Dodge Ram Towing Questions
I very recently purchased a 2006 3500 dually Mega Cab and I'm very happy with the truck so far. I've driven Chevy's for over 20 years, but with all things being considered, the Dodge won the contest in my mind with the inovation of the Mega Cab.
My question is I'm having difficulty finding the weight capacity while ingaged in 5th wheel towing. The Dodge web site indicated the weight being 13,550 lbs. ( with my 3.73 ) gear ratio. Checking out the Gm and Ford web sites, their stats show that the capacity increases while towing with a 5th wheel over conventional towing.
I spoke with someone from customer service with Dodge and they replied that 5th wheel towing doesn't add any benifit to weight capacities.
I dissagree with that due to the fact that the weight of the trailer is distributed a greater percentage over the truck with the front suspension sharing some weight.
So......, any thoughts on the subject? I'm now in the market of a very large 5th wheel travel trailer, and I hate to have to needlessly cut back on my selection due to a too consevative estimate of 5th wheel towing capacities from the manufacter. Thanks for help and opinions !!!
kcram - Pickups Host
Dusty
Is that 14-16 mpg empty or towing with the Dodge Ram 2500? I read somewhere that the older 12 valve Cummins diesels actually got better gas milage than the newer 24 valve ones, but I am not sure what year they changed over to the 24 and wouldn't want to get too old of one used (plus buying used is more of a gamble, so I do lean toward new unless there's a particular prior year that shines).
In the 07 models, I was looking at the 2500 SLT Quad cab with either of the Cummins engines. Which Cummins engine did you get--the 5.9L HO or the 6.7L? Do you know if there a difference in quality and/or fuel efficiency between the two?
I have heard that a long bed increases stability, but would I notice it towing a 5000 lb TT?
Did you go with 2 x 4 or 4 x 4? I am going on dirt roads with washboards and some sand (i.e Southern Utah backroads), but am concerned about losing even more fuel economy with a 4 x 4 (although if I were getting a Tacoma, I would go with the 4WD because it probably would really help a smaller truck to have that extra traction to tow a 5K lb. load on rougher dirt roads) But is a 4 x 4 is really necessary in this big a truck?
Aside from the tow package, are there specific options that you would recommend for travel trailer towing?
Thanks for any/all additional input you can provide! It's really a stretch for me to imagine owning a diesel, but there is a first time for everything.
I wondered about a one-ton diesel myself. They're not cheap. But if you are going to tow any significant amount, I personally wouldn't go gasoline engines now that I've done both. I have also been told here and from owners that my "real" gas mileage won't occur for 30,000 miles or so on this engine. It takes CID engines a good while to fully break in. If I had it to do all over again, I'd do the same thing. The 2500 would probably be sufficient, but I didn't want any more capacity issues, so I went one-ton. If you have the means, I highly recommend picking one up. If you can find a 5 star dealer, I would recommend that too. Some of the others just want to make a quick sale. Thanks...T29
I think I have been doing myself a disservice reading some of the Dodge forums, because of course they are discussing problems, not how reliable these trucks are. But when I talk with people out and about, I hear time and again that you can't go wrong with the Dodge Ram Cummins TCD.
I will definitely heed your advice and go with a reputable 5 star dealer, because some of the Dodge dealers I have read about in the forums sound terrible. Support and service are vital, especially for a newbie like me.
I am psyched to get the Dodge Ram and TT and get out into the world in a whole new way! Thanks again and Happy Trails!
I do not know what truck I need to buy. I have seen pictures of people hauling this type of trailers using a Ram 3500, F 350 and Sierra 3500.
I would appreciate any advise. Thnxs.
Anyway, I went to hook it up and I could not find the plug under the dash. After a friend told me where it was it was still hard to find as when they assembled the truck it was tucked in behind the electronic module. The module has a bunch of wires coming into/out of it up under the drivers dash between the side wall and the steering column. If you can't see it, reach behind for a loose connector and pull it out in front. Again, You may not have it if you did not purchase the manufacturer's towing package.
Good luck. If you still can't find it I can get a picture to you if you ping me offline at gsireove@rogers.com.
Gary
2008 RAM 3500
SLT, 4x4, Quad Cab, 8 Ft, 6.7-Liter Cummins® Turbo Diesel Engine, 6-Speed Automatic 68RFE Transmission
With 4.10 Axle Ratio You Can Tow 16700 lbs
Gross Vehicle Weight Rating(GVWR)[i]=10100
Payload[i]=2965
Curb Weight[i]=7135
Curb WeightFront/Rear=4412/2723
GAWR[i]Front/Rear=5200/6200
Gross Combination Weight Rating(GCWR)[i]=24000
also the GAWR of the front and rear axle don't add up to the GVWR">
I guess Dodge has messed it up! this is not the first time. they still have 2006 pics on the towing guide
Thanks for your help
The 2008 has a higher rating because of the more powerful engine (350/650), but it still would not be enough to drag a 19K loaded trailer. If you have an early 2004 with the 305/555 engine, you have even less to work with.
bc
I have a flat 4 prong trailer connector. Did not get the towing pkg. with the truck did all trucks come with the brake controller connector? I have a 2004 dodge 1500 quad cab.
My question is along the same lines of others I have seen but cannot really figure out. First, it looks like I have about 2K of people and stuff I can add before being overweight. Is that right? Secondly, is the rating listed for off the back towing and the real capacity with fiver towing is higher? Like in the previous post the GM and Ford websites show diffferent ratings for each.
Thanks for any input!!!
Second question... That 14,650 is for fifth-wheels. By law, you can not tow more than 10,000 pounds from a rear hitch, regardless of the truck's rated capacity.
kcram - Pickups/Wagons Host
i have a 2001 ram 1500 2wd quad cab short box with towing package. i also have a travel trailer that has a weight of about 5000 lbs. i have pulled this trailer a few times with no problem but i was hoping to get some feedback to know if im killing my truck or not. everything that ive read says that i can pull up to 7550 lbs. i dont know if i worry too much or im just severely anal. also does anyone know what the proper operating temp for my trans ?
thanks for any advice you might have
I have a 2008 Ram 1500 quad cab 4x4 with the Hemi, the factory trailer tow package and I think it has the auxillary transmission cooler on it. The trailer is 6600lbs dry weight and has a 3k lb load limit. I highly doubt I would put that much weight on it but IF by chance I did, would this truck handle that weight or would I need air bags?
Air bags are not the issue... it's your total weight that can get you into legal issues if an officer thinks you're too heavy and sends you to a scale.
I am towing a 6200 pound trailer with no problems until I reach 50 mph, then the temp. gauge starts climbing. It will go about 2/3 of the way to the red zone and stops, if I drop to 45 mph the gauge returns to normal.
I am not loosing any fluids, and there is no cross contanmination of fluids.
Does any one have an idea of the cause of this over heating?
I have a 2008 Dodge Megacab with the short box. When I bought the truck, all the paperwork list the truck as a 1500, but the Dealership told me that the Megacabs were only built on a solid axle 2500 chassis. Is this true? I do have solid axles and I'm trying to determine my towing capacity?
