As much as I love the car, it’s going to be my last Hyundai due to the service after the sale.
My son is going to be driver very soon, so I guess it will be his 1st car.
They know they have a problem but they try to make it seem as if you are the problem.
In the rear of the Azera use a Quality Sound Deadening Material. Remove both sides of the trunk panels and insulate both rear wheel wells. Also run the Sound Deadening Material in the space in front of the spare tire or right behind the rear seat. Now remove the rear tires and the plastic cover in the front of the wheel wells and insulate behind the plastic cover. Replace the cover and seal the edges with the 3-M under-body coating. Also install a rubber doughnut on the Bottom of each rear spring.
It's like a different automobile. Quieter, the front end is more stable and the improvement in the ride is amazing. A little work but so far well worth it. New tires, shocks and upper strut bars and I think that would really make it ride like a luxury car.
could you tell me what kind of rubber donaut did you put in your springs? did you put only in front or rear too? did it raised the car a lot? isn't it unstable beening higher?
i also did some mods to my azera. koni struts heavy duty strut bar and thicker sway bars. best result is from sway bar so i think the problem isnt in shock absorbers alone but more in too soft springs setting.
strut bar also did a lot to improving the ride.
If they raised the car it was only a quarter inch if even that much. I put them in the front at the top of the spring and in the rear at the bottom of the spring. You are absolutely correct, the springs are too soft.
Where did you find a thicker sway bar? I found a front upper strut bar that ties the two front shocks together under the hood without any modifications required. Just do a search for Hyundai Azera strut bar I think it was KFX.com $99.
But i think i will not put anything into springs as i am going to sell the car. Beside the too soft spring there is another problem to the cars suspension which i detected and its difficult to correct as it is a a factory missdesign.
The thiker sway bar is all the way from korea from kspec.com site. Its quite expencive. Also i got the strut bar from Luxon Korea. No offence but the strut bar that you got is no good. It is too thin. First i got one like this and it did some efect but nothing like the super heavy duty luxon bar. I can send you some photos if you like my mail is viki6or@gmail.com.
Also i can sell them if you like them. As i am going to sell the car with this upgrades so if you want them i can get them off the car.
I just had my upper control arms replaced around 78K, on my 2006 Azera. I've been experiencing the "Clunk" for a while now and my Hyundia Advisor feels it's the Strut mounts. When I take it in for service next week, I'll have them to check the sway bar bushings.
Thanks for info.
Unfortunately, I have to get my ignition coils replaced before I take care of the sway bar bushings. If you get yours done first, by all means let me know. Of course, I'll post regardless when I get that done.
Happy Easter if you celebrate, if not...have a great weekend.
Sway bar bushings - $6.48
Labor for installation - $198
Clunk/rattle noise gone - PRICELESS!!!
For any Azera owners that have any front end noise (clunk or rattles), please do yourself a favor and get the sway bar bushings replaced. After 7 years and 150k miles, the suspension ALMOST sounds as good as it did when it was new. I guess I had gotten so used to the noise that I forgot how good & quiet the rode before. Truly a night and day difference.
Now I've got a few other things to tend to on the car and I think I'll be ready for another 150k miles!!! Just so you other Azera owners know...once you hit the 100k miles mark, start thinking about your 02 sensors, spark plugs, ignition coils and serpentine belt. Other things I have to replace are the engine/transmission mounts, an A/C pressure switch and the original rotors.
