TrailBlazer: Engine warning lights
nasterizer
Member Posts: 1
I recently purchased a 2002 LTZ Trailblazer. I love the car. When i purchased the car it had like a ticking sound when u would start her up but only for like 3 minutes then it would go away. The original owner said that it was from the fan clutch and it was nothing to worry about. H e had even purchased a used clutch but never got around to installing it. two days later as i was driving a yellow engine light came on. i got worried. i kept driving. Then another one came on but with an arrow pointing down in the middle of the engine. I went to a local mechanic and he cleared the alerts. 20 minutes later they came on again. but first the engine light comes on then later on the second one with arrow in the middle comes on. Is this from the fan clutch?? What do these alerts mean?? Im really worried that smthg is going to fail or the car is going to die out on me. All the other guages are stable and i didnt notice any difference in performance. Please anyone help me.
Dealer changed camshaft indicator, did not fix, then installed new grounding bolts, and says all terminals were cleaned,, now wants to change ABS module, which i don't think is the problem, Any clue?
Previous visit for electrical problem, the four way flasher came on when i used the directional signal, same issue, four visits before i researched it myself and told them there was a 238,000 vehicle recall for the same problem on 03(same switch). Bottom line is their electrical components stink and they flounder at pinpointing the issues, Other than electrical problems and there have been others, have had pretty good luck with my vehicle .
just replaced water pump as it had a wobble not leaking. now i'm told it might be theremostat, yet it is working find.feel like they are just changing parts?
Yesterday while driving, the following light lit up on my dash cluster.
service 4 wd, abs, brake.
At the same time my fan stopped blowing out air into the cabin,
does anyone know if these are related and just bad luck having multiple problems at the same time.
Did you speak to the dealership and tell them the concern is still present? Can you please email me your VIN number? You can get my email by clicking on gmcustsvc. Thank you,
Mariah GM Customer Service
