File In Section: 04 - Driveline Axle
Bulletin No.: 01-04-18-001A
Date: October, 2002
INFORMATION
Subject:
Driveline Characteristics For All-Wheel and Four-Wheel Drive Systems
Models:
2003 and Prior Light Duty Truck Models
with All-Wheel Drive (AWD) or Four-Wheel Drive (4WD)
This bulletin is being revised to update the model years, models and information. Please discard Corporate Bulletin Number 01-04-18-001 (Section 04 - Driveline/Axle).
The purpose of this bulletin is to help explain the operating characteristics of 4WD/AWD systems.
Definitions
AWD vs. 4WD
The very basic difference between AWD and 4WD is the intended usage of the systems.
AWD is usually intended for on-road use in inclement weather conditions, while operating smoothly on dry pavement by allowing for a difference in speed between the front and rear axles while turning. These systems do not have low range gearing for the transfer case.
4WD is intended to be used in low traction or off-road situations. Part time systems do not allow for a difference in speed between the front and rear axles while turning. This system effectively locks the front and rear propeller shafts together. When turning, the tires must slip to allow for the different turning circle of the front and rear axles, which is why this is intended for low traction or off-road use. These systems have low range gearing for the transfer case.
PART-TIME 4WD
Part time 4WD refers to vehicles equipped with a transfer case to split power between the front and rear axles of the vehicle. This traditionally is a 2-speed selectable transfer case that can be shifted into 2H1, 4H1, 4L0 and usually a Neutral position. There is no device to allow for a difference in speed between the front and rear axles. Examples of vehicles with this style of transfer case would be a Silverado with a manual shift transfer case (a shift lever on the floor) (RPO NP2) and a Sonoma with a push button transfer case with a 2H1, 4H1 and 4L0 position (RPO NP1). The RPO codes for this style of transfer case are NP1 (NVG 233, 243, 263) or NP2 (NVG 231, 241, 261, BW 4401, 4470).
FULL-TIME 4WD
A second version of a 4WD transfer case is a full-time 4WD transfer case. This style of transfer case has an open differential to allow for different speeds between the front and rear axles and operates similar to an AWD system. This transfer case can be locked to operate like a 4WD transfer case and or uses a traction control system to assist in low traction situations. An example of this type of 4WD is the H2. RPO code is NR4.
AWD
There are two different categories of AWD Systems. The first category is true AWD. This type of transfer case divides torque to the front and rear axles at all times. This ratio can vary depending on the system, but is usually 30/70% front to rear split but can vary depending on traction conditions, up to 100% front or rear. This type of transfer case can have a viscous coupling along with a planetary gear set to allow for difference in speeds between the front and rear axle or an open type of planetary gear set differential. An example of a vehicle with this type of transfer case is a 2002 Denali. RPO codes for this type of transfer case are NP3 (NVG 149, BW 4473) or NR3 (BW 4481).
The second category is an on-demand AWD. This type of AWD basically delivers torque only to a primary driving axle until a slip event occurs. At that point, the system electronically or mechanically will apply torque to the axle with traction. Depending on the type of system, this can provide up to 100% of the torque to the axle with traction. These transfer cases use an electronically actuated clutch pack, a hydraulically actuated clutch pack, or a viscous coupling to allow for a difference in speed between the front and rear axles. An example of an electronically controlled version of the On-Demand AWD is in the Smart Trak system in the 2002 Bravada. An example of a hydraulically operated On-Demand AWD is the Versa Trak system in the Aztek. The RPO code for the Bravada is NP4 (NVG126). For some vehicle lines, there is not an RPO code. The only way to tell is by the Line Chassis VIN code B or V for the Rendezvous/Aztek, V for the Venture/Montana or by SM for the Vibe.
Automatic Transfer Cases
The last category is a combination of 4WD and On Demand AWD. These transfer cases have a 2H1, AWD, 4H1, 4L0 and Neutral position and would fall in the general 4WD category. This transfer case has the operating characteristics of both an On Demand AWD and a 4WD system depending on the mode selected. This transfer case uses a clutch pack to allow for a difference in speed between the front and rear axles in the AWD mode. In the 4H1 or 4L0 modes, there is no allowance for the difference in speed between the front and rear axles. An example of a vehicle with this would be a Sierra with a push-button transfer case with a 2H1, AWD, 4H1, 4L0, and Neutral positions. The RPO code for these transfer cases is NP8 (NVG 236, 246).
Characteristics
4WD
A part time or automatic 4WD transfer case will make - more noise while operated in 4H1 and in 4L0 (a full time 4WD will operate similarly in 4H1 lock or 4L0 lock). This noise can vary depending on the transfer case type, GVW ratings (generally the higher the GVW the more noise it will make), vehicle build variations, gear ratios in the axles, axle type, tires, and importantly driving conditions. This type of system's intended use is on loose traction surfaces such as a dirt road, mud or snow. If this system is used on hard packed surfaces such as dry pavement, driveline binding will occur because there is no device to allow for the different speeds between the front and rear axles. This will cause noise in the axles, transfer case and the rest of the driveline, and will usually increase the more the vehicle is turned. As the vehicle turns, the front and rear axles follow a different arc. When this happens, the only way to compensate is for the tires to slip, which will feel like the vehicle is crow hopping or grabbing. Even if the vehicle is driven in a straight line, there are slight differences in tire circumference that will cause some driveline binding. If a vehicle had the exact same size tires and was driven in a perfectly straight line, the fact that more parts are moving would mean that there will be more noise.
When driving in 4L0, the extra gear reduction will make additional noise compared to driving in 4H1.
While the transfer case is in Neutral, with the engine running, some noise can be expected. When the transfer case is shifted from neutral with the engine running, some gear clash can be expected.
AWD
AWD systems are designed to be used in high and low traction situations. These systems will generally be quieter on high traction surfaces than a similar 4WD used in 4H1 or 4L0. However, these systems will make m
I don't want to screw it up trying to remove it.
In any event, I have appt. with dealer to flush and refill front diff. We'll see how that works.
Don't see a TSB on this (yet)
Transmission was slipping @ 4000 miles and was replaced.
High frequency buzz from speakers that got louder as the rpms increased due to a bad wiring harness.
Rear vibration/buzz @ 40mph due to a bad exhaust heat shield.
Leak from front differential due to loose connector.
Condensation in 3rd brake light.
Wrong emissions decal on engine with 5.3L info instead of 6.0L info.
It was disappointing to find these problems and other damage caused by the dealer while it was with them during repairs. Also disappointing that the dealership doesn't provide the level of service expected when one buys a $50K vehicle.
However, I still believe this a lot of truck for the money and that its a better buy than the other luxury SUVs on the market.
I appreciate reading all your problems/solutions and will continue to share any problems/solutions I experience.
Oh, has anyone had any problems with their power steering? I'm beginning to hear noises when I turn the wheel while parking.
I also have a vibration from the rear left compartment where the jack is located..they "found it" took it apart, and "insulated" the rear air unit....ok for 2 days and vibrates again when going over bumpy roads slowly..it is more annoying than anything and my confidence in the dealer is gong downhill fast..
Hey anybody out there in the NE care to comment on how the Denali/DXL does in the deep snow you've been getting? I'm headed to Boston on business(no not driving) and got curious.
Last tank of petrol I got 15.4 calcualted (15.2 on DTC) running about 70%/30% freeway/city.
http://www.alldatadiy.com
jkpsaras: Thanks for the feedback regarding your steering noise. I'll definitely have mine looked at the next time I'm at the dealer.
After 2 minutes of warmup I put vehicle in gear and gave it very little gas (no more than 1000 rpm) and plowed thru the 24" on my driveway and thru the 35" mound that the snow plow kindly left at the end of my driveway. Like a hot knife thru butter.
Got on the main highway and saw nothing but SUVs. I wonder what those people who post here saying they hate SUVs and are trapped at home with their Yugos and such think now. Hope they didn't have an emergency and couldn't get out of their driveway.
Some cities/towns wouldn't let you drive unless you either had chains on or had a 4 wheel drive.
This vehicle is worth every penny I paid.
I have an 02 Denali and only see the latch mechanism on the bottom...
At the moment I have no need to use the child seat, but hopefully in the next year or so I will!
Here it´s very hard to find a 00-03 Yukon XL or Suburban. And the few that have been imported are redicoulusly expensive. So i might as well do all the work by myself (instead of letting a dealer make a fortune on me.)
My question is: I need help to find a searchengine where i can search for cars on the eastcoast in the US. I´ve been looking a bit at www.autotrader.com but i would appriaciate if any of you guys could recommend another one.
I have a contact in New Jersey that will take care of the shipping and so on, therefor i would like to find one in that aera.
The car i´m looking for is a Yukon XL Denali, say 2002-2004. Or should i go for just a Yukon XL or Suburban? What is really the differens exept for the exteriör?
Peter, stockholm
The interior on the Denali is FAR better than standard Yukon.
But, it is my intention to keep this for a good 5-7 years and the extra money has been "well spent".
It is going to cost a lot of money to ship it to Sweden ??
Web sites...new???
www.gmbuypower.com
Set the dash-mounted switch to AUTO and the system takes over, automatically and instantaneously adjusting the front-to-rear torque according to the changing traction. So you get optimal 2WD fuel economy when the going's easy, and optimal 4WD traction when it's not. The AUTO-mode torque control is also linked to the all-terrain ABS, enhancing braking effectiveness and vehicle stability when ABS is applied.
Having said all this we were less than impressed with AUTO-mode and ended up manually switching the system to fulltime 4X4 for our drive through the ice and snow of West Virginia.
We just don't want to end up with a truck that isn't able to handle snow and ice conditions as well as a 4X4.
Any feedback will be greatly appreciated!
You also may want to try:
www.cars.com
www.gmc.com
Cars.com has options to search for both new and used cars (the majority of the used vehicles listed are actually at dealerships).
GMC.com will allow you to build the vehicle you want. Then you can press a button to have the web page for a dealership that has a vehicle similar to the one you built.
If you need zip codes associated with East coast cities in order to perform your search you can locate them at www.usps.com
Good luck!
Options: 2nd row captains' chairs (AL4), sunroof (CF5), multimedia sound system w/navigation system (UM8).
The factory nav system (included in the multimedia sound system UM8) is a MUST have, in my opinion. It is excellent. I had the factory nav system in the ML430 too. This is an option that I couldn't live without, and I waited until I could get it before placing my GMC order in January (it wasn't available until that time). I never had Onstar before, but I consider it to be a completely different safety and emergency system -- an adjunct to the on-board nav system.
The truck was built and delivered in about 7 weeks. Nobody at the dealership had ever seen the nav system before!
Price, including options and destination charge, was $48,675 (before $2,500 rebate). After rebate, price was $46,175. This seems to be about $124 less than the invoice less dealer holdback (3% of MSRP before dest. chg.). I shopped a number of dealers before finding this price.
So far, the truck seems fine, although there are some annoying noises in the instrument panel. Also, the accelerator pedal seems a bit flaccid (should have more resistance like the ML430). The 6 liter engine seems fine.
If anyone has had any recent problems with their 2003 Yukon XL's, I'd appreciate knowing.
I want to replace the red "GMC" grill emblem with a chrome one. I know they're out there because I've seen them on other trucks. Anyone know where to get it and also how to take the old one off? Thanks in advance.
B.D.
What is your thoughts?
