From one newbie to another, welcome to Edmunds!
You said: I've read all 900 posts and learned a lot about my Denali
I say: I am impressed!
tidester
SUVs
http://www.stylinconcepts.com/parts.cfm/partfamilyid/175/categoryid/11/subcategoryid/54
I have upgraded my stock bulbs with the 50W halogen replacements, and they work great, and I didn't have to splice into anything. If it was me, I would splice into the trailer wiring. It is already outside the truck so you don't have to run wires through any boots, or drill holes to get the wire down to the outside. If memory serves the center pin on the big plug is for backup lights, if you look at the plug's flip up cover it has a pin diagram telling you what pin's do what. All you would have to do then is strip off the insulation of the correct wire wrap the positive wire from the add on lights around the bare wire, solder it, and put some liquid electrical tape on it to seal it back up. I prefer liquid electrical tape to regular tape because no matter how much electrical tape you use it never seals it all back up, the liquid electrical tape acts like the original insulation and seals much better.
I would also like to add a welcome to both 2kdenali and our new host tidester.
Re: Emblem: Post 509 said the emblem is available from www.trucknvan.com for $60.00 + $4.75 shipping. Post 536 had 2 links to a photo of the emblem on his truck, but both those links are dead. I'd really like to "see it in action" before spending the $.
Re: Back Up Lights: Funny you should mention the trailer wiring, because I thought of that yesterday afternoon. Splicing into the regular back up lights bulb wire is no problem. There's plenty of room inside the fixture for the relay, which should be protected from the elements. This connection (I'm told) acts as the "switch" to flip the relay and turn on the lights, which are powered by the direct 12v connection. My idea for the trailer wiring was to splice into 12v power, thereby eliminating the need to run the wire all the way to the battery/fuse panel. In either case, you need both connections. Any idea if any of the trailer wires could be used for the direct 12v connection?
I'll absolutely look into the liquid electrical tape stuff. Sounds like a great product.
Rich
2k2denali
PS - It appears that the protocol for the title/subject field is to insert the user name of whom you're answering. Too bad this board does not thread messages, which keeps it all organised. Then again, having all the posts numbered makes it easy to keep track of information.
Like I said I got the 50W halogen replacement bulbs that fit the the stock plug and housing. They work great, 100% improvement over the stock bulbs. I don't know if they will shorten the life of the plug from the added heat, but they are not on like running lights, or brake lights.
I have also installed the GMC molded plastic mud flaps from the dealer. They installed with three screws which go easily into the molded plastic running boards inside the wheel well. Has definitely been worth the effort since the rear corner panel and front end of the running boards stay much cleaner.
Also installed an aftermarket sunroof (ASC) which I have been very pleased with. Provides one-touch features not available from the factory and allows you to retain the rear climate control not available when you order the factory sunroof. I had it installed through the dealer.
That's all for my upgrades right now although I intend to replace the center and rear ceiling lights with the switched ones from the Tahoe. Also plan to get the Catch-alls. Can anyone provide the site where they got the best price and the product code for the mats for a "neutral" interior on a DXL?
How about a part number for the mudflaps?
The door unlock relay automatically unlocks all doors when the vehicle is put in park. Right now your doors do not unlock until you have turned off the ignition. Once you have installed this relay you could never go back. Simple convenience but really makes a difference.
I don't have a part number for the mud flaps, however I picked them up at the local GMC dealer. I think they were around $15-18 a pair.
heatwave3 - Door unlock relay
Perhaps things were changed on the 2002 Denali. My door locks unlock when put into park (and lock when taken out of PARK.)
I read on the Delphi list regarding disconnecting the battery when doing the relay install. Exactly what memory functions will be erased?
larry91 - mud flaps
I looked on gmpartsdirect.com, but they only have part numbers up to 2000 vehicles, so I called GM Product Specialist @ 888-988-7267. A very helpful gal took all my information and put me on hold for a few minutes. When she returned, she apologized profusely for the wait and said she called a few dealer parts departments in my area and learned that the dealers can only buy in case lots, so many don't stock them (DUH!) She's going to try to find a parts department with stock. I was impressed with their service. We'll see if I ever get the information I asked for. I will post it.
jgmilberg - Back Up Lights
Thanks for the advice.
Rich
2k2denali
If you ask the dealer for Denali mudflaps he will likely tell you there aren't any. I installed the regular molded Yukon XL flaps which installed easily and look very nice with the GMC logo.
Rich
2k2denali
Does anyone know if the regular Yukon ones work with the YD?
Rich
2k2denali
You can program the door lock any way you want,to lock,not to lock,to open,not to open,etc.
My 01 Yukon XL came with the locking feature and it took me 2 minutes to program it the way I want.
You don't need to buy any relays,the programming is part of the truck computer.
Instructions for a 01.
To enter the programme mode you need to:
1/ Beginning when the ignition is off,pull back on the turn signal/multifonction lever all the way toward you and hold it while you perform the next step.
2/Turn your key to ON and OFF twice.Then with the key in OFF, release the turn signal/multifonction lever.
Once you do this,you will hear the lock switch lock and unlock.
All doors lock/only the driver side unlock.
Press the lock side of the power door lock switch on the door panel once and the the unlock side once.
This option is unavailable on most vehicle not equipped with Keyless Entry.
All doors lock/all door unlock.
Press the lock side of the power lock switch on the door panel once and then the unlock side twice.
This is the factory setting.
All doors lock/none of the doors unlock.
Press the lock side of the power lock switch in the door panel once and then the unlock side three times.
No doors locks/none of the doors unlock.
Press the lock side of the power door lock switch on the door panel twice.
This turn off the automatic lock feature.
The relay allows the automatically unlocking program to unlock the doors when the vehicle is moved into park instead of when the ignition is turned off. Its relatively inexpensive ($25) and apparently was changed in the 2002 models.
Andy12, I had the same problem on my 2001 Denali XL. Took it to my dealers bodyshop, left it for a day, they readjusted the door and put on a new rubber bumper, painted it and i have not had the problem since. I am still keeping my fingers crossed, i have had a few minor but annoying problems.
The color is Pewter Metallic.
Is this considered "clear coated" or "regular" paint. Thanks
Rich
2k2denali
When I had the under hood fuse box open (to install the hi/low headlight relay), I noticed 2 bolts with red wires attached. Would one of these be acceptable? The lighting harness that comes with the kit has a round terminal (and in-line fuse) already installed on the wire, so a bolt-on power source would be best. Thanks in advance.
Rich
2k2denali
Welcome aboard! I'm sure Yukon owner's here will be happy to help you out!
tidester
SUVs
I have 2 questions. 1. What is Zaino and why is it so great? Does it remove surface scratches or add a clear coat layer? 2. The relays, is one for combining the low and high beams and another for re-programming door locks? Can I install myself or is it a dealer installation.
I have a digital photo of my denali two-toned if anyone is interested. How do I post it though? I don.'t have my own web site.
Debster
See the "Town Hall Help" link for pic displaying instructions. You'll need a place to host the photos though; some free ones (last I checked) were listed in this message:
steve_ "Toyota Sequoia" Apr 11, 2001 10:14am
Steve
Doug
It really amazes me that GM can put a door ajar light in my '92 bonneville but not put one in on my '01 Yukon XL.
1 Step forward....2 Steps back!
Campo57
Doug
Both have lights to let you know a door is open. I can't believe a $45K truck doesn't have it.
You just have to understand how sensitive markets are to pricing - the extra $1.34 it would have cost to include that luxury would certainly have caused their sales to crash! ;-)
tidester
SUVs
There are 3 relays:
1) lo beams stay on when you switch on hi beams instead of going off.
2) fog lights go on WITH the low beams instead of having to manually turn then on.
3) doors unlock when transmission is put into park instead of unlocking when shutting off the engine. Note, this apparently happens
from the factory with 2002 models, at least it does on mine.
I've installed the low beam one, so far. Very easy, as long as you can work with tools, can follow directions and have confidence in your abilities.
Do disconnect the ground cable on the battery. The only memory loss will be the clocks and calendar.
Also, and I learned this the hard way, the parking brake shuts off the auto headlights. After the relay install, I thought I killed the auto headlights, so took it out. After reading on the Delphi board about the parking brake, I re installed the relay and it does work fine.
All 3 relays are available as a set from truckautoaccessories.com for $49.99.
Individually: headlight $14.99 foglight $14.99 door unlock $29.99
There are also a ton of posts on ths subject further back on this board.
Enjoy your new truck!!
Rich
2k2denali
It would certainly cut down on questions to topics already asked and answered.
Rich
2k2denali
You can do a search using the "Board Search" entry field at the top left of this page. Give it a try!
tidester
SUVs
All three relays are worth it and I am sure you won't regret this inexpensive upgrade.
<http://www.truckautoaccessories.com/>
I know about that, but it only searches for the word in the TITLE, not the message text. Many times discussions tangent off of the title subject, or the titles are vague. The title could be "aftermarket stuff" which ends up being a discussion of wind and rock deflectors, door edge guards, relays, mud flaps, etc. If you searched for "door edge guards" you wouldn't get and hits.
Oh well,,,,,,,,,
Rich
2k2denali
I just tried a search for "door edge guards" and it brought me right back to your post! Just to be sure, I did a search on something totally unrelated to this discussion that I know exists on another board -- and it brought be right back here! So much for high-tech!
tidester
SUVs
#1 --The "Service Engine Soon" light comes on and goes off apparently without any reason. Checked the obvious (gas cap, etc.). Guess the dealer is the next stop. Anyone have the same problem?
#2 -- Source for front/rear mud flaps?
#3 -- The passenger seat belt tends to "lock up" with little motion. Solution?
#4 -- Source for recommended hood bug deflector?
Great truck! Just nit-picking items ...
Larry -- NWYukon
after-market "Denali" emblem (prefer script) to mount above or after the "Yukon XL" emblem?
I removed the Yukon XL emblem and replaced it with the factory DENALI emblem that is located on the side of the front doors.
I ordered the emblem from the dealer for about $20.00. It is very easy to put on. The difficulty is in removing the old emblem. IMO, it looks a lot cleaner than the Yukon XL emblem.
Mine works fine for cooling, but the heating is horrible. The thermostat control must be turned all the way up to the 82 mark to get the thing to heat up. It then starts blowing cold air intermittently.
Any fixes for this problem other than having the dealer tear apart the dash?
Thanks for the help.
If I just "tough it out" the automatic system will stabilize within about 10 minutes.
Larry - NWYukon
