Chevy Venture Squeaks, Rattles and other Noises
When driving my Venture, when the wheels begin to move, a whirring noise is then heard. It seems to get faster and louder as speed increases. It ends when stopped. When I coast, the noise is still there. I had it in a shop today and he doesn't really know. It's definitely not the wheel bearings. However, he thinks it may be the pinion bearing. Any ideas and costs???
BTW - a wheel bearing failure at 76000 miles is not an uncommon event although fortunately its not something that happens to everyone. Personally, I've replaced wheel bearings at much less and much more miles than that...it happens. If you have some mechanical ability and a torque wrench its a job that's certainly doable by a "do-it-yourselfer"
Not sure of the cost for the Venture - did some quick checking and the part from autozone is about $ 150 so from the dealer its probably 250-350 plus labor. I'm guessing the dealer will get about $ 500 for it, but its only a guess. If you're not in warranty, I'm sure you'll do better with your local mechanic.
As for tools in case you want to try to tackle it yourself, you only need a socket for the hub nut (32mm I think) and a breaker bar,
socket to take the hub off (15mm?), a swivel to get to the hub mounting bolts and a hub puller. (and of course, a torque wrench) Autozone will lend you some tools for free if you buy the part there, not sure about other places. You might want to check with them if you're so inclined. Best of luck - let us know how it turned out...
John
Well I chickened out and didn't do the work myself (not enough time, but it sounds like could have saved some $$$). I took it the local dealer and they diagnosed the problem and as suspected, the right wheel bearing was kaput. Parts and labor came to 511.00. You were right on the mark. I had an extended warranty, but it ran out about 4000 miles ago. I asked to see if they would at least cover some portion of the cost since it was close ( I consider 4000 miles close) to the warranty mileage, but they balked. Too bad...I had a similar incident with a Mercury Villager van and the tranny died 3500 miles out of the basic warranty. I petitioned the local dealer to fix it under warranty and they obliged to the tune of over $800. Too bad Chevrolet/GM wouldn't do the same for their customers. But all said and done, I needed to have it there anyway as the horn had quit working about 6 months ago. Seems that was the horn relay was shot, the relay was shorted out and stuck open. Bummer on that deal was the part was less than $20 but the labor was over $90 to install. They get you coming and going...
Thanks for the help and info. I hope this helps someone else...
Bill
Glad I could help you...
John
Loud knocking when first starting that softens after running for awhile but is still there. Has 97xxx miles and has had the oil changed religously. Absolutely no other problems, no lights, no anything. Any help appreciated.
I'm not very familiar with the AWD setup in the Venture as mine doesn't have it but its curious to me that you mention that the clunk sounds like its midway under the chassis. I believe that there is a hanger bearing underneath which supports the shaft going to the rear wheels and the bushing on it has been known to fail with some clunking noises. Maybe that's your problem?? Sorry, just a guess, not too familiar with the setup...You should be able to visually check it from underneath and see if it looks like anything is overly worn...
On the "hanger bearing" noise...I'm searching for a noise that seems like it's coming from the right wheel well, but I've had all the struts, tie rods, etc replaced. Is this hanger bearing near the front of the car...(it sounds like it's further back).
I typically hear it regularly, like an extra clunk when going at 40 mph...especially noticeable if any aberrations in the road. It feels like it's from a rotating part that is out of round. Any help appreciated.
Can't say for sure what your noise is...sorry
So, after about a year I still can't figure what this noise is.
Had a flat tire on the right front while on interstate about a week ago.
Put on donut tire and everything seemed fine.
Then, later in the day sounded like a tire rub was happening after reaching about 20mph.
I had the blown tire fixed and put back on thinking the sound was the donut tire.
Sound is still there, but not as loud.
Sounds like a tire rub, but no tire rubbing evident.
Worse when turning to right and less when turning to left.
Things checked -
- wheel bearing - no excessive play
- CV boot - in tact with no tears - no knocking noise when turning presently
- tie rods look as normal as they always have been
- wheel well molding in place and not damaged in any way
I've also driven my spare care next to the van at highway speed and you can't hear the noise when driving next to it. Sounds like it is coming from the directly underneath the front passenger area.
Any assistance or advice welcomed!!
