When accelerating from stop to about 40, there is a rumbling noise, which sounds like it's coming from right beneath the centre front floor, somewhere between the exhaust manifold and the cat. I've only listened to this from inside the car. The best I can describe it is, it is the type of sound you would hear on many GM cars like the Grand Am, Grand Prix and older Cutlass series cars. Sort of like a catalytic converter rumbling type sound. It only happens when in Drive though, not when revving in Neutral or Park.
Is this normal? Sorry, the last car I drove was much older and I'm not the best authority on what noise should and shouldn't be there in a new car.
Thanks in advance.
How far does the car roll?
It had a sluggish ride and I would hear noises from under the hood and whenever I started the car and when I would put it into reverse, there would be a another type of noise from the shifting area. I took my car to the Hyundai service department, I told them that my car was sluggish up a hill and it's making a noise when I shift into park and reverse, the service guy drove it, took a look under the hood and noticed there was metal in the transmission fluid, and that's when they said the words "your car needs a new transmission" I just bout fell out of my seat. My baby now has a new transmission and she's peppy.
Hopes this was helpful.
Gary
Any help would be much appreciated !
Thanks - Sarah
Frank
My problem went away by doing this. No idea about the buzzing??
http://www.hyundai-blog.com/index.php/2010/08/10/2011-hyundai-elantra-has-new-si- x-speed-automatic-transmission/
So, will Kias get it too?
As I started driving i realized that i could not go above 30 or 40 mph, and that the gears on the shift were not working. No matter whether it was in drive or a different gear, same result. In order to get the car to 40 mph i had to really hit the gas and get the RPMs to 5,000 or almost 6,000.
Well i got home and then realized i had no reverse, so i put the car in neutral and pushed the car into my driveway. I then shut the car off for the first time. As I decided to bring the car to a mechanic i turned the car on and now everything is working fine, however the transmission fluid is now very dark, almost black...lol..
I know this needs to be corrected, but should I just get a transmission flush or a just drain out the current transmission fluid and replace it with new transmission fluid...im not concerned about cost.. thanks to all for your help...
K
My guess, BTW, is that it overheated. It then generated the errors, entered limp mode, and between the overheating & your driving it the fluid got burned.
At a minimum you'll probably need the replace the fluid.
If it's a 2008, I'm under the assumption that it's still under warranty. Do NOT just get a trans flush...as I said your problem sounds like exactly what happened to me.
Thanks, Steven
P.S. Been doing some more research, I see several mentions of replacing shifter bushings, can this help with my problem? Some are "racing" bushings, or should I stick with OEM parts?
Before I took it to the dealer I even replaced the ECM which I found a replacement for on Ebay for under $30. My advice is that if it comes up as a P1529 or any other code that refers to a generic problem with a sensor on the transmission then you start with the input or output sensor as they are actually sitting on the transmission itself. All the other changes I made could have been avoided.
Good luck
