Subaru Forester Electrical/Lighting Issues
This is the place to chase down those electrical gremlins in your Forester.
I'm competent enought to have installed keyless entry, but that was with the help of a repair guide for my other car. Opening up the steering column has me a little more wary. I've searched all over for a Chilton's like guide for the 2000 Forester, but can't find anything other than the really pricey factory manuals. I guess I'd settle for one of those if I can get some help finding the right one.
Any advice?
First question is whether the car is fitted with a Driver's Airbag. If so, entrust it to an expert as the entertainment of an airbag triggering is something you don't want to experience.
Cheers
Graham
-Frank
I hope you have similar luck?
-juice
I am brand new to this forum--sorry for the length of the post but it's an extremely odd occurrence. I bought a 2006 Subaru Forester X in July of 2005 (brand new, only owner).
A couple of months ago we had a fuse short out which my husband replaced with the Subaru spare fuse (yes--it was the correct fuse). Two days ago, we drove the car to work in the morning, I got back to it about 10 hours later to see a third of the passenger side floor BURNED, the inner console burned to the point that the plastic on the right side of gear shift was completed melted (you can nearly see underneath the gear). It melted so much that it approached the dc lighter box (below stereo). It seems that the root of the fire/meltdown came from underneath the passenger seat where I'm told the main system board is located. I did not dare turn on the vehicle and am still dealing with Subaru of N. America to determine what is going on. I was wondering if anyone has heard of this sort of thing happening. The entire front area is completely smoke damaged (all uncovered interior is now smoke colored and all exposed plastic/glass is smoke covered). I don't think it was a fire because there was a newspaper right on the passenger seat completely untouched. Also---we DO NOT smoke on this vehicle. Any suggestions would be great. I am really upset about this because I LOVED my car. I had no problems for the first 13 months of owning it.
I hope you reported the fire and damage to your insurance company! If not, please do so. Once they are involved, any car manufacturer repairs the damage far more promptly.
I had a crack appear in my sunroof, same car as yours. They told me it must have been a foreign object hitting it. I took it to my AAA office, and they called Subaru, and they repaired it as soon as they received the replacement glass at the dealer. Seems the insurance company had documented many reports of the exact same fault, in the same place, rear left corner, from other Subaru owners.
See, the Insurance Industry operates a computer database of all such "odd" and not-to-odd occurrence's. Makes it much harder for the car companies to claim they don't know about such things, or they are the owner's fault.
I totally agree with you about loving my Forester. Keep us posted on what happens, please!
Obviously take it to your dealer but also call 800-SUBARU3 and ask them to open a case number for you. Ask them for a loaner car while all the repairs are done, and tell them you want replacements for all the items damaged by the heat, including the center console panels affected.
The dealer will do the work but the 800 guys basically monitor your case to make sure you are taken care of.
-juice
As for the light, sometimes a bad one comes along, and that's why its annoying, because we all take for granted they will last a dozen years, and most do.
If you have never been into the dash panel, or installed your own radio and sound systems, I really recommend that you bite the bullet and have the dealer do it. Those areas are so jammed with wires and crap, unless you really know what you are doing, it can sometimes end up with an expensive repair when they have to trace down something mistakenly pulled loose or shorted. :sick:
-juice
-mike
John
-Brian
I'd do a quick check of fluids -- if the odor doesn't smell like oil or coolant or transmission fluids, and all your levels are okay, and there aren't any leaks, it's probably just the undercoating.
-juice
OK, so how do you change them?
I was told by the dealer that it had to be done by them cause they had to hoist the car and remove something to gain access to it.
Charged me $150 AUD cause a bulb is not under warranty.
That's the last time I let those thieving swines change a bulb in my car.
Thanks. :confuse: :confuse: :confuse:
A friend that I was driving with and I popped the hood to check all connections, and nothing seemed to be amiss. The vehicle has 75,000 miles on it, and the battery is the original. We're thinking it's a problem with my alternator because all of the accessories dimmed out. Anyone have a similar experience? Any idea how much replacing an alternator costs?
Thanks in advance,
Eck
-mike
I ran across a situation where the fuse looked fine but wasn't, it had still burned out. I swear I could see no flaws in it, but a new one still fixed it.
Worth the few pennies to try that.
On the other hand, I don't see how a jump can pass the fuses and cause damage to the instrument panel itself.
Thanks!!
Bill
-mike
Check the belt tension first. Also inspect the belt for aging.
-mike
Juan
Check on Scooby Mods and you will find the full procedure on there.
