C92, I must not be pulling in the right direction or not hard enough, but I can't get the bezel to budge anywhere around it. I began to concentrate at the "B" points since those directions indicate they is first. Am I just being too easy? I will NEVER hear the end of it from my wife if I scratch or tear the plastic. Thx.
Mechanically, I've had no problems thanks to several of the posts above. Electrically, I'm at a stand-still. There are no wiring diagrams available for the stereo and I don't know which wire to tap into to pull the ACC+ power from. I'm a little "green" when it comes to this part.
Any suggestions for the wiring? Recommendations? Has anyone else tried this? If not, I'll let you know soon enough (hopefully)">
The FM Modulator when switched on completely clears out the FM transmission from the antenna and allows a direct-wired connection from the iPod to the factory radio.
It may not use the Bose Centerpoint, but it still has great sound. Very inexpensive installation job to have full functionality of my iPod.
Has anyone replaced the stock HU in a Grand Touring edition, where the climate control displays are in the upper info display? I want to make sure if I buy a GT that this information will still show & work with an aftermarket HU. I really want to add a Navi HU like the Pioneer D3, I assume the clock will not work as someone with a Sport edition told me his didn't after replacing. I can live w/o the clock, but not w/o knowing what temp my hvac is set at! Anyone done this, or can direct me to the proper thread for this info? Thanks!!
SUVs and Smart Shopper
I haven't done this myself (I am too "old-school" for NAV, and I love the stock stereo) but it seems to me that Mazda probably uses the same display for all CX-7s, and since you can get the Bose without the auto A/C, it stands to reason that the radio and HVAC displays are independent. Good luck!
-c92
Now I'm just trying to verify if you can easily add an aftermarket radio in the Bose-equipped CX-7 or if that will cause problems. I like the idea of the additional speakers, but still want to change the HU.
I just found this message board and I think this is great. I just have two questions, does anyone have any email(s) address to someone at Mazda I can contact? Is Mazda planning on correcting this problem of not able to see titles?
Has anyone else installed the Harmon/Kurdon Drive and Play? It looks like the next best thing?
It's so good to know I'm not the only one upset about this. OK three questions.
All I can suggest is setting up your first 5 playlists for use in your CX-7.
Also, if you re-boot your iPod (hold down Menu and Select) while the CX-7 stereo is in another mode (like FM), you will still have the sound connection, but control and display revert to the iPod. The CX-7 will display meaningless track numbers, etc. What sucks here is you'd have to do it every time you start the vehicle. That tip is best used on long drives.
Sferguson, I never used to use playlists at all, but have gotten used to them and now treat a playlist much like I would a CD binder in the old days. Before I head to work, I simply make a playlist (or two or three) and can switch between them on the road, like I would CDs in the changer. Incidentally, from what I can remember, there is only a theoretical limit to number of playlists or songs - I know I've had over 10 playlists, and at times some of those have had over 100 songs.
It'd have been nice if Mazda set the display up for text/title capability in the early CX-7s, but I don't really miss it... 11,000 songs on my iPod and I can still name most of them by memory after hearing the first 10 seconds. "Your tuneage may vary."
-c92
If the cx-7 had this input jack, I would be able to plug and play my mp3 player in to the cx-7 and use the mp3 player display to see what songs and playlists are playing.
i know I am in the majority here but.............
i don't have "apple" tattoos or anything, but i still think you meant "minority..."
Using the re-boot solution I can now get to the music I want to hear and still have a great connection. I am happy to give up using the radio controls to be able to hear what I want to hear when I want to hear it.
THIS IS GREAT. Again thank you so much. I'm going to suggest to Mazda that they include this in their manual. My wife thanks you also now she doesn't have to listen to me complaining about the integration module.
Now I can complain about the iPod Touch with only 16GB.
Thanks again
As far as getting it in the manual, I don't think that's going to happen for a number of reasons that I won't get into.
Any idea why my home-made MP3 tunes will display the title/track on the nav screen, but the store-bought CD's will not display the title/track? Yes, I've read the manual and there isn't any sort of adjustment to be made that I can tell. It's just "supposed" to automatically appear...
Thanks for your help. Chari
How to install aux-input
I am also replacing all the speakers in my car, any advice will be appreciated!
It`s driving me Crazy!! I am new to this ipod thing & the itunes site is hard to use for me. Help Me jake 70
Thank you,
Stephen
