Toyota Echo Transmission
pa_rookies
Member Posts: 2
in Toyota
Need a way forward,
I have a 2000 Toyota Echo with 80,000 miles and the dealership has just informed me that i will need a NEW transmission. At the 68,000 mile mark I noticed that the transmission slipped out of gear and going from stop to start it appeared to jump into gear. This is an automatic transmission and i was surprised to think that this was the problem. I cleaned the MAF sensor and everything seemed fine until the 80,000 mark where the problem is almost constant. I replaced the MAF from Auto Zone but the problem continues. The dealership reccomended a transmission flush to possibly narrow down the problem but this failed to get results. The transmission fluid was also replaced at 35,000 by Toyota. I am puzzeled by the MAF that appears to change how the transmission shifts, When I took into the dealership I could not get it into D and only had the lower 2 gears. I pulled over, unplugged and plugged the MAF back in and went the next 5 miles to the dealership witht the trans running perfect. When i discussed this with the mechanic he said the MAF has nothing to do with the transmission. I'm puzzeled by this and can't believe that i need a new trans at 80,000 and would welcome feed back or suggestions that may save me big bucks!
Dave
Dave
Do you feel the MAF sensor could cause this condition?
Thanks very much for the reply.
Could this be transmission. Car has 78,000 miles. I am the only owner. :shades:
I have 2000 Echo with 100k miles.
At around 60k miles, I had exact same problem.
It is not a transmission problem.
Replace MAF filter!
I've had trouble w/that before and cleaning it did the trick, Where is the MAF filter ?
My tranny jumped into neutral in a rainstorm, but the shifter was in drive !!, coasted to the side and a minute later it was OK..At 65000, guess I need the fluid changed ...
Thanks in advance.
My son just bought a 2000 ECHO with a 5 sp tranny and 255k kilometers or 160k miles. It's in really good shape actually and we LOVE driving it around.
When idling there is a chirping noise coming from the driver's side of the engine. When slight pressure is applied on the clutch pedal it disappears and then reappears when the pedal is released.
A Google search has someone saying if the chirping disappears when the clutch is depressed it is the input shaft bearing... if it only chirps when the clutch is depressed and quits when it is released , then it is the throw-out bearing.
I think is must be the reverse... if the chirping goes away when the clutch is depressed that is a noisy throw-out bearing (not a big deal).
First... has anyone else had this chirping noise?
If so... should we be concerned?
Re: "take it easy" I think he realizes that this car is in it's senior years... but being a new driver, he might not have the sense of what is hard on a vehicle. I'm that one that will rev it out while accelerating... it's fun to drive... but smooth shifting is not likely to hurt it.
Thx for the feedback. Anyone else have chirping????
I thought that given the reputation of the transmissions, that I would occasionally flush the transmissions... thinking if I change oil every 5000 - 10000 km then changing the tranny fluid every 80K or 100K would certainly be reasonable.
The outcome... I had 270,000 Km on the van when I slipped off an icy road last year (they wrote it off because the airbag went off) AND I am still communting daily with the Sable wagon and it's pushing 300,000 Km. I have had NO tranny problems except for cracked line to the radiator that was easily replaced.
IMHO... I'd say that the flush is WELL WORTH IT! :shades:
On an automatic, it's nice to do once in a long while as it gets all the fluid out and exchanges it, which regular drain-n-fills don't do. But also be aware that it is a MASSIVE profit item for mechanics.
Oh... the other thing that I do is about every 25 000 I add a slippery/slidey "conditioner" that cleans and lubricated the valves and pumps. I sometimes got a clunk when shifting... and this always smoothed things out. Again... only about $8 and likely worth it.
So... shop around for pricing and ask them exactly what they do... if it is just drain and fill... it doesn't change ALL the fluid. Ask around... /denis
-gary
driving with a scan tool hooked up may give some insight.
chirping is the the relaease breaing or its linkage.
look at it as insurance against the trany failing
if wait a long time, you will need to flush the transmission.
drian and fill is ok if it is done reguarly on a toyota.
Also my clutch seems to be losing pressure.(feels very lite)any ideas?
It seems to shift okay but a little jerky sometimes.
I just bought the car 5 day's ago and put over 1000 km's on it.Bought it with 145,000 k's
90,000 miles or so.never been in a clamied accident.I am quite worried with the problems,because this is a super reliable brand.Yes the car is 10 years old and counting.
Any input would be great.Or just chime in on your ECHO problems or experinces.
I ran over a curb doing 30 miles an hour, was more of a concrete island dividing two lanes at an intersection.I was lucky to miss a metal light pole by just 3 feet.The little echo took all the force of the accident with the steel wheel and tire.There was a big bubble on the tire after.I thought for sure i killed the underneath of the car ,but all was needed was a used tire,and banging the steel wheel back to shape.And a balance and i was on my way.Tough little cars for sure.High ground clearance.
Well thanks Bryan in London Ontario Canada
"Weakness" is just the hydralic operateing system. ECHO has a light clutch pedal pressure. As long as the clutch doesnt slip while accelerating its fine.
Sounds like the clutch is tweaked but serviceable.
Personally I can drive a new car with a clutch 200,000 miles without replacement (or more) I have NEVER needed to replace a clutch.
So if the car was mine I would just drive it hoping the dammage will stop and not get worse.
But in the meantime look for a shop and get estimates. I dont know what they get for a clutch job but the ECHO is failry complicated to get the trans in and out Im thinking.
Good luck and tell us what happens!
Also post something at least once a week to liven thingsup around here! I love to gab.
It's just, the clutch seemed tighter when I first got the car.Maybe low on fluid.I just hate not having a trustworthy mechanic.
Thanks for the input kneisl1.The car is great on gas even know it's getting below freezing out.
I really did'nt want a 5-speed at first,I've had a couple in the past for only short periods of time.The gas savings is worth rowing through the gears in the city.
do you have an
echo?
The ECHO is the better car in my opinion.
I bought a 2000 ECHO with automatic for my son five or six years ago for $3000 with 117k miles on it. It has over 180k miles on it now with no problems except for a new MAF sensor.
Today, when I shifted into 1st gear, the car moved very slowly even when I applied gas. Did the same in reverse. I decided to try something and put the car in first and took my foot off the clutch without gas and the car did not stall. Does anyone know what this could be? I am about to sell my car as is, and want to ensure I can let any buyer know about what problems I have experienced. The car is a 2001 and has 233,000. I just flushed the transmission fluid last winter and regularly change the oil.
Cheers
Kathy
If the transmission was bad it would not go into gear, or it would pop out of gear (any gear) while driving.
If you are driving along in, say, 3rd gear and accelerate briskly and the engine revs but the car doesnt move any faster, the clutch is "slipping" and needs replacement.
Good Luck!
PS My advice is take the ECHO to a shop and have them fix the clutch (~$1000) and KEEP IT! : )
You must be doing something wrong.
Second thing have it changed by a shop that hooks up a continous feed to the trans so ALL the oil is changed. I believe the trans takes special Toyota semi synthetic oil...
Third...my guess is the trans is shot. Get a used one from a junkyard and have it installed.
