Next thing I'm planning to do is to remove the ignition module and coil assembly to see if a local auto part store can put on a bench tester.
Does anyone have a similar problem and a solution?
If its not mechanical. Chances are the problem is the info from one of many sensors that your ECM is reading.
if you don't like to visit a mechanic every time a lite comes on what you need to get is a codereader/Scanner for your year & make of your vehicle. a scanner will give you more details then just a codereader. I just changed my MAP sensor and that was the problem.
the most common problem is the O2 sensor. hope this helps.
Z34Luver
Lawman
BTW, no tools needed. :shades:
I have a 1995 lumina sedan. when I try to accelerate it seems to hesitate unless I depress the accelerator all the way down and downshifting.when at highway speed i depress the pedal and either nothing happens of it responds very slowly.again downshifting seems to help.
Any suggestions and help????? thanks Larry
when it goes out the fluid leaks out .
it acts like that when its out of fluid . plus it lets air in which messes stuff up
seal kit costs 9.99 just did mine last weekend
when the seal gets really bad the fluid leaks out really fast.
now and then. It has gradually got worse. There is no check engine light. Any ideas
The problem is my 17 year old son cut the corner too sharp and damaged the right rear rim on the curb. Had to replace the rim. Tire was mounted and balanced on another rim.
However now there's a constant thump whenever I accelerate above 15 mph. At speed it almost sounds as if there's a helicopter hovering over the right rear of the car. The noise was not there prior to breaking the rim.
I'm thinking the wheel bearings may be damaged, but I open for suggestions. Anyone have any ideas on what the problem might be?
I would probably put on the doughnut spare and go for a test drive. If the problem persists, you know for sure its not related to the tire/rim.
Sorry, wish I could help.
Power steering
- Will work on and off
Won't start after X number of starts
- All electronics will start and turn on, engine won't do anything
Whenever it does decide to start
- Clicking noise that eventually goes away
Acceleration
- It will hesitate on acceleration, flooring it will make it go but nothing other than that
Lo siento, pero nosotros hablamos ingles exclusivamente aqui en estos foros. Se necesita buscar un sitio hispanohablante para la problema de su Lumina.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
