerate faster as you must do with the 3.5L gasoline motor to gain maximum power and acceleration.
The gasser has 268 horsepower, but not until 6000 rpm. Torque is much less at only 258 ft-lbs
but not until 2400-5000 rpm. 0 to 60 mph for the 3.5L gasser is 6.5 seconds.
The diesel 3.0L is only one tenth of a second slower at 6.6 seconds.
With the diesel, there is maximum torque before you begin to move off the starting line, and if
you are not careful, there is much wheel spin. I don't think the gasser will spin the tires at all.
Now what happens when you are cruising at highway speeds and you want more acceleration as in wanting to pass? With the diesel, you simply tickle it slightly, and because you are already in the maximum torque range, you accelerate faster than the 3.5L gasser will do unless you floor the gasser and drop at least two or three gears. With the diesel, there is no need to floor it or downshift it at all.
In fact, doing so might mean you would accelerate slower.
Not only is the 3.0L diesel motor slightly smaller than the gasser (3.0L vs 3.5L) but it has an extra 142 ft-lbs torque (a 55 percent increase) and that is what makes it more powerful and at the same time, it gets a minimum of at least 25 percent better fuel economy while doing so.
So much for the discussion of torque and acceleration.
If the diesel were the of the same displacement as the gasser, the
gasser would then be slower 0-60 compared to the diesel.
Similar figures can be found while comparing the VW gas/diesel line.
Also in the Dodge, Ford, Chevy/GMC pickup trucks line.
Just wait until other maufactures bring their diesel powered vehicles to market.
Maybe you'd like to explain why the VW TDIs have always (and continue) to be slugs relative to their gas engined bethren? Despite more of that precious torque, could it be that the diesel does not have the ability to turn into useable HP fast enough???
But, we do agree on one thing, the diesel should make a comeback, as soon as those technologies that make things like the CDI so good (and unobtrusive) can become available in less costly vehicles - until then we'll just have to 'put up' with the VWs, I guess.
actually have, a MB ML320CDI SUV, and as I said it was quite remarkable and unobtrusive - in short, quite undiesel- like. The only thing that made it quite obviously a diesel - compression braking - when you let off the accelerator it's like you turned the car into a 100 mph headwind. Drivability has not generally been the diesels problem however because of all that low end torque as you say, acceleration, stink, and clatter - now those are things that should improve with these new generation 'clean' diesels as they become available. May continue to be a hard sell over here in the states though, too many folks remember those Oldsmobile 98s with that infamous 350 diesel.
Audi Q7 3.0 TDi Test Drive
and then you have this one as well...
Audi 5.9 V-12 TDi
Are you saying a diesel has a lot of compression braking? Not without an exhaust brake. The air inlet on a diesel is wide open. No way to close it like a gas engine. So, very little compression braking.
That depends on which gasoline motor you are comparing the diesel to.
If you compare the TDI with the standard gasoline 2.5L five cylinder
engine, that's not necessarily so.
The just available and at your VW dealers now here in Estados Unidos is
the Jetta Sedan and Sport Wagen with a 2.0L TDI (Turbo diesel injected.)
With 236lb/ft torque at 1750 -2500 rpm, and 140 hp at 4000 rpm, it may be a
trifle slower 0 - 60 compared to the standard 5 cylinder 2.5L gasoline
engine with 177lb/ft torque at 4250 rpm and 170hp at 5700 rpm.
Look what you need to do with that five banger gasser to get to the maximum
hp/torque rpms. This is with their standard available gas engine.
FE is but 20 city and 29 highway with an automatic.
The TDI is always right there on that fat torque plateau where you spend most of
your time, and again, there is no need to downshift to get good acceleration.
FE is 29 city/40 highway, but members over on Fred's will give you a big discussion as to those
FE figures being far to low when compared to what actual owners are receiving mileage wise.
I read there about mileages in the low 30s in the city and mid to
high 40s on the highway. Some even speak of 800 mile tanks.
Yes, VW does have their turbocharged 2.0L gasoline 4 cylinder with 200 hp,
but it will not achieve the FE of the TDI. It must have premimum fuel.
Over yonder, VW has that same short block TDI producing much greater
power, but alas, they won't bring that one over here to the N A continent.
Drop by your eager VW dealer and test-drive one. I think you are in for a surprise.
Regarding the infamous GM 350 diesels of 1978, I bought a new '79 Cutlass
Cruiser Wagon (ordered it loaded) and it was something else indeed.
Had it for two years and only 17K miles, and I did not experience the
problems that many people had with theirs. It was a real slug.
No turbo and no lock up T/C and only a three speed TH350 trans.
That motor was nothing more than a halfbred. A converted gasoline engine.
One can only imagine what a 5.7 liter modern diesel engine would be like today
given the advances in diesel engine design. Simply look at the Duramax,
especially the newly designed 4.4L yet to come out version.
A not to swift diesel either was the 4.3L six cylinder GM diesel
I had in my front wheel drive '82 Buick Century.
Many problems with that one. Piston slap (GM replaced two pistons under warranty)
a governor retainer ring failure in West Yellowstone. It had to be towed to
Billings and was repaired at no charge under the emissions warranty.
Tranny lost second speed when I kicked it down to pass in the four corners area of Navajo
country and I drove it clear back to California with only first and third gears and lockup.
Too much torque, as that motor had the most torque of any of the engines being put in
front of that tranny at that time (recall the four clyinder iron duke and the 3.0L sixes?)
Funny how GM always puts their vehicles in the hands of the public to 'prove up'
their product. They wonder why they are in BIG TROUBLE now!
I digress, Sorry.
"Unfortunately telling people they should think differently just doesn't work, and yes, perception is reality in the market. Nameplates like BMW, and Mercedes earned those reputations...."
Yeah, and now they've spent the last decade frantically un-earning them, and people have begun to notice -- which is why the dull, reliable and service-oriented Lexus brand has moved into the void so successfully. "Perception is reality"? Yes, If you're buying their stocks or handicapping their sales, yes. If you're buying their cars, no -- reality is reality. The reality of the Hyundai Genesis is big room, rear drive, full options, extreme quiet, and modern engines. There are only two parts of the physical car that fall notably short of its lux-brand competitors: the fake wood and the slanty-H logos. Which means, unless you're fanatical about timber, you're not objecting to the owner's experience driving the car -- you're objecting to the reaction of spectators. As for me, I hope they all hate it so I can drive in comfort and luxury for thousands off. Screw 'em.
"As I said, a large V-8 is where everyone has been, but is not where everyone is going, and those folks looking for that big V-8 are the very folks that are comfortable with the Lexus, BMW, Infinity, etc."
Even accepting your premise of handicapping the popularity of the cars, this comment misses the point. When Lexus and Infiniti models like the GS and the M offer a choice between V6 and V8 power, very few buyers actually buy the 8. It's there as a halo choice, for image. You'll notice that the excellent Acura RL died like a dog, in large part because it didn't have that halo to mesmerize people who'd end up getting the V6 anyway. Hyundai fully expects, and so do I, that most Genesis buyers will choose their excellent V6. In short, in all regards EXCEPT image, the V8 simply isn't very important, and even Hyundai has always known it.
Or perhaps you don't like the driving experience, which you completely left out of your "two-parts." Perhaps it should be "at least three-parts?"
C&D had this to say about driving the vehicle:
We mentioned the suggestion of athleticism, and that’s what it is: a visual suggestion quickly tempered by dynamic realities when the road acquires curves and kinks. As we noted in our August preview test, Hyundai didn’t skimp on the suspension, which employs multilink hardware fore and aft, with aluminum componentry. But it didn’t take long on some of our favorite back roads to convince us that the decisions made by the chassis engineers in the area of spring rates and damping could benefit from a little revision. Maybe more than a little.
On smooth freeway stretches, the ride is creamy and quiet. But on those back roads, contoured and crinkled by Michigan winters, it was not difficult to use up all of the suspension travel, yielding hard bumps and episodes of head toss.
They go on to say its a luxury cruiser, but not on the same page as vehicles such as the BMW 528.
Automobile Magazine, in comparing the Genesis against German and Japanese Lux competition had this to say about the driving experience:
On glass-smooth on-ramps, the big Hyundai takes a deliberate, slightly tail-out set, thanks in part to an enormous rear antiroll bar.
But add a few bumps, and the Genesis takes a turn for the worse. Unlike any of the other sedans, the Hyundai falls completely to pieces on twisty, bumpy back roads. Push it hard, and pavement irregularities send the Genesis heaving and wallowing down the road with the traction control light flashing and the steering wheel shuddering. When you're hustling with a car full of passengers, its soft rear suspension crashes onto its bump stops over moderately rough roads.
Sure, hard-core cornering probably isn't on a lot of shoppers' lists when looking at the $40k Hyundai, but I post this to say that there are definitely some places where the Genesis needs to improve besides wood trim and brand prestige.
Best regards,
TheGrad
Maybe Mercedes, but not BMW. And certainly not in every market segment.
could benefit from a little revision. Maybe more than a little. [Ah men!]
the suspension travel, yielding hard bumps and episodes of head toss."
Just like the Azera.
Hyundai's suspension engineers are not up to the task of properly designing a good suspension system.
I know because we are on our third set of front shocks for our Azera in less than 14K miles.
Hyundia's Mando supplied shocks simply do not last and are not up to the task, and from what some magagine writters are saying, it doesn't appear that the Sachs shocks in the Genesis are any
better. What a shame. Excellent cars failing because of Hyundia's suspension engineers!
In both cases, one wonders why Hyundai did not go to Bilstein or KYB
in the beginning when shopping for shock absorber suppliers. :confuse:
No need to feel sorry Dave. What year was your VW Diesel?
So a search for Fred's TDI or go to: www.tdiclub.com
That will get you to a group of VW enthusiasts bar none.
As a group, we know the VW diesel better than the dealers, I kid you not!
I am always surprised how many VW diesel owners have never heard of this group.
With over 64,497members World Wide of which over 18,000 are considered active,
it has been around for over 10 years and is continually growing.
Fred is a fellow who started that group many years ago when he didn't own a diesel
and this group simply grew and grew. Whatever you need to know, the members
there know the car.
I have also communicated with other manufacturers and been cordially treated.
But, NOT Hyundai!
08/26 sent a letter to CEO with what I would like to see on the Genesis. Most suggestions were things on the Azera, but not on the Genesis and moving some features from the 4.6 to another package on the 3.8.
09/05 letter stamped received in President's office.
10/02 letter stamped received in Consumer Affairs Dept.
11/21 letter stamped received in Legal Dept.
11/21 letter returned to me with a cover letter from assistant general counsel.
Their letter states: "As a matter of course, all correspondence received by HMA containing suggestions for design changes, new products, marketing strategies, advertising slogans or the like, is forwarded to the Legal Department for reply. Please be advised that it is against the policy of HMA to accept unsolicited ideas from persons outside the Hyundai organization. In accordance with this policy, we are returning your correspondence with this letter. Please consider this letter as HMA's response to your August 26, 2008 correspondence."
This is why Hyundai will not suceed as a luxury car manufacturer and will ultimately have problems becoming a major factor in the American market.
A better way is to post your suggestions and concerns in a forum like this one. Hopefully they monitor these forums. If they don't then you last statement in the above post is most certainly true.
Again thanks for the answer,
van
Exactly what other automakers would have replied here as well. Your Lexus situation was about a purchase decision; it's different here, as it was concerning about future products. So while you didn't get what you wanted to hear, it was the right thing Hyundai did. Companies do this on a regular basis.
More on Jalopnik, at the link below.
click here for the Taurus pics
The only problem I see here is the chrome surfaces around the gauge pods -- they'd be a guaranteed source of annoying reflections on a sunny day.
Yes Jaguar used to be known as the Mechanic's Nightmare...but that was prior to Ford.
What Ford has done for Jaguar's quality is nothing short of a full-fledged miracle.
Before you wrongly continue to malign this brand's quality image, I'd suggest you spend a little time 'first' reviewing Jaguar's quality ratings at JD Power.com You will find that under Ford's ownership, the quality of the vehicles has gone through the roof and has bested many far more expensive brands...more than once in the last decade.
You're info is simply wrong based on my ownership experience of my 2003 Jag.
Roland
Lonely edmunds poster sitting at home with nothing to do...likes to critique cars...has opinions that may be valuable someday, altho to whom is currently unknown...secretly yearns to be in focus groups, even tho I, myself, am occasionally unfocused...if you're willing to take a chance on a nice guy, give me a call, 800 555 1212...you won't be sorry...
Still looks great, no real wear issues on the interior. No plans to trade or sell. It is still the best car for the money I have ever owned.
Collision repair or unresolved warranty issue?
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
They had ordered the part for me before, but when I finally took it to them to get it done...they found out that the wrong part had been shipped, so they ordered a 2nd one. It comes in...and again, the wrong part. The part number on the packaging was right, but the part inside was wrong. So...they had to take pictures of the part taken out of my car, send a few emails and wait for the part to be shipped, from Korea once again, before they can install it. :sick:
The poor little Sonata they gave me as a loaner truly makes me miss my Azera. However, on the bright side...we picked up an '04 Audi A6 about a week ago that has eased my mind a bit.
Admittedly I haven't driven one, as I know it will be hard to stay rational if I do, but I spent a great deal of time at the local auto show going over one.
I'm a big guy so interior space is a concern and an area that my 08 Accord really excels at. I wanted to see how the G8 fared.
There were 2 different G8 GT's at the auto show. Very nice salesman from Dartmouth Motors in Newport NH answered every question I asked. He was anxious to get me in for a test drive but I tried to convince us both I was just looking.
Both cars had performance & sport packages with the 19" summer rubber. The black one had a sunroof, the white one did not.
Interior space is about equal to my 08 Accord, great elbow, leg, hip and shoulder room front and rear. I can comfortably sit behind myself. Biggest difference was headroom. The G8 roof line is lower and that, coupled with the black headliner tightens things up both physically and visually. THe Accord gives me signifigantly mroe headreoom and a generall "airyness" that isn't present in the lower slung G8.
The black car had a sunroof which eats a bit more as well. The white one I sat in had no sunroof and it made a noticeable difference. Given how tiny the sunroof is anyway, I wouldn't want one.
I thought the interior plastics were of good quality, nicely textured with decent gaps. It's no Audi, sure, but it's not a early 90's Saturn either, it did not feel "cheap" by any stretch, very much on par with my Accord.
The red and black leather was of good quality and looked fantastic. The seats were very comfortable, with more bolstering then my Accord seats, but not so much that they felt too tight even for me. The center console comes up higher in the G8 then in the Accord so that holds you in as well. Trunk is large enough for my needs.
The white really did nothing for me but in black, this car is so fantastic looking, wheel gaps were small, short overhangs, and the overall shape was very sporty. The wheels were a bit bland but fit the overall design well. Brake disks look HUGE behind them. One minor concern I could dig for is the low front clip. I've already scraped up the lip of my Accord and it is easily twice as high off the ground then the G8. Deal breaker? Nope, but a consideration with my area's plethora of crappy roads, steep dirt driveways, and 5 month winters.
Overall I was very impressed. For a non-driving review it met or exceeded my expectations. Frankly the only thing keeping me from buying one right now is price and a general fear about the economy. Not that it's not a great value (these were "special priced" at $27.5) but just that I don't car-shop much over $20k, just not in my budget. But I can REALLY see me looking at used ones a year or so from now.
http://twitpic.com/2bnfj http://twitpic.com/2bgaf
The Hyundai Assurance helps alleviate that problem. Lose your income within the 1st year after you buy it and they pay your car note for 3 months. After that, if you still don't have income to pay the car note, you can sell it back to them with no affect to your credit.
Maybe you should wait for the 2010 Ford Taurus. I've seen the website and it's a very nice look for the Taurus. SHO version is packing 365 hp to keep up with the Genesis, G8, 300C & Charger R/T.
2010 Ford Taurus
Yeah...the A6 is truly a nice car. First German car I've owned and I can see why they are highly regarded when it comes to suspenion. Even with a sport tuned suspension, the ride is VERY nice. Not to mention the fact, stock tires are 234/45-17's. I would have expected the ride to be harsher with low profile tires, but it is quite complaint and comfortable.
Reminds me of a shower door I ordered from Sears, years back. Wanted silver, arrived as gold. Reordered. Got another gold. Found that the catalog numbers for silver and gold were reversed! So we ordered the gold to get the silver! But in the meantime, Sears saw the problem and internally changed the numbers.. so, received yet another GOLD! Fourth time worked OK...
MODERATOR /ADMINISTRATOR
Need help navigating? [email protected] - or send a private message by clicking on my name.
Share your vehicle reviews
