2nd problem could be the brake light switch. The brake switch also locks/unlocks the shifter lever solenoid. You will not be able to move the shifter out of park if the switch is bad. It's just like not stepping on the brake pedals. 3rd problem could be damaged shift lock mechanism. Forcing the shifter when it is locked will break things in the shifter mechanism. There is an emergency release just in front of the shifter lever. Pop the cover with a small screw driver. Inside the hole, push the lever with the screw driver. While pushing on the lever, move the shifter out of park. Good luck.
Dealer kept telling me that everything was withing specifications... after 10k miles they told me that it was because I did not rotate the tires at 6k miles (BS).
then they told me that i neeeded an aligment.
well I went and got an aligment .. paid for out of pocket.. it did help.. with the wearing out... it's been about 12k miles since aligment.. tires are not wearing out as much..... BUT THE CAR STILL PULLS TO THE LEFT. MAYBE IF I GET NEW TIRES AND RE-ALIGN...SHOULD SOLVE PROBLEM.
TRADE IN THE CAR AND IT EILL SOLVE THE PROBLEM AS WELL. :lemon:
Yes, my stereo faceplate is peeling by the volume knob on my 2007 Elantra SE!
Im planning on seeing the dealer soon. I only have 20,000 miles. Did you dealer
replace it under warranty??
I also have read that it could be the charcoal canister, vent line. I had taken mine off to check it when I learned about the nozzles and decide not to spend the 200 plus dollars replacing the EVAP canister, air filter for the canister and the 2 way valve.
I have worked the nozzle in all the way, held it partially out, turn it sideways and upside down without any difference
Lets see what develops? Check the venting?
http://www.edmunds.com/maintenance/recalltsb.html?styleId=100913165&engCode=4INA- G2.0&transCode=AUTOMATIC&mileage=34%2C000&zip=55420&type=recall&serviceType=#2
Still, would be good to have the dealer check it out. Could be the fuel pump or something else. Any other dealers in your area that might have this special tool?
I took it to the dealer, and they heard the same noise during the test drive and said it is from the rear window. The service center guy explained that the when going over bumps the car twists, and the window makes these kind of noises. He said the problem is normal and that it occurs even in some Toyota cars...
He basically put some lubricant around the rear window seal, and said that it should gradually go away...
It has been a couple of days since he put that lubricant, and I still hear the cracking sounds from the rear...
Has anyone else come across this kind of noise/sound?
Also, have you returned your survey yet? The dealers treat those very seriously. If you haven't filled it out yet, you might call the sales manager and explain you'd like to give them top marks on the survey, but you can't while this issue is unresolved.
My issue seems to be worse when it is cool outside. I live on hill so I hear the loud rear window popping every time I go up my driveway.
Did yours ever get fixed?
If you don't mind. Do you know if the spacer solution was a "Hyundai solution" or a clever fix by a mechanic and/or the auto glass co.?
We have a 2008 Hyundai Elantra.
Today while driving at 60Mph with cruise control, stepped on the break to slow down and instead the engine revved up, the car jumped and started speeding up to 65-70Mph. It was a considerable effort to get the car stopped as the breaks did not seem to work. It also resulted in getting chased by a cop...
After finally stopping, the shift was locked, would go only into neutral, but not into reverse or park.
The car got towed to the dealer, and they replaced the "break switch" saying that was the reason for all the problems...
So, can a "break switch" speed the car up, not let the car break, and lock up the shift?
Or should we be afraid of hitting someone, next time this happens?
Thadson
The brake switch operates a few things. It turns the brake lights on; it disengages the cruise control; it also controls the shift lock, traction control and ABS.
There is an open recall for the brake switch (see here and here) and that would cause your problem. If the dealer replaced the brake switch, your problem should be solved.
The National Highway Traffic Safety Administration (NHTSA) and Hyundai have initiated recalls on 963,305 vehicles as part of four separate campaigns. The first recall, blanketing over one half million late-model vehicles, is nationwide. The other three recalls, all corrosion-related on older vehicles, are limited to the regions of the country where salt is used to de-ice roads in the winters.
The most widespread recall, affecting up to 531,894 2005-2008 Accent, Azera, Elantra, Entourage, Santa Fe, Sonata, Tucson, and Veracruz models, is NHTSA Campaign 09V122000. It is focused on a malfunctioning stop lamp switch that may prevent brake lights from illuminating when the pedal is depressed (the same switch may also cause them to stay lit after the brakes are released).
Manufacturer: HYUNDAI MOTOR COMPANY Mfr's Report Date: APR 14, 2009
NHTSA CAMPAIGN ID Number: 09V122000
PE09003
NHTSA Action Number: PE09003
Component: SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE LIGHT
Potential Number of Units Affected: 531894
Summary:
HYUNDAI IS RECALLING 531,894 MY 2006-2007 ACCENT, ENTOURAGE, SONATA, MY 2007 AZERA, ELANTRA AND SANTA FE, MY 2005-2007 TUCSON AND MY 2007-2008 VERACRUZ VEHICLES. THE STOP LAMP SWITCH IN THE AFFECTED VEHICLES MAY MALFUNCTION. A MALFUNCTIONING STOP LAMP SWITCH MAY CAUSE THE BRAKE LIGHTS TO NOT ILLUMINATE WHEN THE BRAKE PEDAL IS DEPRESSED OR MAY CAUSE THE BRAKE LIGHTS TO REMAIN ILLUMINATED WHEN THE BRAKE PEDAL IS RELEASED. A STOP LAMP SWITCH MALFUNCTION MAY AFFECT THE OPERATION OF THE BRAKE-TRANSMISSION SHIFT INTERLOCK FEATURE SO THE TRANSMISSION SHIFTER WOULD NOT BE ABLE TO BE SHIFTED OUT OF PARK POSITION. IT MAY ALSO CAUSE THE ELECTRONIC STABILITY CONTROL (ESC) MALFUNCTION LIGHT TO ILLUMINATE, AND IT MAY NOT DEACTIVATE THE CRUISE CONTROL WHEN THE BRAKE PEDAL IS DEPRESSED.
Consequence:
THESE MALFUNCTIONS MY LEAD TO A CRASH.
Remedy:
DEALERS WILL REPLACE THE STOP LAMP SWITCH FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL 2009. OWNERS MAY CONTACT HYUNDAI CUSTOMER ASSISTANCE CENTER AT 1-800-633-5151.
Notes:
HYUNDAI RECALL NO. 092. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
Anybody have knowledge, that if we make a big enough stink we can get a loaner car? (son needs to return to college 1 week)
If I were you, I would press (politely) for a loaner car while you are waiting for the transmission. Mention your hardship (son needs to return to college) that was caused by Hyundai's inability to fix the car promptly. If your dealer is at all interested in maintaining customer loyalty and satisfaction, they'll provide a loaner or pay for a rental.
It's driving me nuts, how do I make it stop?
Is there a recall or something?
Everytime I go over a bump or turn into my driveway it pops from the rear window area.
It only happens when I put the gear to "D", I tried to put the gear to "3" or other settings and no vibration at 35-40mph.
Does any experience this vibration?
I took it back to them, and they convinced me that it would go away after sometime; and re-applied the lubricant.
At that time they also said that if it still doesn't go away; the next time I come they would call the 'Glass repair' folks and have the rear window removed and resealed.
Anyways, long story short, the noise went away after a couple of days just with the lubricant...didn't have to go back for the glass work. It has been 4-5 months now, and I don't get that noise anymore.
I have taken it to two different Hyundai dealerships and neither service department has been able to replicate the problem or find any stored codes that would indicate what the issue is. I am still under warranty, but they tell me they can't do anything for me at this point. The first service rep simply told me to keep the Hyundai Roadside Assistance number handy. The second rep told me to try fueling it with a higher octane grade.
I am extremely frustrated and I am anxious about driving it. Does anyone have any suggestions???
2. Check/change any filters you can. Air filter, etc. If not electrical, then maybe it isn't getting the air or fuel it needs.
3. Agree with burning a few tanks of premium. It's possible you got some bad gas.
4. They shouldn't need changing but check/clean the spark plugs.
We are looking for people who have the same problem as we do with our 2008 Hyundai Elantra.
We had several occasions since last summer (2009) where when stepping on the brake instead of slowing down the engine revved up and the car started speeding without touching the gas pedal. We have the cruse control on when driving, however it is not always set. For instance we were getting chased by an officer as the car would not slow down when stepping on the brake in a limited speed zone or lurching forward in a parking lot as we wanted to come to the final stop, causing the car running into the 4 lane traffic through the bushes and the side walk. The car has been back to the dealership 5 times and since they cannot duplicate the problem they say there is no problem existing. They are implying that we cannot drive, and that we are maybe lying about it to take advantage of the manufacturer.
We had arbitration, and since at the time of the arbitration test drive the problem did not occur, they decided that the car is not dangerous to drive, and the problem does not exist. They implied their solution of trading in the car and get a new one. The car is a road hazard it can cause a deadly accident at any time, and since the problem occurs randomly it cannot be avoided really. How could we possibly trade it in and sleep well at night knowing that maybe someone else will be hurt just because we passed over our problem. Just because we would not own the car that does not mean that the problem is solved. We are in shock to see that certain individuals value money more then human life.
We are going to go further with this issue to another arbitration and trying to find people who have the same problem.
Online, we have found a lot of complaints about the same type/model of car and same issue; we will pursue to find those people as well. Your help would be greatly appreciated. We have to do something together for public safety before something tragic happens.....
Thank you very much for your time...We are looking forward hearing from you.
On monday my car was totalled due the car not stopping when the brake was applied. It felt to that the car sped up when i applied my brake there was no stopping it. At the time i was pulling into a parking spot at the local cvs and hit a structure @ this point there is over $9000.00 in damanages and wait for insurance company to investigate.
I would really appreciate any info you could forward me and i would gladly help you with any info i receive at this point its trying to prove the defect in the brakes
Therese
Or at least this is what my lawyer told me, for the next time when the car speeds up again while breaking...
We got denied on arbitration, and I was told that we will always be, as long as we take our car only to Hyundai's service because they get rid of anything proof even if they find something...
I'm not saying they would not try to fix the car, but they will do everything in their power to make sure nothing comes out... Imagine a Toyota type bad publicity for them... They don't want that, so they will deny and deny...
