"D" Area 51 Racing Lucky 13
The first shattered bulb, did not comprehend how could have occurred, but when happens AGAIN, and then the Melting, obviously something malfunctioning.
(am presently on doubletime duty , family member in hospital and can NOt afford delays and certainly do not need stops for malfuctioning tail light and all that such entails as well.
IF any others have experienced this too , if any have suggestions to resolve, would appreciate.
(am adding , this is NOT my car, is hsubands and is what available to drive back and forth..HE is in the hospital, recent leg amputee with complications so need reliable transportation, will appreciate any assit of info in this particular matter as am NOT auto mechanically inclined !! Thanks )
This happened to me while Chrysler was in bankruptcy and the parts were not available anywhere. I had to buy a junked out steering wheel/column and have them take the parts from that.
Bill
These three incidents have happened within a three month span.
I've considered getting a toggle fuse for it, to try to alleviate the symptom, but would prefer a real fix - especially if it can be done on the cheap.
Any solutions will be greatly appreciated.
Sounds like many of us are experiencing the same issue, but there isn't a recall (?)
FYI, I saw today (3/23/11 on nbcla) on the news that 2 young girls were killed by a rental car (PT Cruiser) from fire that came from the steering column that there was a recall (I was never notified of one) on the steering column but that rental cars by law don't have to have them done. A city official is making it law that car rental agencies have to get the recalls done on their rental cars too.
Don
When I start my PT cruiser turbo 2005 it makes a high pitched whine. The engine light and oil light come on. Steering wheel will not unlock and nothing happens at all if I tap the gas. Can switch gears, and the radio and lights fades in and out every few minutes. Could it be a computer problem?
Did you get the air light sorted. Mine has been more or less constantly on for a couple of months beeping at me every minute or so. Worse, I have been told that it's a fault that might not be repairable.
Is it as simple as the airbag genuinely not working (the mechanic says not) or something else?
Answers might save me a fortune!
Will
The cam position sensor basically counts the revolutions of the cam as it detects a magnet on the cam. It's simple.
Good luck!
How do I go about diagnosing this and is there any way to re-wire the headlamps myself?
Seriously disappointed in Chicago.
:sick:
So frustrating
- driver's side key cylinder switch
- multi-function switch
- try manually locking/unlocking all doors (tried this one, no luck)
- loose screw in driver's side door
- replace rke (no idea, not too car savvy) and replace key fob
- replace IOD fuse
Any information on these? Have any worked/not worked??
Looked like my brights were on, at least the indicator light.
Checked it out and found that one of either my lights, fog lights or parking lights had to be on. I did tie up/put tension on my turn signal and got them to shut off.
Came in side, Googled the problem, found this blog.
Pulled out fuse#8 and now fog lights off....looks like my 'brights' probably won't work either now.
fyi..when car was about 3 yrs old had problem with turn signal and replace that switch then. Sounds like same problem now. I was thinking it was close to $300 at the time, but notes make it sound cheaper.
Thanks for everyone's posts on this topic.
