Ford Escape Hybrid Brake Problems
12346»
  • I had the same thing with my 2006 FEH. Now they are telling me it will be a $5000 fix! at 75k miles with no other brake problems. Unfortunately, no bubble for me. :-( I am without a vehicle because I can't afford the $5k.
  • Willie,
    I'm getting the same thing, but mine is intermittent which, to me, indicates a computer glitch. Everything works perfectly somethimes. For me it was a $5000 quote!
    I've talked to several local mechanics who spit out their coffee or choke when I tell them the repair bill! They say they can't touch the FORD ABS system. (something about needing a VERY expensive programmer to match the computer to the car ID?)
    I think I've scared off at least a dozen people from buying a Ford with the story of my brake bill. I'm going to tell it to everyone I know and then some. It doesn't look like there will be a happy ending since I have contacted FORD customer complaints and they said basically:
    Yeah, you have a right to be mad about that bill, but you are on your own, we aren't going to help you out one bit.
    What do they think they are, therapists? I have a right to be mad? No kidding sherlock! The vehicle is only 5 years old and I have a repair bill that makes my vehicle worthless unless I pay them the $5000 repair bill so I can sell it for only a couple thousand more if I'm lucky?!?
    No Way, I'll junk it instead! Or, park it on my lot on the side of the main road with a big sign on it saying "for sale...needs a $5000 brake job according to ford!"
    If you get a junk yard to take yours, let me know how much you get in maine, I'll do the same here.
    I'm taking it to a different ford dealer for a second oppinion tomorrow. Wish me luck.
  • Good news (for me anyway)! I took it to another dealer in Waterville, ME (Ray Haskell Ford) and they were able to fix it without the expensive parts. I did not tell them about the first dealer experience, only about the first shop that could not bleed the brakes.
    The receipt says:
    "40 ECC tested 3 codes bled brakes and reprogrammed ABS, did pinpoint test - road tested OK"
    so $176 instead of potential $7K.
    Lesson: if this happens to you don't accept that the master cylinder and HCU are bad. Get other opinions. Make them go back at it.
    Hopefully the fix will last me!
    It seems like this regenerative brake thing is just too dang complex and reliant on computers. It is a scary feeling to know that you are at the mercy of Ford dealers for this rather than local mechanics.
    thanks,
    Will
    There is more on this and shop manuals here: http://www.escape-city.com/viewtopic.php?f=38&t=11675
  • degu1degu1 Posts: 2
    I had the same thing happen with my 2006 Hybrid Escape brakes. I went to the manager of the dealership and asked him to intervene with Ford customer service...not much help, but fortunately for me I the manager of the service dept. said he would bleed brakes and see if this would "fix" the problem as the pads etc all looked good on the auto. Basically did the same as your tech, for under $200.00 and the ABS light hasn't come on since. This was back in Jan.2011.
  • dsteakdsteak Posts: 18
    Yup. I've had this problem since 1.5 years (18K miles). While my car was still under warranty, they kept changing the ground saying that was the fix. I had it in 10 times. After my car was out of warranty, the fix was then a new computer module ($4,500). Even my dealer was on my side, saying that the fix should have been the computer module from the start, which was what other people were getting, which is what I asked in the beginning, "isn't that the fix, a new computer module?". Ford told my dealer to help me but Ford themselves wouldn't be providing any assistance whatsoever. My dealer told me they would provide the fix at cost ($3500). So apparently Ford makes $1000+ on this repair. Nice for them huh? There is a facebook page about this to LIKE - link title
    Ford didn't want a recall or any negative publicity about their hybrids (the Mercury has the same issue) since times were tough in the auto industry. You can read the history of my posts on this site, but it provides no consolation. I tell everyone Ford hybrids are no good, but gee they made billions last year. This is my last Ford. How about a little class action?
  • I have also had brake failure on a 2009 Ford Escape Hybrid. Two weeks ago, at 50,000 miles and just back from the dealer's service, the brakes failed at start-up: very little braking action and a warning on the dash. I drove it around the block and went through four stop signs. I had it towed back to the dealer, where it has been ever since. The technician there found a code for "over-extended brake pedal" -- naturally the result when the brakes fail and the pedal goes to the floor. The service manager says they cannot duplicate the failure despite frequent attempts, and that Ford will not authorize repair unless they can see the failure for themselves. The "Customer Service" Manager at Ford headquarters, implies that Ford's engineers are unaware of this kind of problem and have no explanation for it -- a position that is belied by the many posts at this site. The dealer's technician was more honest: he said "We can't replace the system without Ford's approval, and they won't approve that because of the high-dollar parts." But I have a high-dollar life.
    I agree with those who say that a class-action suit is appropriate. Better now than after someone is killed.
    In the meantime, I am taking my case to the Bureau of Automotive Repair of the California Department of Consumer Affairs.
  • Brakes working fine on my 2005. Curious if you can operate the vehicle without any hybrid battery life. Can you disable the hybrid so as to not replace batteries when they finally go?
  • stevedebistevedebi LAPosts: 3,994
    "Brakes working fine on my 2005. Curious if you can operate the vehicle without any hybrid battery life. Can you disable the hybrid so as to not replace batteries when they finally go? "
    No. The battery has to be working for the vehicle to move.
  • wwestwwest Posts: 10,706
    First, "my shop"....
    Second....Siezed/stuck brake caliper piston at 187,000 should be considered a normal failure.
    The calipers should have been inspected/replaced/rebuilt at that initial brake service.
    Lastly..."your shop" began a brake fluid proceedure without knowing, or knowing how, to completely bleed a system as complex as is the FEH.
  • Did you not read that one Ford dealer wanted $1500 for master cylinder to tell me that I then might need a $4000 HCU? And that another Ford dealer figured it out for $176?
    I think our point here is to learn about this problem and how to deal with it without getting in an accident or getting ripped off.
    What is your point?
  • I also have a failed ABS system...just had the ground wire and battery replaced and a day later got the service brake message. Searching Google I found a couple used for sale for around $200. The description says:
    ABS Control Module/Pump
    Assm; Hybrid, 4WD
    Fits: 2006 Ford Escape
    assembly; Hybrid, 4WD
    I checked Motorcraft website that shows the price at $3125. The dealer quoted 3,700 plus 400 to install.
    Can a used one work?
    What prices are you being quoted for the part?
    I plan on selling this car within the month. Dont really want to put a lot more into this POS.
    thanks!
    Sequence of events does not lead me to the belief that something has HARD failed.
    Look to "what changed"....
    i would also be interested in replacing this with a used one and selling the car. i have had this same problem for 5 years now.
  • I saw a post somewhere where someone had bought a used one, had their mechanic install it and when they took it to the Dealer to get the lines bleed (you need special equipment) they said they couldn't program it. Might be pretty risky to go used.
  • thowleythowley Posts: 1
    2nd year in a row our brakes have failed in our 2010 Hybrid. Brakes failing on a vehicle 1 time is 1 too many. Our teenager drives this car and I can't imagine this new driver being in the car when this has happened. I will not stop until this known problem is fixed. I cannot believe no one has been hurt yet in this vehicle or that Ford is willing to risk this.
    I have started the escalation process.
  • FEH 09, 44K miles. Wife driving, red brake light, chimes and check brake system comes on, brake petal to the floor, gets the FEH to stop. Luckily she is going slow in an isolated area. Calls me, I start it up, no alert or alarms. Drive slowly and carefully the 6 miles to Ford dealer, no issues on the drive. Has a code about the brake pressure sensor. Tech finds the wiring run to the connection is very tight and the connector is not fully engaged. Reroutes wiring run to get some slack, tightens everything up, code is gone, drives fine. Based on some other estimates in this forum for repair parts, the $100 fix for this problem, instead of $4K computer, was a lot easier to pay. Glad something was found.
  • I've got a 2009 Escape Hybrid with 76K miles on it. I've experienced braking problems when traveling down very steep grades (i.e. Mt. Whitney portal to valley, etc..., 10+% downgrades). Specifically, the vehicle shakes severely and the regenerative power/battery meter doesn't indicate that it's being regenerated, as it normally does when the brakes are applied. This happened the summer of 2011, than again this past summer, each time only once, while traveling down severe grades. I had the transmission in low to help keep my speed down to minimize the braking. The shaking would typically occur while braking at 40-50 mph +/-. This has not happened in any other situations, and the brakes appear to be working well at all other times. Any thoughts?
    "....transmission in "low"...."
    "B" mode also?
    "I've got a 2009 Escape Hybrid with 76K miles on it. I've experienced braking problems when traveling down very steep grades (i.e. Mt. Whitney portal to valley, etc..., 10+% downgrades). Specifically, the vehicle shakes severely and the regenerative power/battery meter doesn't indicate that it's being regenerated, as it normally does when the brakes are applied. This happened the summer of 2011, than again this past summer, each time only once, while traveling down severe grades. I had the transmission in low to help keep my speed down to minimize the braking. The shaking would typically occur while braking at 40-50 mph +/-. This has not happened in any other situations, and the brakes appear to be working well at all other times. Any thoughts? "
    I don't know about "severe" shaking, but if you are in "L" going down hill, the battery will max out at about 66% SOC. After that point, the FEH will use the engine to brake, which can be pretty loud. Next time, shift back to "D" and see if the shaking goes away. But on my 2008, the only thing that happens is I hear the engine. If there is shaking, something may be wrong under the hood.
    Might be the EBD, Electronic Braking Distrbution. The system tries to "balance" braking front vs rear. I most notice it activating on a slight downhill with wet roadbed, feels like cross multiple railroad tracks.
    edited October 2012
    "Might be the EBD, Electronic Braking Distrbution. The system tries to "balance" braking front vs rear. I most notice it activating on a slight downhill with wet roadbed, feels like cross multiple railroad tracks. "
    Really? Since you never owned an FEH, how do you know what Ford EBD feels like?
    As an owner, I can say that I have never had any such feeling from my 2008 FEH.
    I normally make sure to ignore wwest when he trolls other forums for vehicles he has never owned. But I had to clear up misinformation.
    "..how do you know what Ford EBD feels like?..."
    Never said I did, "might be" is in no way a definitive team.
    And why would you assume, suppose, that Ford's implementation of EBD would differ significantly than others?
    On the other hand since the FEH must "contend" with three separate braking modes (front ONLY [regen], combined [regen front, frictional front/rear], and frictional only) I would suspect that activation of EBD might even more pronounced, noticeable vs my RX300.
    Like I said, I don't answer trolls.
    Good-O....
  • wilcoxwilcox Posts: 581
    Found something unusual...beats all I've ever personally seen car wise :confuse:
    Yesterday, I jacked up our 2007 Merc Mariner 4X4 HYBRID SUV in the garage and inspected the underneath and removed all 4 wheels and inspected disc brakes on all four axles.
    We began operating this vehicle in October of 2006. It now has reached 90,000 miles on odometer. All the original disc brake pads linings are in good shape and I'll wager that there is still a good 25K - 30K miles left in them. The rotors look fine IMO...not brand new looking...but not badly grooved or pitted, warpo'ed, etc.
    Nothing else was out of order... :)
    This is my 2nd brake inspection on the vehicle. 1st one was at 65K miles.
  • Curious to know what happened up happening here? My mom is having the same problem with hers.. The brakes randomly fail and dealer doesn't know what the real problem is so is suggesting repairs that "may" solve the problem.
  • So I bought my 2006 FEH used this spring. As soon as I got it I noticed that it 'talked' to me when I got near it - sometimes when I opened the door. A quiet rapid clicking noise. It didn't seem a big enough issue to bring up to my mechanic so I just got used to it.
    Recently the check brakes and check 4x4 lights both came on and it had a shudder on some slow turns and occasional shudder when I braked. I took it to my local mechanic.
    They said it needed a tone ring - no biggie. When they had it apart, they called to say it needed disks and tie rods. OK.
    But, once they put it back together, no brakes.
    Now they say that the ABS Brake pump was what was making the mysterious noise (they heard it too) and that it must have been running too often and now it has died. Along with the sensor/module thingy that's mounted on it.
    They say I need a new one, maybe I should look for a used one and they're afraid to mess with it so I should probably get it towed to a dealer. Oh, and the part is going to cost about $3,500. More than 1/2 the amount that I paid for the car.
    Can the pump coincidentally have died just when they messed with the system? Could they maybe not have put something back together correctly? Can it be tested? Can I find a used one? Any suggestions?
    THANKS!! I don't know if its worth it to buy a new pump but if someone can come up with a $100 fix, it's surely worth it!!
    It may not be relevant , but it was owned by a park system shortly before I bought it - there's evidence of a roof mounted light, a radio in the dash and other electrical systems askew (some dangling unattached under the hood.)
12346»
Ford Escape Hybrid Brake Problems - Page 6 - Car Forums at Edmunds.com
