Chevrolet Camaro Security Systems
When I try to start my car, about once every 7 starts it doesn't start. It simply turns on the security light, and I have to wait three minutes for it to start. The owners manual just said that there may be dirt on the chip, but I even got a new key and that did not fix the problem. Can anyone help me please!
Russ
there are only 15 different resistors. if you take a multi-meter and put it on the resistor it will give you a value like 1.103. theres a list of the 15 values. 1.103 for instance is key or resistor #4. if the key ignition does not see the resistor for any reason it cuts off the starter & fuel pump relay. if you have another key try that one. someone on ebay sells a by-pass kit for gm's vats system
