Toyota Yaris Transmission Problems
yaris46yaris46 Member Posts: 24
Anyone change the gear oil on their 1.5 liter? I had a hell of a time doing it and wonder if any Toyota Mechanics are out there. DO YOU FILL THE TRANNY TILL IT COMES OUT THE FILL PLUG? I HAVE HEARD YOU ARE SUPPOSED TO LEAVE A FEW MM BELOW THE PLUG OR YOU CAN BLOW SEALS.
Anyone QUALIFIED have an answer?
«13
    nippononlynippononly Member Posts: 12,555
    are you changing the gear oil already?
    The gear oil from the factory is dino. Synthetic oils are far superior in terms of shifting AND longevity of components. My car has 2000 miles and I have Mobil 1 and a Mobil 1 oil filter on it PLUS I changed the gear oil to REDLINE MT90 which is a vastly superior lubricant compared to whats in the car when it comes from the factory.
    well, to answer your question a bit, yes, the manual transmission oil is supposed to be pretty much up to the hole. You should be able to put your finger in and feel the oil level just below your finger. This is a general answer based on my past experience with many other cars where I have changed the gear oil, NOT specifically related to the '07 Yaris. So if you want to be sure, read the manual. :-)
    lhansonlhanson Member Posts: 268
    So would you go ahead replace the factory lubricant like Yaris 46? If not, when would you replace it? I get the feeling that you are holding back your knowledge from the rest of us.
    I contacted several service techs, As I had thought, the level is FAR FROM CRITICAL. You can have a little more or a little less, its not THAT IMPORTANT. What IS important IMHO is the QUALITY OF LUBRICANTS used in your car. Thats why I ALWAYS put REDLINE MT90 in all my manual transmissions after break-in period. As for engine oil I PREFER REDLINE but its 9 bucks a quart, so I use Mobil 1 AND a Mobil 1 filter. FRAM IS PROBABLY THE WORST OIL FILTER MADE so if you decide to go synthetic make certain your using a top quality oil filter.
    Nah, I wouldn't bother. I have seen Toyota manual transmissions go out to 200K miles with dino oil changed once halfway through, without a problem.
    Now as for synthetic vs dino ENGINE oil, well that's the age-old debate on these boards isn't it? I don't bother myself, but I won't say the folks who do it don't gain some benefit from it. It probably provides better lubrication at cold start-up, although Toyota engines seem to be able to go the stretch (200K) without it, so why go to the extra expense? Just change your dino oil every 5000 miles and save some money.
    Its not just longevity, For example my Roadster is a 2006 MX-5. The 6 speed was a bit tough to handle for me since I am disabled and have only partial use of my right hand. BEFORE installing REDLINE MT90 I had to reach over with my left hand to shift to 5th and 6th gear. AFTER MT90 the tranny is sSO MUCH EASIER that I no longer need to reach over. NOW THINK, IF A LUBRICANT CAN MAKE SHIFTING EASIER THEN THINK WHAT IT CAN DO FOR KEEPING A HEALTHY HAPPY TRANNY!!
    Yeah, I hear you, but my original point stands, as personal opinion ONLY: if the tranny is going to be happy and healthy to 200K anyway, I can't be bothered to change from the manufacturer's spec.
    Your absolutely correct. That train of thought also applies to using cheap dino oil and low budget Fram oil filters. They will do the job and as long as you change your oil every 3K you should be OK. As for MY ENGINES I prefer to know I have TOP QUALITY FILTERS AND LUBRICANTS in my engine. Your approach is certainly more cost-effective. My approach wastes money BUT probably adds significantly to drivetrain longevity AND gives me peace of mind. I haven't used a FRAM filter and Dino oil in 10 years!
    You are the type of person I would like to buy my used cars from. After 5 years or so, I would think that you would have a hard time getting a dealer to give you any more for your trade-in than nippononly would get for his car, assuming all other aspects of the cars are equal.
    After 5 years I will have over 200K on my car. I am not an AVERAGE driver. If you plan on trading in your car and have no enthusiasm whatsever for your vehicle I suggest Wal Mart oil and filters all the way! BTW: Wal Mart oil filters are VERY GOOD QUALITY. I have no plans on trading my car, I will drive it to the ground.
    robertknrobertkn Member Posts: 94
    Hey, I have a question related to the auto tranny. I just picked up my new LB last week. Does anyone have any input on the long term effects of using engine braking by downshifting the auto trans? Is that hard on an engine or tranny? Thanks.
    QUESTION: Whats cheaper, BRAKE PADS or A TRANSMISSION?
    I think that answers your question. Why would you subject an expensive component that is not designed for braking to such abuse? Thats what brakes are for! IMHO: Next time buy a manual but sincev your stuck with a slushbox you will now need to properly maintain it every 25K. A complete transmission fluid flush should be done regularly and the filter changed. Yet another reason besides poor gas mileage to never buy an automatic. The US is the only country where automatics are in such high demand. Europe and Japan drivers know the advantages of manual transmissions and purchase accordingly. Its the fat lazy American that complains its too much work to shift gears in a car!!
    that was a bit of an indictment without cause, wasn't it?
    Toyota makes many of its automatics with "lifetime" fluid (no routine fluid changes are called for) now, unless you use the car for towing. Feel free to view that with as much skepticism as you would like, and I don't know if that includes the new Yaris, but it certainly included the Matrix I had.
    robertkn, I wouldn't do it, because I think it WOULD be hard on the transmission in the long run, although many will tell you that in these days of computer-controlled automatics they can handle the behavior you describe.
    Actually...my question was not whether you think a manual transmission is better than an automatic transmission. That must be a different thread, but thank you for your opinion.
    1. How much does it cost to have a clutch replaced periodically?
    2. The Yaris Owners Manual specifically explains how to perform engine braking by downshifting the transmission, thus my question (which yaris46 did not even address). If the transmission were not designed to do so, why would the process be discussed in the manual?
    3. If a transmission is not designed for braking are you saying that you do not downshift your manual tranny to slow down your car? When in high gear you just depress the clutch and hit the brakes until it stops?
    4. The gas mileage rating for the manual tranny is only 1 mpg higher than the automatic.
    Hoping to hear from someone who knows.
    boris13boris13 Member Posts: 80
    "The gas mileage rating for the manual tranny is only 1 mpg higher than the automatic."
    From all the reviews I have read, many people with automatics are getting much worse than the EPA mpg estimates in real-world city driving... more like 27-30 instead of 34. However, manual owners are getting closer to the EPA city rating, in the 31-34 range.
    That made my decision to order a manual-shift LB easier.
    In that case I'm very pleased to report that after just doing my first fillup at 231 miles, the mpg for my new liftback/automatic computed out to 33 mpg--98% of which was city. Yay!! :)
    Wait, if the Yaris owner manual tells you how to do it, then why are you worried? I doubt they would tell you how to do something that would damage the car.
    Didn't say that I was "worried" per se. It's just that I've always owned automatics and have never done that and, for that matter, have never known anyone who did. It actually seems like a good idea, I just don't know whether it's something that will affect the longetivity of an automatic transmission. Maybe nobody knows...
    I have only owned an automatic once (and based on that I never will again), but I used to plan the downshifts just before I needed the engine braking, while my foot was still on the gas. That always seemed intuitively less hard on the transmission.
    With regards to the question as to whether I use my engine to downshift and slow the car the answer is: NO! I am aiming for 300-400 thousand miles on my motor and drivetrain. I will GLADLY pay for a lousy set of brake pads over reduced engine longevity. This is NOT ROCKET SCIENCE!
    Its simple common sense that the less strain put on your engine will extend the life of your engine. The benefits of downshifting and bringing the RPM's up over 3-5 K are what exactly? I won't put brakes on for an extra 10,000 miles? BIG DEAL! I drive this car completely differently than my performance cars. I keep my RPM's under 4K at ALL TIMES and generally run at 2.5-3.5 thousand RPM. I not only get outstanding gas mileage but I am also putting very little stain on my powerplant and drivetrain. I have owned several Porsches, Audis, M3 BMW's etc. and I certainly don't drive a performance car in this manner. The Yaris is an OUTSTANDING econobox BUT IT IS AN ECONOBOX! Downshifting a Yaris to slow the car down is IMHO not the best way to extend engine life which is my ultimate goal. If your driving a Yaris as a fun sporty car and can't afford a performance car than I certainly can understand revving the engine and downshifting at red lights etc. Its ALOT more fun to drive this way! Unfortunately it is not something that helps to extend the lifespan of the engine.
    As for "lifetime transmission fluid" if someone is that stupid as to not change the transmission fluid at least every 30,000 miles than God bless them when they need a new tranny. This again is simple COMMON SENSE. Would you not change your engine oil? Your transmission fluid is as important to the transmission as engine oil is to the engine!!
    "The benefits of downshifting and bringing the RPM's up over 3-5 K are what exactly?"
    Well, bringing the RPM's up obviously isn't the intent of using engine braking. The intended benefit would be to slow the car down. But, I see your point now. The downshift brings up RPM's thus increasing heat and putting the stress of the car's inertia on the drivetrain rather than the rotors. Since brakes pads are cheaper than gears, why do it? Seems logical.
    "If your driving a Yaris as a fun sporty car and can't afford a performance car than I certainly can understand revving the engine and downshifting at red lights etc."
    Nah, not so much. I just sold my Volvo 240 with 214,000 miles on it and it still ran great. So, what does that tell you? (I know--hard to believe it actually ran "great," but it did. No internal engine work ever done--other than valve adjustments.)
    I quit using the Fram stuff a couple years ago once I learned the "truth." The average consumer just doesn't know any better, as Fram has been around for so many years. I use Baldwin oil filters which seem to be really well made. It almost instantly cleared up a tappet noise I had in my 1988 Caravan.
    Now, if you go to synthetic oil do you still have to drop both the oil and filter every 5k during the warranty period? I thought I once heard that with synthetics you don't need to drop the oil at every change. Thanks for the tip about formally "notifying" Toyota of the lubricant change.
    dkarschdkarsch Member Posts: 72
    Maybe you can post your mechanic credentials online since you feel that you obviously know more than the rest of the universe. LIGHTEN UP!!!!
    While someone who doesn't change their transmission fluid ever is on one end of the spectrum, you are on the other end and needlessly wasting money. My mechanic who has been taking care of my vehicles for the past 14 years recommends 60,000 mile change and I trust him a lot more than I do a random poster on this message board. :mad:
    Of course you can change transmission fluids at 60,000 miles. I suggest you perform a test on your own car. Drive 60,000 miles and then extract a cup of tranny fluid from your car using an extraction pump (20 bucks ebay) then have your transmission fluid changed and changed PROPERLY (I doubt your mechanic even flushes the system if he thinks 60K is satisfactory, he probably drops the pan and changes the filter and fluid, this leaves over 2/3 of the old fluid in the tranny) After changing the fluid PROPERLY then drive your car 30K and change the fluid. I GUARANTEE THE 60K FLUID WILL BE DARK BROWN AND HAVE A SMELL. I ALSO GUARANTEE THE 30K FLUID TO BE FRESH AND PINK WITH NO SMELL.
    This kinda stuff is just plain common sense. Why on earth would someone be so cheap as to only change their tranny fluid every 60K? ITS CHEAP INSURANCE TO CHANGE IT EVERY 25-30K! ALOT CHEAPER THAN REPAIRING AN AUTOMATIC TRANNY!!
    As for synthetic oil changes you can actually go for over 25,000 miles on some synthetics and by having your oil tested you can confirm its OK. Once again this is also simple common sense: I WILL GLADLY PAY THE EXTA MONEY FOR MOBIL 1 AND A MOBIL 1 FILTER AND CHANGE MY OIL EVERY 6,000 MILES. Does my car need a filter and oil change at 6,000 miles when using Mobil 1? Of course not but its CHEAP INSURANCE and synthetics have been proven time and again to be superior particularly during cold starts where alot of engine wear occurs. BOTTOM LINE: SPEND THE LOUSY FEW EXTRA BUCKS AND DUMP YOUR TRANNY FLUID AT LEAST EVERY 30K!
    USE FULL SYNTHETICS AND A MOBIL 1 FILTER! (At this time there is no other quality oil filter available for the 1.5 liter motor)
    If you were fortunate enough to buy a manual I suggest dumping the gear oil and replacing it with REDLINE SYNTHETIC.
    Well MR KNOWITALL...as a matter of fact my mechanic uses a device which replaces 100% of the fluid. Funny how you like to make assumptions about the quality of his work. I would stack his knowledge of cars against yours any day of the week.
    Why start at 25K miles. Why not change your schedule to every 15 thousand or maybe even drop it to 10 thousand miles. And you could buy that expensive synthetic oil and change it and your filter every 1000 miles.WHY.....BECAUSE IT'S CHEAP INSURANCE AGAINST AN AUTO REPAIR
    you could also attach foam rubber to the exterior of your car to avoid ding and dents from stone and car doors in parking lots. Let us not forget about acid rain...make sure to cover your car each and every night to protect the finish.
    WHY...BECAUSE IT'S CHEAP INSURANCE AGAINST COSTLY AUTO BODY REPAIRS AND REPAINTING BILLS.
    Please do tell us how you have amassed such an expansive knowledge of auto care and repair. I don't know why we didn't see sooner that all the car manufacturers and mechanics in the world are wrong and you are right.
    the freaks come out at night, huh?!
    My car was an '03 Toyota Matrix. Not only did the maintenance schedule for that car SPECIFICALLY SAY no routine fluid changes were recommended for the automatic transmission fluid, they actually put a sticker right on the transmission dipstick handle saying the same thing.
    The only exception was if you used the car for towing (that car had the very modest towing limit of 1500 pounds).
    So it wouldn't be stupid, it would be following the owner's manual, written by THE PEOPLE WHO DESIGNED AND BUILT THE CAR. SERIOUSLY, lighten up, your tone is fairly offensive. :-(
    edit...BTW, many modern cars are the same way. I haven't read the Yaris's owners manual so I don't know what is recommended for this model, but since other Toyotas have the same maintenance-free auto trans fluid, the Yaris may also...
    So the common wisdom in this thread is to NOT CHANGE FLUIDS EARLIER THAN SPECIFIED?
    Toyota SELLS CARS. They MAKE MONEY when you BUY CARS.
    This is routine maintenance 101. ALWAYS change fluids earlier and more often than recommended. My MX5 states oil changes at 7500 miles using dino. Do I wait 7500 miles? Thats ridiculous. I change my oil at 6K PERIOD and use only synthetic. My Porsche 911 manual specified oil changes at 15,000 miles. Do I change it as specified by Porsche? Of course not. Oil and filters are far too cheap too wait 15,000 miles between changes. Its YOUR CAR, YOUR TRANSMISSION. I can assure you of one thing. An automatic transmission that is flushed and maintained properly every 25-30K has a FAR BETTER chance of extended life and being problem free. Has anyone ever changed their own tranny fluid? Anyone ever dropped a pan on an automatic to see what happens when fluids aren't changed? I have seen clogged filters, burned and filthy transmission fluid, and failed transmissions because PEOPLE THINK THEY KNOW WHATS BEST. Another common misconception: rear end gear oils last the life of the car. Ford specifically states on my Explorer that the rear end gear oil is not to be changed for the life of the vehicle. THE QUESTION IS: WHO DETERMINES THE LIFE? FORD WHO SELLS CARS OR YOU THE OWNER? And why are there plugs in the housing that allow you to change the gear oil?
    So I assume that using the logic presented that the SMART THING TO DO IS NEVER CHANGE THE GEAR OIL? Even if the Explorer has 300,000 miles and a new engine for example? ITS SIMPLE COMMON SENSE, CHANGE ALL LUBRICANTS AND FLUIDS IN YOUR DRIVETRAIN ON A REGULAR BASIS AND DON'T USE COMPANY SPECS AS A GUIDE. THEY SELL CARS!!
    Getting back to the downshifting thing for a moment, yaris46 what do you think of this comment I happened to run across in another thread:
    "If you have a manual [transmission], it can help a lot to leave it in gear when decelerating, as that helps the rings to seat, which will contribute greatly to decreasing oil consumption later in life.."
    Nippon,
    I wouldn't even bother trying to have any type of dialog with Yaris46. I wish there was an ignore button like the yahoo message boards have that would filter out his posts. I enjoyed jabbing fun at his ridiculous posts but I will no longer respond to him.
    There are many types of people in this world and occasionally you run into someone like Yaris46. They are the type of people who always think that they are right, will try and talk over everyone else in meetings or discussions and unfortunately alienates almost everyone they meet with their abrasive manner.
    Most of the posters on this board while having different opinions, can have a civilized dialog with each other. Apparently yaris46 isn't one of them.
    There are several different trains of thought regarding seating rings in an engine. Many people believe that using synthetic oil when the engine is new will not allow the rings to seat properly since synthetic oils are slipperier. Others feel the best way to seat rings in an engine is to run the engine FULL BLAST as soon as you buy the car! I personally run my engines for 2000 miles then dump the dino and replace it with synthetic. I have never heard of downshifting helping to seat rings although its extremely important to vary engine RPM's for the first 500 miles and this is a part of the seating process. I have almost 20,000 miles on my engine in less than 3 months and I don't burn a single drop of oil. In fact I don't even bother checking my oil level any longer since it always reads exactly the same! I will start checking again at 40,000 miles.
    snowmansnowman Member Posts: 540
    I really like the new Yaris and I've been lurking to discussion forums to read what others say about. This particular topic about transmission oil change interval took my attention.
    I like to pass my 2 cents on the technical aspect of the discussion.
    Unlike what some auto mechanics and manufacturers say, anything beyond 30K tranny oil replacement interval is an invitation for costly repair bill.
    Conventional tranny oil will start showing contamination signs @ after 20K usage. I usually reach that point @ 18K. I perform the flush myself, pretty much every year.
    Unlike EU manufacturers, US manufacturers don't even mention brake fluid and PS fluid replacements as maintenance items in their manuals. However, they are crucial items.
    So, the point is, don't believe everything you hear or read. Do your own search and make desicison.
    Yaris is a new design, consumers shouldn't be surprised if some problems arise. But overall, it is backed by Toyota.
    bambesibambesi Member Posts: 9
    Ok... I got a response to my question (new yaris lemon?) but really it didn't answer my question. There are so many Yaris owners... can other people please answer that post and tell me if what my engine is doing is normal? And if so, why does it do that? The other poster said it was because of the self-adjusting transmission(?) I have not heard of that, could that be it? I am very concerned about this. Anyone?
    If you are that concerned about it, take it back to the dealer. It is still under warranty, isn't it?
    typer73typer73 Member Posts: 11
    My auto liftback also does the same. I never thought it was a problem, just the way the car drives. Don't know why... never tried to find out because it just doesn't bother me. :confuse:
    I don't know about the self adjusting trans thing. This is the first I've heard of that. However, my wife commented that our liftback sometimes seems to shift "funny." Now, I don't really notice it when I drive, but she has commented on it more than once. I think the shifting is electronically controlled and the way one applies the accelerator might affect how the transmission shifts.
    I would suggest 2 things. First, check the owners manual for information on the transmission. The manual sometimes provides some unique details about the car that you would not otherwise know. Second, I would definitely take it to a dealer and let someone else drive the car while you ride along. In that way you could point out the problem and maybe determine whether it is related to driving style.
    If the characteristic is present with any driver and the dealer just blows you off I would take it up direct with the manufacturer. You still might not get anything done, but at least it would be reported. You never know when something like this might lead to a recall some day.
    ray_h1ray_h1 Member Posts: 1,134
    )) "I don't know about the self adjusting trans thing. This is the first I've heard of that." ((
    You do lead a sheltered life... ;) Without getting into the quagmire of certain Toyota AT problems covered in other forums, all modern automatic transmissions are "self-adjusting". They're now under the control of computers to continually set and adjust shift quality according to engine RPMs, temperature, vehicle speed, engine load, and, not least importantly, operator driving style - aggressive drivers get a somewhat firmer shift over time, while more temperate drivers enjoy a settling-in of consistently smoother shift quality. Once a predominent pattern is established, the shift control computer will automatically compensate for long-term clutch pack wear to maintain the established shift quality until it's rebuild time. Prior to computer controls, automatic transmission shift points were modulated strictly by engine intake manifold vacuum - and doing so worked fairly well to a point. But I'm old enough to remember my dad taking the family '55 Plymouth with its two-speed "PowerFlyte" transmission in for a periodic band adjustment every 12,000 miles where the technician would adjust for clutch band accumulated wear to re-establish the proper shift point feel. How many of you reading this remember ever having had to do any such thing?
    randyliciousrandylicious Member Posts: 3
    I'm a little hesitant to post in this discussion, but the flame war above seems to have smoldered and gone out and my question is definitely about a Yaris transmission problem.
    My Yaris Liftback M/T has 5900 miles on it.
    This weekend (driving around San Francisco) and today (driving home in very heavy traffic) I noticed the gear linkage squeaks when moving from first into second. Inside the cab, the squeak isn't too loud, but sitting on the driveway with the engine off and the door open, it's very loud. The shifter moves smoothly, and it doesn't make noise moving out of second or shifting from third to second.
    Has anyone else noticed this problem? Does it sound like impending doom?
    The driving conditions for these two days were way out of my norm (open freeway commute, short distances in town).
    jollyreaperjollyreaper Member Posts: 9
    It seems that a common error amongst us Yaris drivers is leaving the car in third gear rather than drive. It sounds like the problem is due to the confusing design of the shift mechanism. I would like to make sure that I'm understanding the problem and solution here.
    The shifter does not just move up and down but also rocks left to right. As I understand this, if you leave it pushed to the left it's in third gear but if you push it to the right you are then in fourth gear?
    That's weird. What could possibly be the reason for designing it this way?
    lovcomlovcom Member Posts: 5
    Yaris46 is showing his age....old thinking....old school thinking, big on emotion, dillusion, and superstition.
    Toyota says to change the tranny fluid on an as neede basis...this can mean going 100,000 miles or more between changes, your situation depending.
    I have had several Toyotas that I NEVER changed the tranny fluid on, and all of them reached 120,000+ miles with no tranny issues.
    And the reason Toyota suggest little or no changing of the fluid is NOT to sell more cars...this is stupid thinking...but the reason is because if the fluid is okay (regardless of milage) then changing the fluid is just waste, regardless of how cheap it cost to change.
    If going so long was so bad, then Toyota would have millions of complaints which would translate into a really bad reputation, massive loss of sales, etc...of course this is not the case...Yaris46 is big on emotion, low on facts, and reality....sad.
    Just learn to drive your car...this really is not an issue...this is a simple training issue...just be mindful for a few days, and like me, you too will stop keeping the shifter in 3rd....this issue stopped being an issue for me after a few days.
    This is not a design problem. Mercedes and Chrysler use this "gated" design, and it is a benefit, not an impediment, as it helps prevent mis-shifts.
    Read the manual! ;-)
    kenc9kenc9 Member Posts: 7
    I remember having the bands adjusted HAHA I'm a "old Guy". This, along with others is why I got the 5 speed MT. I am sick and tired of trannys just failing one day for a whole lot of money and time getting it repaired. The MT's will give you years of warning IF they are goint to go out and give you extra power as well. The Yaris is so light and quiet that with my radio on I can't hear the engine and I am trying to save the clutch so I am trying to keep the RPMs down at take off. Well I have stalled it in traffic about three times now. Dang I hate that...so I guess it will just take some time. This is my first MT in years.
    "You do lead a sheltered life..."
    You are an exhaust port. ;)
    Don't feel bad, I did the same thing for the first couple thousand miles and still ocassionally until I sold it to my son and got an automatic transmission. Now I don't have that problem any more.
    spike109spike109 Member Posts: 3
    I always thought that automatic transmission were better than manual transmission
    ________________
    Drew
    Toyota 07 Yaris - Get the Toyota 07 Yaris Catalog by Toyota Motors
    mcdawggmcdawgg Member Posts: 1,722
    My Corolla did that, and I just lubed the pivot points where the shift cables attach to the transmission. 5 minute job. I would take back to your dealer.
    girlcarbuildergirlcarbuilder Member Posts: 225
    Rule of thumb always......go by the service manual specifications! Factory manual is the best way to go. I have seen way too many mistakes in Haynes and Chilton's!
    A good mechanic never assumes he/she has the correct answer. If I went by history, it would be fill to the level. But I would not assume, I would check the service manual. That also gives you the correct service interval and fluid type.
    That factory manual may be expensive from the dealer, but it is well worth it in the long haul.
    You are correct for some makes, like Ford! On many of our foreign cars, we run a synthetic oil 10k miles with a good oil filter. Always run a WIX, never a Fram. Expect to pay at least $5 for it. Don't believe me, cut them open and see why. Historically, Toyota's are very true to the maintenance schdules. I have even seen a few that did not have proper oil changes hold up well.
    But the bottom line folks is good lubrication extends the life period no matter what you drive. As for another good tip, many fleets are now installing an inline filter and oil cooler for automatic transmissions. The inline filter has a magnet in it and it has a service life of 10K miles. Best to locate it before the cooler. Change it regularly and you will no tranny headaches to speak of. Oh, I have only found these parts at the transmssion supply houses like Transstar.
    Well an ocassionally deal like that is what I do with our rebuilt engines during the first five hundred miles. The high vaccuum helps suck oil past the rings to seat them better. 500 to 1000 miles that is not necessary, because most of the setting is in place. If you switch to synthetic oil, expect to be back to oil burning for a while because it is a better lubrication material. With synthetic, you will be well broke in with excellent gas maileage by 10K miles.
    Yes, I have seen Toyota auto tranny's with over 200K with no problems or service. I would suggest a fluid fliter change at least every 100K for insurance. I would also consider the new inline filters as well. Those inline filters are being used by many fleets now. Change them every 10K though, and you will never have that tranny apart from what I am hearing! Check with Transtar Transmission parts on net for those filters. This is a transmission parts major supplier to that trade. Real question is, how long do you want to drive that car? Many of mine are 20 years and older still in regular service! The mileage is way up there on one.
