That is correct, the spring-tension clamps will allow for expansion/contraction as things change temparture while maintaining constant and correct tension around the hose.
The screw-type clamps DO NOT change size as the joint expand/contract. If you apply the correct tension on the clamp when the engine is cold, This means that the hose gets TOO MUCH clamping force when things heat up and expand. This can damage (crush) the hose and lead to premature failure or leakage.
Perhaps the reason you have problems with the springclamps is because you are not using the correct tool to deal with them. I used to have problems dealing with the springclamps myself until I started using the proper tool for the job... now it is quick and easy.
Dusty
Any and all comments appreciated.
Also, what would be involved doing it myself??. Would I need a new seal on that side of the diff?, any special tools needed??
Tom.
Me again, well it turns out after talking with people that it was my bearing. It was a real bear to get off as it was kindof frozen in the knucle. It was 209. for the part at napa (usa made). I needed a 32 mm socket for the axle bolt.
Arrgghhh what a job, I'm getting too old for this stuff.
Anyways, while working on it, I was not aware that my whole front drivetrain and driveshaft turn all the time even in 2wd. (Previously I had an s10 blazer and that did not). So at 78k miles I guess I should change my transfer case fluid. Previously I've done the trany (not bad looking0 and pumped out the fluids out of my diffs and replaced w/ mob1 gear oil. I want to drop the diff covers but never have really used formagasket. Does anyone make a gasket for those? I was lucky enough to find one for the trany. Also I am going to change my serpantine belt. Do I need to loosen anything (tensioner? or just push aside while doing the belt swap?
Also I want to change my battery, does anyone know of a national brand that is a direct fit, or do I need to get one that is smaller and comes with adapter plates for height etc....
thanks, and feel free to ask any questions you want.
Tom.
I will NEVER have to change the fluids again AND it gave me another 2-4 MPG better due to less "churn" in the oil.
There is no gasket for the diffs, just use an oil-sucker to remove old oil. That way, you do not have to break the seal.
For front diff, it is easier to fill using the breather hose (end of it is near the battery with a white breather on it)
For serp. belt, once you are CERTAIN how it is routed, just move the tensionor a bit and pull off the old belt BEWARE: RELEASE TENSION SLOWLY.
For battery, look in yellow pages for INTERSTATE, they can supply you with ANY battery ever made. (or make it for you). Also their batterys are "fresh". (Stored dry and acid added when you buy it)
Do not forget that a lead-acid battery starts to age as soon as the acid is put in it. If it sits in a wharehouse for 2 years before you buy it, then 2 years of its life is already gone.
Thanks for the help.
I use a pump on the gear oil bottles, from a mercruiser lower unit fill kit that fits qt bottles and pumps gear oil nicely into tight areas such as diffs or manual transmissions. ( I have the auto).
Thanks for the info on the belt, I will study it, also there is a sticker that shows the routing on the radiator support. Thats nice that it can be done with no tools.
I 've usually gotten my batterys at Sams club or walmart in the past, cheap, and they seem to turnover frequently, also they have date codes on them. But I do want a better fit for the Dak.
Anyways, thanks for the input and I'll keep you updated if any probs.
FYI- i have my original tires the wranglers RTS with 78km on them. I just bought new ones (same for $126 each) and hope to hold off on putting them on until Sept./Oct.. Just to let others know that I have read of poor mileage with those, I just rotate f-r, r-f approx. every 10k miles.
thanks again,
Tom.
I'm thinking either a fuel or ignition problem. I checked the resistance of the TPS. Between the center and left terminals I get about 4.7K ohms at idle and about 0.8K ohms at WOT. I noticed that as I move the throttle open, the resistance will increase slightly before decreasing. I've seen resistances as high as 5.5K ohms for short periods.
Anybody have any thoughts on what to look for? Thanks.
My 2000 Dakota 3.9 has me baffled! The story behind the truck is recently dropped a new motor in the truck (175,000 miles cracked head). Prior to putting the new motor in the truck it had a bad misfire at idle. After the new motor was put in same problem, No vaccuum leaks new plugs wires cap rotor, distributer IAC, fuel pump number 5 injector, belly pan gasket all within the past year. The truck misfires worse after warm up. Have access to the Snap-on Modis and Mitchell on demand but having a heck of time fixing this truck. When I run a misfire data all 6 cylinders show multiple misfires. The fuel sync is set at 0
Any suggestions would be greatly appreciated
Q:i have 89 dakota 3.9L that gives me very bad
milage/gas.i would like to install a 1990 4.0L cherookee engine that i have do you think it is
possible?????i know that both dakota and cherokee come in 4 cyl 2.5l engines.
thank you
You can read all about it here. and here
I am not sure if an AMC engine would easilly bolt into a Dodge engine-bay.
Mandy
I said what the ?...so I checked the brain again, it said the down stream O2 sensor was bad on the passengers side...I said what???? I just put one in the drivers side, give me a break! I replaced that one also...I thought the problem was surely solved now, but it wasn't.
The truck started misfiring again within 3 days. I ran another check on the brain, and it said the 02 down stream sensor was bad, it made me mad to say the least!
SO I pulled it out and the new one was bent on the tip of it. To make a long story short, both the converters were bad, and needed swapping out, along with the O2 sensors.The converters were damaging the O2 sensors, even after swapping them out.
My high dollar brain reader, did not say the converters were bad! After buying 2 O2 sensors, I found out the hard money spending way, thats what was making my truck misfire to start with!
I even took the truck to a Dodge dealer and they said the O2 sensors were bad, not the converters, which was a lie!
For me to cure the misfire problem. I had to swap both converters and buy 4 new O2 sensors. The whole ordeal was very exspensive, to say the least!
You can take your truck to Advance auto,and they will run the test on your truck for free, to see if it's the O2 sensors or converters.The Dodge dealer will charge you for this service, go figure!...
If you have the converters and O2 sensors replaced at the dealer, you can look to spend over $1,000 just for the parts,this dont count labor. The exhaust is sold as a whole unit from the manifolds to the mufflers, they won't sell just the converters by their selves! They will sell you the O2 sensors by their selves.
I would find a private reputable muffler shop and get a price qoute for reinstalling the 2 converters and O2 sensors.It would be a lot less than the Dodge dealers!
I checked around and had the work done for $450.00 at a local muffler shop.(This price don't count what I had done spent on the other 2 sensors:-)
I learned the hard way what the problem was to start with:-) Hope you don't!
Hope this has helped out, and you can get your truck fixed.
I would suggest checking the following items as well:
Air Filter for excessive dirt, air filter housing for obstructions (leaves, etc.)
PCV valve
Rubber vacuum hoses for cracks and subsequent embrittlement
Defective O2 sensor(s)
Defective catalytic converter
This vehicle could also have dirty or defective fuel injectors, a clogged fuel filter or weak fuel pump. Could also have a bad Powertrain Control Module.
Dusty
Dusty
I am having what seems to be a possible motor issue.
I took it into the Dodge dealer and they recovered 2
stored codes. No check engine light was on. The one code was a bad o2 sensor. The other code said "fuel system lean". They replaced the o2 sensor thinking that would take care of it. It did not. When my truck is started it idels high, low, high, low etc. When my truck goes under 10mph it idels rough and when I come to a stop it sometimes stalls. I have noticed that when I am on the highway, it has a hesitation but recovers. It has not stalled on the highway. My check engine light is not on and there are no active codes stored. My transmission seemed to be starting in 2nd. but was not constant. Only when the truck has been running for a while. Since the O2 sensor was replaced, I have not really noticed the transmission issue but I took it to a transmission place and they did diagnostics and said that there are no "codes" for the transmission. That made me think that maybe my calipers are sticking or has something to do with my brakes. My brake pads are new, I need to replace the rotors soon though. Anyone have any idea what I can do to fix this? Every time I take it to the dealer, it seems they have no clue because there is no check engine light on or no codes. Also when they test drive it, it runs normal for them.....go figure. I don't want to replace parts that don't need to be replaced if they are not bad....Any help or ideas would be appreciated.....Thanks! Angi
I've got a 3.9 engine with 170K. Recently the engine has developed a rattle and it does not seem to be consistent with the rev of the engine but it sounds very much like it is coming from the engine. I noticed that the engine is running a little rougher at start up and the idle is not as smooth. Over all there is not a lot of difference in the way it is running. Still has plenty of power and is not running hot or doing anything else out of the ordinary.
Is there anything that comes to mind I may need to be concerned about at this mileage? I know engines develop history and even if they are well maintained they can start showing their weaknesses at high mileage. Could this be a timing chain with a worn out tensioner?
Any ideas would be appreciated!
Thanks, Tim
twalter@insightbb.com
My son was convinced that his '91 3.9 had a bad timing chain because everyone driving a Chevy or a Ford told him it was bad. At 210,000 miles he tore it apart. He asked me to look at it and, yes, there was slack. However, there were no signs it was hitting the timing chain cover.
Convinced that so many people could not be wrong, he changed the timing chain. It did not solve his performance problem. (It turned out to be a combination of bad plug wires, distributor cap, and some cracked vacuum hoses.
That being said, at high mileage I can understand why timing chains are usually first suspected for a noise condition. I would recommend using a stethoscope to listen for the noise generating area of the motor before you tear into the engine. It could be a worn chain or gears.
Best regards,
Dusty
On that vintage your Idle Speed Motor could be binding and not returning back to the correct idle position. This was an occasional problem in those years. If you disconnect the Idle Speed Motor and the idle goes to rest, you could have a bad Coolant Temperature Sensor, a Fuel Temperature Sensor, or a faulty computer.
Make sure that the cables going to the throttle lever on the throttle body are not binding or sticking.
Dusty
Thanks again,
Faith.
I'm not sure what hose you could be refering to, but nothing should be disconnected!
If the connector has been disconnected from the Idle Speed Motor, then I suspect this is what's causing your problem, since you indicate that the high idle problem has not returned. As previously noted, the motors in that vintage sometimes had a tendency to bind and not allow a return to normal idle. Unfortunately, I have seen one that was caused by the computer sending a constant signal to the motor.
Right now the throttle stop located on the front of the throttle body and contacts the linkage at rest is acting as the idle position. The Idle Speed Motor needs to be working correctly in order for the engine to operate properly.
I think on '91 throttle bodies the stop was adjustable, but it is not recommended if you ever repair the idle speed motor issue.
Dusty
Before we can help you get the ignition-wires hooked up right... we needs to know what engine you have? (The Dakota is availabe with 4 different engines)
My problem is loss of power at high RPM’s at 60 mph if I floor it, it will down shift and no increase in speed. If I just give it a little gas so it will not down shift I can get as fast as I want. Well maybe not as fast as I want but fast enough.
The auto parts store ran a code check and it is misfiring cylinders 1&3
So far I have changes plugs, wires, cap, and ran two tank of fuel injector cleaner also my fuel presser in 48 lbs.
I was thinking about changing the fuel injectors in 1 and 3. What would you say my next step be?
now the truck has alittle miss at idle and going down the road if u give it alitttle gas and let i level off at a certain rpm the truck will backfire and start jerking also the truck would stall sometimes it will start and sometimes it wont. found out the plastic piece that hold the wire on the bottom of the coil was broke replaced the coil and the wires were loose so i filled the plug with dielectric grease. that seemed to fix the stalling problem but the backfire and jerking is still there and seems to be getting worse. yesterday i took the fuel rail and the injectors out inspected everything and cleaned everything. injectors seem to be electrically sound. also changed tps,torqued intake down, checked for vaccuum leaks none were found the only code i could retvive was code 12 (1 flash pause 2 flashes) and by the chiltons book is memory standby power lost. the book doesnt say what that is.
the only thing that i can think of that hasnt been looked might be the catconverter or o2 sensor which the sensor was replaced 20,0000 miles ago
is there any suggestions out there or any answer on the code im getting . by the way i have 107,000 miles on the truck
